Discover
Posted: Mon Jul 19, 2010 6:44 am Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Gary,
In reference to Arjay's email copied below.
I've discussed the testing you mentioned to me some time ago with several people. That is your temperature testing of the air in the induction where you found no heating from the cylinders at cruise speeds.
I just wanted to confirm that I remembered your results correctly. That is you found no increase in the air temp from the cowling entrance to the induction entrance at the rear of the baffles. That is correct right?
I would wager that the NACA used in LoPresti design actually yields a lower manifold pressure than the stock induction and not any cooler temps. It is well known and recorded in the NACA literature that a NACA scoop is a very poor design for use where RAM is desired such as in an induction where it was shown that up to 30% pressure loss occures.
I own both a LoPresti nose bowl and a Jaguar Cowl. I purchased the LoPresti years ago when it was the only option. I also owned another Tiger with the LoPresti.
I did a lot of researching other owners of the LoPresti and found that all but one found no speed increase. Most said that the engine temps were lower and more even. One person Stu Morse, who is a racer, who, although he did not have just before and just after numbers, thought the LoPresti added 2 or 3 kts and helped in cooling both CHT's and oil temps. Glen Hadley who's Tiger I owned did have before and after flight tests and said he found no speed increase but also said cooling was improved.
Just to be clear, there really is no common ground between the LoPresti nose bowl and the Jaguar cowling. They are 2 completely different things and the LoPresti in no way comes even close to the benefits of the Jaguar. One of the things I like about the Jaguar is that it retains the stock induction location. I had already proven that this is good for 3/4 - 1" of manifoild pressure increase over the stock AG5B location.
From all the flight testing I have done over the years I have learned that it is quite difficult to repeat flights with the same conditions. It is also difficult to quantify 2 or 3 kts difference in speeds due to mods.
I think I will utilize my EI engine scanner and place probes at the entrance of the cowl and at teh entrance of the induction just to confirm what Ithought you had told me about these temps. I'll report back with the results.
Your Fellow Grumman Enthhusiast,
Ned
teamgrumman(at)YAHOO.COM Guest
Posted: Mon Jul 19, 2010 9:13 am Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Ned,
When I measured temps at the inlet to the airbox on the back of the #3, I found the temps to be within a degree of ambient. I found no excessive heating of the air. Certainly not 20 degrees. Unless the plane is sitting still with the engine running.
As for the NACA flush inlet, a couple of things. First, any energy in the air is totally lost when it slams into that wall at the end of the inlet, makes an abrupt 90 degree turn and goes straight up and then through 3 or 4 feet of rough SCAT tubing, building a boundary layer the entire time, and then into the airbox. Second, the goal is to bleed off any excess air coming into the engine that isn't being used to cool the engine. Which brings up CHTs.
You'll always see higher CHTs on #1 than the others during climb. That was done intentionally. The inlets are not symmetric, left to right. Subtle, but different.
Your CHTs will not be that good with a richer mixture unless you can use the early carb. Yours has different jetting to compensate for the dual airboxes on the AG.
As for airspeeds, I see 2 to 3 knots variation depending on how it's trimmed.
Like you, I have never talked to anyone who has seen an increase in speed with the LoPresti nose-bowl. The improved CHT #3 temps is due to the ramp on the right inlet.
The best location for the inlet hasn't been tried yet. Stay tuned.
Gary
Sent: Mon, July 19, 2010 7:45:53 AM
Subject: Re: TeamGrumman-List:LoPresti Nose Bowl Performance
Gary,
Ned
n2_narcosis(at)YAHOO.COM Guest
Posted: Mon Jul 19, 2010 3:46 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Again, being new to this list and tiger ownership I have a couple of questions. Is the Jaguar cowl the cowl that Gary at AUCountry working on? I can only assume it is STCd by now. if not, what is the Jaguar cowl, and will it fit on stock 76 Tiger.
Brock
Date: Monday, July 19, 2010, 9:45 AM
Gary,
Ned
flyv35b(at)minetfiber.com Guest
Posted: Mon Jul 19, 2010 4:35 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
It's finished, is STC'd and will fit on a 76 Tiger. Gary has the data but I haven't seen it published. It is a definite improvement in both cooling and speed.
