AZFlyer
Posted: Wed Apr 26, 2006 7:15 am Post subject: Thanks for all your ideas on cutting Aluminum |
I'm overwhelmed at the response on my question re. "getting a clean edge" on Aluminum. Thanks. I have tried many of the ideas forwarded and frankly most work to some degree; but, none work all the time.
I have a jillson snip, a round "thingy", have a pnuematic shear, lots of files, usually sneak up on the finished cut line, several hand shears, (which work best for me upside down)....
I believe I'm being too much a perfectionist for this problem. I don't have a "debur" problem, I think my attitude is wrong.
...now, onto the wings.
Thanks again for your feedback.
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
jon(at)joncroke.com Guest
Posted: Wed Apr 26, 2006 8:16 am Post subject: Thanks for all your ideas on cutting Aluminum |
I'm sure that everyone has a few techniques they discover during their life
that they wished they knew about much earlier... you know - the ones that
really make a huge difference (life changing?) - and yet were so simple that
they kick themselves for not grapsing it sooner.....
Well this is one for me... and I'll share it with you for what its worth
(remember, you get what you pay for!)
I am almost finished with my 2nd 701... the first was a kit and the 2nd is
mostly from scratch (except for the 'hard' parts which I purchased!) and it
was during this 2nd build that I had to cut and cut and cut LOTS of sheet
aluminum... and it seems it's a common struggle to get a factory looking
cut... no waves, ripples, and STRAIGHT. It IS time consuming, and if you
are in a little hurry... it shows... and the filing to get rid of the teeth
marks... the stretching.. AND if you need a long cut... it magnifies all
these problems. Well, I did my best for the impatient, in a hurry type of
guy that I am and if you dont like the quality of my final edges that
resulted... then you can go build your own plane and do better! (not
difficult!).
Well it was about 3/4 thru the building of this 2nd plane, while filming
Mark and Dave from Can-Zac for the Scratch Building video that I got a first
hand demonstration of their OLFA knife technique.... COULD NOT believe what
I was missing all these years of cutting metal... by dragging this knife a
few times along a straightedge where you want a cut to be made... the sheet
would separate effortlessly... NO teeth marks, No stretching, No waste, and
NO need for two cuts to get it done. An edge results that is as straight as
your ruler... yes it is sharp but cleans up quickly because you are not
dealing with waves, teeth marks or high/low points.
I now rarley use my Wiss shears anymore.. the OLFA knife was $15.... I first
went out to TruValue Stanley hardware and bought a similar looking knife and
blade... it did NOT work.. I thought OLFA was Swiss... its Japanese made! It
must be something special... in fact, right on the knife it reads: "Special
Tungsten blade" (and I thought tungsten makes your incandescent bulbs
glow!)
If you think this is silly to put this in the category of "life changing"
techniques discovered in life.. consider this: I will CHALLENGE you to the
following: the next time you need a straight cut that will become an edge
of some sort on your aircraft, I will make the cut you need in HALF the TIME
compared to YOU using Wiss shears AND my piece will be STRAIGHTER and more
'factory' looking than yours. That simple. It is much less time consuming
when you consider YOU are making 2 cuts, being extra careful on the second
pass, and then the time you take trying to carefully remove the teeth marks.
And then, you think you can cut 1000 millimeters as straight with your hands
as my straightedge ruler? No way! But this is only for those of you who
are in a hurry AND want professional looking cuts everytime.
I took this a step further when I had to cut the flaperon slots in the
fuselage side... I drilled two holes of proper size to define the ends of
the arc... then used a compass to draw the curves that connect the holes for
both edges of the slot (20mm wide) on a scrap piece of .025 ... I used my
WISS (!) to cut out this scrap curve of metal and placed this metal scrap on
the fuselage connecting the two holes I drilled and used this as a guide to
drag my OLFA cutter... (hope this is clear) Anyhow.. I was able to have
beautiful arc cuts that have no ripples, stretch, or teeth marks. No
dremels, nibblers, shears, etc (I remember my first plane!) Very little
deburring to remove the sharp edge.
Well you have read ENOUGH of this dribble... I have no financial interest in
OLFA but thought Id let you know that this was one rude awakening when I
realize the rest of my plane COULD have been a lot BETTER if I had known
about this technique a LONG time ago.... There is a demonstration by Dave on
the Scratch Building video of how the OFLA is used... you dont need to watch
this to figure it out... and I do have a financial interest in the video so
I dont want to lead you in that direction... but in case I felt strongly
about something I might put this cutting technique on the list of truly
invaluable tips that make you say "DUH I should have known about this a LONG
time ago"...it kind of makes you a craftsman without the effort... because
it is more of a 'knowledge' thing than a skill thing...
OK, enough.
