Bob Barrow
Posted: Sun Aug 08, 2010 3:26 am Post subject: Z14 regulator voltages |
I have installed a Z14 split bus architecture with 2 B&C LR3 regulators. I have a couple of avionics devices that can draw power from both buses. They will draw power from whichever bus providing the greater voltage.
In order to ensure that a particular bus normally provides the power to these devices I will presumably have to have that bus running at a slightly higher voltage than the other. As provided by B&C the LR3 generates 14.2 volts. I presume that I will have to set the secondary bus(non preferred current supplier) to a lower voltage.
My question is what voltage should I set the secondary bus to: would 14.0 volts do the trick.
My second question is how do I determine the actual voltage of the adjusted secondary regulator without actually running the alternator (I'm probably 12 months away from running the engine). In other words I know how to make the adjustment but I'm not sure how to determine if the voltage adjustment is accurate.
Regards Bob Barrow
Posted: Sun Aug 08, 2010 8:49 am Post subject: Z14 regulator voltages |
Why are you doing this? The whole idea behind
Z-14 was to cover any single point of failure
with a robust plan-b. What kind of event do you
anticipate that takes down an entire bus structure
such that "dual sources" for some appliances is
called for? The whole architecture of Z-14 is already
set up to offer 4 sources of power for everything
in the airplane no matter what bus the device is
fed from.
You can't. All operating adjustments are made
with the alternator turning and anticipated
loads turned on.
Bob Barrow
Posted: Tue Aug 10, 2010 12:23 am Post subject: Re: Z14 regulator voltages |
Yep, I take your point Bob. However the engine management system on my EFIS of choice will only provide me with a voltage reading on both buses if I actually source power from both buses via a primary and secondary power input. And I really want a voltage reading for both buses.
My ignorance was in thinking that the EFIS would source power from the bus of higher voltage...and that it would oscillate constantly between the two buses if they had similar voltages. But the EFIS manufacturer now advises me that this is not how it works.
In fact the EFIS always draws power from the primary bus, and only switches to the secondary bus if the voltage on the primary bus drops below approx 8 volts.
Of course having a seamless transition to the secondary bus in the event of a catastrophic failure of the primary bus ensures that there is no reboot and therefore no loss of potentially crucial flight information.
Six years of building and I'm still learning something new virtually every day. It's great. And the "Connection" is the most fabulous of resources.
Cheers Bob Barrow
fed from.
Posted: Tue Aug 10, 2010 6:44 am Post subject: Z14 regulator voltages |
At 03:23 AM 8/10/2010, you wrote:
<bobbarrow10(at)hotmail.com>
These are independent electrical systems and
would normally be fitted with separate voltmeters.
They certainly need to be fitted with their
own active notification of low voltage.
| Quote: | My ignorance was in thinking that the EFIS would source power from
flight information.
We've had a lot of builders investing intellectual
and emotional capital in devising golden power sources
for devices that are not themselves golden. Failure
TOLERANT design assumes that EVERY installed item
is subject to failure from defect, wear-out or
improper installation. The elegant design uses
the minimum of components and operating procedures
to detect and react to any single failure for
any reason.
With a cross-feed contactor closed, All the busses
in Z-14 enjoy (count 'em) FOUR separate sources
of electrical energy. Detecting and reacting to loss
of an alternator requires nothing more than active
notification of low voltage for each bus. All contactors
are pre-flight tested and the cross feed contactor
is normally left off in flight. The layers of capability
to react to a failure in this system are many and
robust.
Catastrophic failures don't happen. Some single
component fails which MIGHT produce a reduced bus
voltage . . . but doesn't take it to zero. Do
you plan to spend a lot of time boring pathways
through clouds? If your EFIS suffers its own failure,
what is your plan for dealing with it? It is many
times more likely that your EFIS wanders off into
the weeds than it is to loose power.
We'll have several options available for monitoring
the health of a multi-source electrical system.
One interesting device is the 9011 multi-channel
monitor. Two such devices installed on Z-14 would
provide real time monitoring of both alternators and
battery contactors.
| Quote: | Six years of building and I'm still learning something new virtually
I'm pleased that you find the work useful. It's
been a great project for me in that much of
what I've been able to share with the OBAM
aircraft community is not understood/practiced
by segments of the TC aircraft community.
Attempts to help them understand and react to
this condition have thus far been un-successful.
They don't know what they don't know and
cannot appreciate the increased risks, costs of
certification, manufacturing and ownership that
accompanies such ignorance.
You folks are building some of the most utilitarian,
low cost and lowest risk airplanes in the world.
I am pleased to be a participant in that endeavor.
