philipguziec(at)yahoo.com Guest
Posted: Mon Aug 02, 2010 3:53 pm Post subject: More data on that IO 720 |
Oil looks clean with no chips in the filters or screens. Just starting oil
analysis, so no data there.
Thanks again,
PHil
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
hcourier(at)cox.net Guest
Posted: Mon Aug 02, 2010 6:49 pm Post subject: More data on that IO 720 |
I flew a commander, 680FLP with the IO-720s for 1,100 hrs. Oil pressure on
both engines was always at the bottom of the green at idle and at cruise
after it warmed up. Never had the prop problem, however the plane I flew
didn't have a prop accumulator. You might look there, and since the
accumulator was just overhauled seems that's what might be the culprit.
Sent: Monday, August 02, 2010 6:53 PM
To: <commander-list(at)matronics.com>; <mooney(at)aviating.com>;
<mooney-tech(at)aviating.com>
Subject: More data on that IO 720
<philipguziec(at)yahoo.com>
oil
Thanks again,
PHil
yourtcfg(at)aol.com Guest
Posted: Tue Aug 03, 2010 7:37 am Post subject: More data on that IO 720 |
HELLO PHIL....There is nothing unique about the 720 oil system, it is the same as most direct drive lycs. If the O.P. is low at idle (or any RPM) and the adjustment spring cant compensate for it, The engine is bypassing oil. Usually, the OP will be high (to high) when the oil is cold, and then drop off with the rise in temp. No good news here. Probably camshaft bearing to engine case clearance?? How much TSOH? Could be the seat that the op ball sits in. These can be changed fairly easily, or the ball itself?? I have run GSO-480s many hours with this malady, I even used 120 weight oi to help outl, and the engine did not expire. My propeller did work normally.
Assuming the propellers are steel clamp, counterweighted Hartzells, there is a large spring that takes the blades to high pitch/ feather. If the propeller does not get enough engine op, it cannot come out of high pitch or feather. sorry, but it sounds like an engine problem to me.
jb
