sprejean(at)sbcglobal.net Guest
Posted: Thu Jul 22, 2010 7:51 pm Post subject: Yak 52 Forward Mag Switch Problem |
After being down for repairs for more than 18 months, the forward magneto switch no longer grounds the magneto P-Leads. The aft unit works find and it had to be used to test the mag drop and shutdown the engine during its initial test run. The forward would do neither. Has anyone experienced this problem or have a schematic?
Steve Prejean
Posted: Fri Jul 23, 2010 3:37 am Post subject: Yak 52 Forward Mag Switch Problem |
Check to make sure the toggle switch next to the gear selector in the rear cockpit is in the UP position. See in attached small photo. The tabs on the sides of the switch are squeezed together in this photo.
Dennis
| Description: |
| Filesize: |
10.85 KB |
| Viewed: |
1772 Time(s) |