Thanks DAVID Barth
frank.hinde(at)hp.com Guest
rjscep(at)yahoo.com Guest
Posted: Wed Apr 26, 2006 9:35 am Post subject: Thanks for all your ideas on cutting Aluminum |
| Quote: | I have another idea to throw to all sctratch
builders
| Quote: | I have been involved with other aluminum aircraft.
Most of the builders when laying out their parts on
the sheets, draw the lines directly on the sheet.
I have been using a different method. I bought some
white contact paper, peeled it, have to careful not
to cut large pieces, I used long strips and layed
out
| Quote: | the lines to be cut on a shear or by hand. The paper
protects the the aluminim from any scratches, it
also
| Quote: | can be on there for many years without adhearing to
the metal. I have had previous experience with the
paper and have not had to struggle getting it off.
Also if you want to cover the whole part, that's no
probelem, it will peel off without any trouble.
Its very good for marking with a ball point pen. It
leaves no dents either, in the metal. Happy building
Bob S.
--- AZFlyer <millrML(at)AOL.com> wrote:
Mike Miller (at) millrml(at)aol.com
601 XL, 3300
Remember: "the second mouse gets the
cheese"!
http://forums.matronics.com/viewtopic.php?p=30860#30860
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
bjohnson(at)satx.rr.com Guest
Posted: Wed Apr 26, 2006 9:50 am Post subject: Thanks for all your ideas on cutting Aluminum |
David,
Is this the one???
<http://www.aaaindustrialsupply.com/index.asp?PageAction=VIEWPROD&ProdID=598
" OLFA Cutter Heavy Duty P-800 Model 5012- 710041
OLFA Cutter Heavy Duty P-800 Model 5012 Produces A Very Fine Score Line To
Allow Precise Breaking Of Plastics And Laminates."
The above link has them for $8.48 free shipping over $25... hrm, I wonder
what other tools I might need from them <grin>
-Bruce Johnson
Scratch Building a Sonex near San Antonio, TX & still have a LOT of sheet
cutting to do!!!
[quote] --
Posted: Wed Apr 26, 2006 9:53 am Post subject: Thanks for all your ideas on cutting Aluminum |
I think I knew an Olga... she had a sister...
But the OLFA model is P800... you're right in that they have lots of models
out there. And dont bother getting extra blades if you're just cutting
alumimum.. it comes with extras and they dont seem to wear out!
It IS a wild experience when you make your first cut... you'll say WOW!
Posted: Wed Apr 26, 2006 10:13 am Post subject: Thanks for all your ideas on cutting Aluminum |
Yep,
Thats the one... and les than $9 bucks! I have yet to find a popular chain
store in the states that carries it. But even if it costs $5 for
shipping... go for it! Save gas!
David,
Is this the one???
-Bruce Johnson
randy(at)shadycreekoutlaw Guest
Posted: Wed Apr 26, 2006 11:51 am Post subject: Thanks for all your ideas on cutting Aluminum |
Wished I'd knew this a few days earlier... I just ordered and received a
Olfa P-800 today... with 6 spare blades!
Randy
N344RB
Posted: Wed Apr 26, 2006 12:03 pm Post subject: Thanks for all your ideas on cutting Aluminum |
I'm hoping you're right on the Olfa knife... I received 2 knives and 6
extra blades today, that I ordered last week...
Randy
N344RB
Jari Kaija
Posted: Fri Apr 28, 2006 3:54 am Post subject: Thanks for all your ideas on cutting Aluminum |
Just wondering. Do you guys ever TRY to use JUST a good
"Kitchen scissors". Works better than great with .016 aluminium
http://www.project-ch701.net/ch701_wings/big_wingf100.jpg
I don't know about u-state, but in here, in Finland we have a
good factory, what produces sharp and strong scissors. Called
"Fiskars"
http://www.jarikaija.com
nfivesl(at)yahoo.com Guest
Posted: Fri Apr 28, 2006 4:42 am Post subject: Thanks for all your ideas on cutting Aluminum |
Here in the U-States we have a store called Wal-Mart
that sells Fiskers and all sorts of foreign-made
goods.
Scott (Do Not Archive) Laughlin
--- Jari Kaija <jari.kaija(at)pp.inet.fi> wrote:
| Quote: | I don't know about u-state, but in here, in Finland
we have a good factory, what produces sharp and
| Quote: | "Fiskars"
Do You Yahoo!?
Malcolm.HUNT(at)networkra Guest
Posted: Fri Apr 28, 2006 4:43 am Post subject: Thanks for all your ideas on cutting Aluminum |
Jari
May work great but don't get caught using the wife's scissors.
Best Wishes
Malcolm
Do not Archive
dougsire
Posted: Fri Apr 28, 2006 7:20 am Post subject: Thanks for all your ideas on cutting Aluminum |
I once bought an Uffda knife at a Norwegian craft show. Would that work?
Doug Sire
601XL
_________________ Doug Sire 601XL
Do Not Archive |
