4 into 1 dsub connector
cjhukill(at)cox.net
PostPosted: Mon Jul 26, 2010 6:15 am    Post subject: 4 into 1 dsub connector Reply with quote
I'm wiring my RV10 for the Dynon network and am looking for a source for a high quality (OBAM) 9 pin Dsub connector that would split into 4. The Dynon solution is multiple 2 into 1 harnesses, but a 4 into 1 splitter would be a more elegant solution, if such a device exists. The ribbon mount connectors that Bob had on the list isn't appropriate for aircraft critical systems, I believe, nor is the ribbon of sufficient gauge, but a solid multi connector would be. All the normal searches have struck out for me, but maybe someone knows a source?
Chris Hukill
PostPosted: Mon Jul 26, 2010 2:54 pm    Post subject: 4 into 1 dsub connector Reply with quote
Those are generally fabricated by individuals
who have the application. Suggest you consider
ExpressPCB layouts to mount an array of the
necessary connectors on a single board. See:
http://expresspcb.com/
If you're not inclined to become a board layout
person, I or perhaps someone else on the List
could do the layout for you. A minimum order
from ExpressPCB would get you 6 or more of
the necessary boards for $59.
[img]cid:.0[/img]
Be advised that this will only work to gang
like-sexed connectors. When you put rows of
connectors on "combed" traces, pin 1 will
be connected to pin 1 of all other connectors
only if they're the same gender.
The ribbon cable adapter was intended for
test purposes only. I've used a lot of mass-terminated
ribbon cable in test setups but not for
qualified production.
 Filesize:  32.96 KB
 Viewed:  1957 Time(s)
