dsvs(at)ca.rr.com Guest
Posted: Sat Jul 24, 2010 7:12 pm Post subject: Low Voltage Warning Light |
I am using an LR3 voltage regulator and a B&C 60 A alternator. Is it
acceptable to change out the supplied warning light for a red 12 volt led?
It would be in my direct line of sight so I do not think the lack of
blinking would be an issue. That is if the blinking is a function of the
light and not the regulator. Please let me know if there would be problems
with using an led and if it would blink. TIA Don VS
Posted: Sun Jul 25, 2010 4:08 am Post subject: Low Voltage Warning Light |
At 10:11 PM 7/24/2010, you wrote:
Yes, but the circuitry in the LR3 was designed
to drive incandescent bulbs. You'll need to
add some resistors to the LED circuit such that
the LED mimics the bulb. See:
http://aeroelectric.com/Pictures/Schematics/LR3_LV_Led_1.jpg
| Quote: | It would be in my direct line of sight so I do not think the lack of
with using an led and if it would blink/
The flasher is built into the LR3.
mikef(at)apexconsultingse Guest
Posted: Mon Jul 26, 2010 6:41 am Post subject: Low Voltage Warning Light |
For a low voltage light you are unable to ignore I installed on of these Whelen stroble/flasters with my LR3 regular. Sits on the say, even a blind dog can see it when it goes off.
http://www.galls.com/style.html?assort=general_catalog&style=GR309
On Sun, Jul 25, 2010 at 6:08 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | --> AeroElectric-List message posted by: "Don" <dsvs(at)ca.rr.com (dsvs(at)ca.rr.com)>
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
Mike Fontenot
Apex Consulting & Services LLC
Lakewood, Colorado
303 / 731-6645
mikef AT apexconsultingservices DOT com