Cliff
ArjayS(at)AOL.COM Guest
Posted: Mon Jul 19, 2010 5:07 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Hi Brock
The Jaguar cowl is indeed what Gary at AU Country is working on. It's a very nice looking cowl. He's been at it for ten years now. There are no final performance figures or prices yet but I think he selling the first units for about eight thousand. (You would need to check with him). I do not believe it's certified yet but he's got to be very close. I think Cliff may have one of his first units. They are both nice guys.
As far as convincing Cliff of anything, I kinda don't think that's possible for me. I'm retired from Apple computer, I was one of the original Mac designers. I mention this because for some reason folks take the Mac vs. PC as almost a religious issue. (Which makes as much sense to me as defending your purchase of a GE toaster instead of a Sears.) It looks like many folks in aviation take the same stance about their "beliefs". I have four engineering degrees generally because I'm a nerd but mostly because I'm curious. I have a little bit of both knowledge and experience when it comes fluid dynamics and thermodynamics but I do try to keep an open mind. However, when you meet someone who comes to the table with a set belief, then the only thing you can do is be polite.
Or look at it this way. Maybe, I'm completely full of beans. So instead of listening to me, let me send you to lots of LoPresti customers who have our products and feel they work equal or better than advertised. Probably the most famous is Greg Amy and his gorgeous Tiger. He says he gets in the low 140+ knots and loves the look and cooling.
http://www.gatm.com/flying/feedback.html
OR maybe a 100% money back guarentee is enough. Dunno...
Either way it takes the look of the Tiger out of the late 1950's and that alone is a good thing.
Just my 2 cents!
Thanks!
Rj Siegel CEO/LoPresti Aviation Engineering [quote][b]
Posted: Mon Jul 19, 2010 5:12 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
It isn't published because then I'd have to do a whole bunch of performance testing to verify the improvements. Then, I'd have to change the POH. Then, I'd have to do a supplement. Then . . . .
I just did the cowling for cooling reasons.
At 1000 MSL, if I push my plane, I can true out at 158 to 160 knots. It will comfortably go at 150 knots all day.
Sent: Mon, July 19, 2010 5:26:26 PM
Cliff
Posted: Mon Jul 19, 2010 5:23 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
COOL! As far as publishing the results, I agree, it's a GIGANTIC pain and it never ends.
Rj
| Quote: | It isn't published because then I'd have to do a whole bunch of performance testing to verify the improvements. Then, I'd have to change the POH. Then, I'd have to do a supplement. Then . . . .
pic
Cliff
1.35 MB |
8388 Time(s) |
Posted: Mon Jul 19, 2010 5:40 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
The Jaguar cowling was approved a year ago. There are 4 out there flying, including mine. Average speed increase is 5-6 knots.
As for the $1000/knot myth, that was posted here a while back by someone other than myself, that was in pre-1970 dollars (before inflation). In today's money, it's about $2000/knot.
To: teamgrumman(at)YAHOO.COM; teamgrumman-list(at)matronics.com
Sent: Mon, July 19, 2010 6:15:26 PM
Rj
Posted: Tue Jul 20, 2010 1:32 am Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Gary and/or Ned and whomever is flying the Jag cowl, how much did your CHTs drop during climb and cruise? I am seriously considering the jag cowl as my old stock cowl is cracking. The plane is getting its annual(my first, ouch) and Fletch squawked it so at some point I either need to fix or replace and I really like the look of the Jag cowl.
Thanks Brock
--- On Mon, 7/19/10, Gary Vogt <teamgrumman(at)YAHOO.COM> wrote:
To: ArjayS(at)aol.com, "Teamgrumman List" <teamgrumman-list(at)matronics.com>
Date: Monday, July 19, 2010, 8:39 PM
Rj
st" rel=nofollow target=_blank>http://www.matronics.com/Navigator?TeamGrumman-List
Posted: Tue Jul 20, 2010 6:37 am Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Per Rj:
"I do not believe it's certified yet but he's got to be very close. I think Cliff may have one of his first units. They are both nice guys."
It is certified. No, I don't have one of Gary's cowls. In fact I don't have a plane that it would fit on. I have an O-320 powered AA-1C and a V35B Bonanza I fly when I want to go somewhere distant.
