Z-32 Question
jonlaury
PostPosted: Wed Jul 21, 2010 5:17 pm    Post subject: Z-32 Question Reply with quote
If the feed wire from the main batt bus to the relay is protected by the 10a fuse, why is it marked " * " ?
PostPosted: Wed Jul 21, 2010 7:17 pm    Post subject: Z-32 Question Reply with quote
Because the 10A (or larger) fuse exceeds the legacy
rule-of-thumb for protection size of long, always
hot feeders. Hence the alternate feed source "mini-
contactor" and a short feeder between that contactor
and the battery bus.
jonlaury
PostPosted: Thu Jul 22, 2010 8:53 am    Post subject: Re: Z-32 Question Reply with quote
Bob,
OK, got it.
But now that begs the question of why there is a fusible link between the Ebus and Alt Feed Switch in Z-13/8 and not one in Z-32 between the contactor and Ebus?
Also, would you comment on my attached schematic (disregard pg 2)? In particular your thoughts on using the GP contactor as a contactor for Alt # 2.
Is there a prohibition of having both alternators online simultaneously?
Thank you,
John
Z13-8Q MINE w-40a contactor.pdf
 Filename:  Z13-8Q MINE w-40a contactor.pdf
 Filesize:  498.25 KB
 Downloaded:  341 Time(s)
jonlaury
PostPosted: Thu Jul 22, 2010 8:59 am    Post subject: Re: Z-32 Question Reply with quote
Bob,
I missed your response to "Corrected Electrical Schematic" so disregard that part of my last post on this subject.
J
