Posted: Fri Jul 30, 2010 8:34 am Post subject: New Z-8 drawing |
Discussions with Jon Laury combined with conversation
about the abortive Z-13/8 architecture some months
ago have prompted a new Z-figure.
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z08A-PRELIMINARY.pdf
Design goals include but are not limited to
Fuseblock-friendly design (crowbar ov protection
replaced with new field disconnect relay system.
Two layer electrical system similar to that crafted
in Z-13/8.
No practical limit to the size of the aux alternator.
Anything from the SD-20 on up can be adapted to this
architecture.
Single battery.
This architecture seems well suited to electrically
dependent engines where demand for energy exceeds
what an SD-8 can supply. The two-layer architecture
(as opposed to single-layer like Z-12) offers a way
to make the majority of the ship's electrical system
completely cold while maintaining engine operations.
I'm still pondering the ingredients that might work
best in this recipe for success. Thought I would share
it with the group. It's a good example of how new
and useful things can evolve from a group of folks
willing to throw some stuff against the wall to see
what sticks!
rckol
Posted: Fri Jul 30, 2010 3:09 pm Post subject: Re: New Z-8 drawing |
I might be missing something here, but it seems that unlike the Z13/8, if the battery contactor is open, only the battery bus will be fed by the aux alt (no feed for equipment that might be on a traditional ebus, like minimal pfd, nav and comm).
Is this the intent, or do these other functions get piled into the battery bus?
_________________ rck |
Posted: Fri Jul 30, 2010 7:23 pm Post subject: New Z-8 drawing |
At 06:09 PM 7/30/2010, you wrote:
battery bus?
One could add an e-bus to this architecture . . . and
in fact, I'll do so at the next iteration.
Thanks for bringing it up. I hadn't really got that
far yet . . . the e-bus can be added to virtually
any architecture. I was fixated on getting the fat
wires managed first.
jonlaury
Posted: Sat Jul 31, 2010 6:52 am Post subject: Re: New Z-8 drawing |
Hi Bob,
When you said
| Quote: | Discussions with Jon Laury combined with conversation
ago have prompted a new Z-figure |
did you mean Z-13/20 here?
John
Posted: Sat Jul 31, 2010 7:31 am Post subject: New Z-8 drawing |
At 09:52 AM 7/31/2010, you wrote:
Hi Bob,
yes . . .
jonlaury
Posted: Fri Aug 06, 2010 11:31 am Post subject: Re: New Z-8 drawing |
Bob,
Just to be clear, in a previous exchange you said that ALL essential engine power should come from the Batt Bus. Does that mean redundant systems (#2pump, #2ignition, #2EFI {switch}) also reside on the batt bus?
If the answer is yes, what is the reasoning for not having them on the main (separate) bus?
John
Posted: Sat Aug 07, 2010 7:32 am Post subject: New Z-8 drawing |
At 02:31 PM 8/6/2010, you wrote:
Bob,
One set would run from the battery bus, the other from
the main bus.
| Quote: | If the answer is yes, what is the reasoning for not having them on
The design goal is to be able to shut down
as much of the electrical system as possible
without killing the engine. So if you get a
severe electrical event (smoke in the cockpit)
you can turn off the battery master and alternator
switches without affecting engine ops.
So the primary engine support hardware would
run from the battery bus, secondary engine
support would power from the main bus.
This separation covers a smoke-in-the-cockpit
event without having to manage any switches
over and above the power sources.
I've discovered any really attractive
high-current diodes for aux alternator b-lead
isolation. Electrically suited components
are pretty bulky after you get the heat-sinked.
They're also more expensive than a contactor.
So your original idea for tasking a single contactor
with ground power management AND b-lead crash
safety has some warm fuzzies about it.
My grand daughter was visiting most of last
week which was a most pleasant but commanding
distraction. I'll get my head back on things
electric pretty soon.
jonlaury
Posted: Sun Aug 08, 2010 1:45 pm Post subject: Re: New Z-8 drawing |
Bob,
Per your last post, re your grand daughter | Quote: | The design goal is to be able to shut down
without killing the engine. |
Sometimes I feel this is applicable to my nephews.
| Quote: | So your original idea for tasking a single contactor
safety has some warm fuzzies about it. |
There are two concerns here with my set-up. See attachment
1.My ground power jack positve lead to the contactor is about 30". When the SB alternator is on line the GPJ lead is hot to the battery through a 40a MANL . I reasoned that worst case, like a shorted diode plate in the alt, the MANL would keep things from getting out of hand should the 4AWG GPJ lead be breached by anything, that I don't like to think about, during inflight SB alt ops.
2. To control the GPJ/SB alt contactor by the SB Alt switch, without having to remember to close the GPJ contactor, I have two parallel switch legs from the neg side of the contactor coil to ground. One for
the GPJ per the Z figure and one for a leg of the DPDT switch that has 9024 control of the SB alt.on the other leg.
Other than inadvertently closing the GPJ/SB alt contactor by the GP switch and putting both alts online at once (are there bad things that happen??), I can't see any problems with doing this. But when asking a system to do double duty, I'd like some other eyes to have a look for gotchas.
And speaking of double duty, could the 9024 Ovm on the contactor also dispense with the need for the (9005 LVM) on the Batt bus?
John
Z8 w-SB ALT-GPJ conceptual .pdf |
441.09 KB |
536 Time(s) |
Posted: Mon Aug 09, 2010 2:34 pm Post subject: New Z-8 drawing |
| Quote: | 1.My ground power jack positve lead to the contactor is about 30".
through a 40a MANL.
The ground power lead can't go through the MANL40.
You can't crank an engine through that small a fuse.
This lead is in the same class as a "FAT WIRE" that
feeds battery/cranking circuits and does not give
rise to a lot of risk that cannot be managed by shutting
off the crew controlled power switches.
| Quote: | 2. To control the GPJ/SB alt contactor by the SB Alt switch, without
a look for gotchas.
I'm praying over this a bit. What's your s/b
alternator/regulator combination again?
| Quote: | And speaking of double duty, could the 9024 Ovm on the contactor
Yes, or better yet, the 9011 dual LV monitor
can watch both the battery and main busses
and perhaps handle s/b alt OV too.
Still sifting the marbles . . .
jonlaury
Posted: Tue Aug 10, 2010 9:58 am Post subject: Re: New Z-8 drawing |
| Quote: | | The ground power lead can't go through the MANL40. |
Sometimes I get so buried in how it all connects that I overlook what it's for. Thanks for catching that.
| Quote: | What's your s/b
Main alt, 60a with LR3
Stby, 40a with a generic Ford regulator.
[/quote]better yet, the 9011 dual LV monitor
Is the 9011 available from the AEC? Or do I need to roll my own?
John |
Posted: Tue Aug 10, 2010 1:10 pm Post subject: New Z-8 drawing |
>> What's your s/b
Okay, we can press a 9024 into service as dual
LV warning only. Another 9024 would take care
of lv warning for both battery and main busses
PLUS ov protection for the S/B alternator.
The 9011 is all done except for writing the installation
manual and getting it into production. Proof
of concept articles have been flying for awhile
with no unhappy feedback. The 9011 will be right
on the heels of the 9024.
Also, the amber LED warning light fixtures
illustrated at
http://www.aeroelectric.com/Catalog/AEC/9011/
are available. I could probably come up
with placards too.
jonlaury
Posted: Wed Aug 11, 2010 9:34 am Post subject: Re: New Z-8 drawing |
| Quote: | Okay, we can press a 9024 into service as dual
I'm a little confused about the need for two 9024's if one can give LV indication for Batt and Main busses and OV protection from the stby alt.
And would the OV protection extend to the shared contactor (stby alt/GPJ) for the ground power jack as in the attached?
John
446.97 KB |
558 Time(s) |
Posted: Wed Aug 11, 2010 3:31 pm Post subject: New Z-8 drawing |
Oops, I had a brain-f(at)#t and was running the
hampster wheel on another system. Got too many
irons in the fire.
I'm still stirring the pot on how to get the
s/b alternator b-lead contactor to retain
ground power reverse polarity and ov protection.
The architecture you've illustrated agrees with
my best recipe for the moment. Separate ov protection
for the ground power contactor (probably crowbar)
and another for s/b alternator field (probably
9024 driving a relay so you don't need a circuit
breaker).
| Quote: | And would the OV protection extend to the shared contactor (stby
We need to think about how the crowbar ov
module interacts with the 9024 ov protection.
We don't want the contactor to open before the
ov relay gets tripped. I think we'll want to wire
things so that the crowbar module is effective only
while the ground power control switch/breaker is
closed. I.e. move the black wire to the cathode
end of the diode in the ground power control lead.
jonlaury
Posted: Wed Aug 11, 2010 10:17 pm Post subject: Re: New Z-8 drawing |
| Quote: | Oops, I had a brain-f(at)#t and was running the
irons in the fire. |
No worries and I know that I speak for all of us on this forum; it is simply astounding that you manage to participate here as much as you do AND keep your day job.
| Quote: | I think we'll want to wire
OK, that's done in the attached. I quarantined the 9005 module for now until OV protection and LV monitoring gets ironed out. With 9024 control of the SB alt, I deleted the fuselink from the Batt bus in favor of a 5a fuse.
Re the Main bus, with an LR3 in there, it seems that the main bus is taken care of and it's not necessary to integrate the SB alt 9024 voltage monitoring into the main bus. Can a 9024 now focus solely on the SB alt and battery bus?
John
439.52 KB |
543 Time(s) |