"As far as convincing Cliff of anything, I kinda don't think that's possible for me. I'm retired from Apple computer, I was one of the original Mac designers. I mention this because for some reason folks take the Mac vs. PC as almost a religious issue. (Which makes as much sense to me as defending your purchase of a GE toaster instead of a Sears.) It looks like many folks in aviation take the same stance about their "beliefs". I have four engineering degrees generally because I'm a nerd but mostly because I'm curious. I have a little bit of both knowledge and experience when it comes fluid dynamics and thermodynamics but I do try to keep an open mind. However, when you meet someone who comes to the table with a set belief, then the only thing you can do is be polite."
Actually, It's not that difficult to convince me as I have a pretty open mind I think. It just takes facts and actual test data or side by side comparisons. I suppose that my engineering background and 45 years experience in GA require that it pass the smell test as well. I started out asking a couple of pertinent questions, which really never were answered, just comments about come down here and we'll show you the proof or at least wine and dine you. And as far as asking people who have purchased your products (nose bowl) I have learned that those kinds of testimonials are not necessarily totally unbiased. After all it's kind of hard to admit you spent thousands of dollars on a product doesn't do what it claimed. The best analysis comes from someone who doesn't have a dog in the fight and truly is totally unbiased. And independent analysis such as Aviation Consumer does holds more water so to speak.
BTW, what does Apple vs. PC computers have to do with this conversation?
Cliff A&P/IA
Posted: Tue Jul 20, 2010 10:53 am Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
I don't think that either I nor Ned are the right ones to ask. We usually firewall the throttle and leave it there. On a JPI, I can easily push 470 degrees in a 1000-1500 fpm climb from 2500 feet to 4000 feet turning 2500 rpm. Straight and level at 2500 feet, leaned to max power, and WAY over redline, I can do the same.
Jeff and Martin, on-the-other-hand, the other two owners, are typical flyers. Both (with JPIs) show 360 to 380 in cruise and rarely go over 420 in a climb. #1 CHT will peak first in a climb; it's designed that way. In cruise, it's very close to the rest.
Sent: Tue, July 20, 2010 2:31:56 AM
Thanks Brock
Rj
Discover
Posted: Tue Jul 20, 2010 12:09 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Hi Brock,
I'm still flight testing the Jag cowl but I am getting some data points that I think are reliable.
As far as cooling performance of the Jag cowl I am finding a gain of 25 to 30degF in cooling of the CHTs. I run LASAR which is known to cause CHT's to run 30 -35 degF higher than stock. I always run WOT with an MT constant speed prop and always lean to best power and turn the RPM for best speed. Last year while racing I typically saw CHT's in the 380 range. Recently, while flight testing the Jag cowl I have been seeing CHT's in mid 350's. This for a DA of 4500'.
On my flight home from California in April after installing the Jag cowl I had rather higher than normal CHT temps. I found that the under cylinder baffle safety ties (normally springs) were broken and I believe this was why I saw the higher than usual temps. This info for those that have followed my emails concerning the Jag cowl.
For climb I really cannot give you a good data point from my flights for comparison as I usually use mixture to keep CHT's below 400 in climb.
Know that Gary uses JPI and I use EI and Gary has determined that JPI reads 70degF higher than EI. So when Gary says his CHT is 470 that is the same as my CHT reading 400....
I'm still working and flight testing to determine what speed gains the Jag may have given my plane. I do think there is a speed gain and will give those numbers when I have good repeatable flight test data to share.
If you have a stock cowl there are a number of things that can be done to increase cooling. But the Jaguar cowl is really an excellent way to upgrade a Tiger. It looks really good and I think you will find both cooling and speed benefits in addition to bringing the look of the plane into the 21st century.
The LoPresti is NOT a cowl. It is a nose bowl and not a cowl. If you need a new cowl the LoPresti won't replace your old cowl.
Another thing to keep in mind is that with the Jaguar cowl you get ALL NEW baffles and baffle seals. And Gary did an excellent job designing these new baffles so that they seal very well. Most old Tigers are in need of this.
Here are some links to pictures of a completed Jaguar Cowl installation:
http://web.mac.com/jkeesaman/N1976T/N1976T_Returns_Home.html
http://web.mac.com/jkeesaman/N1976T/Cowling_Spy_Photos%21.html
Your Fellow Grumman Enthusiast,
Ned
Posted: Tue Jul 20, 2010 5:32 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
Wow, I am in trouble. My plane has a single EI CHT probe on number three and was seeing CHTs in the 440s on climb. That would be 510 on the JPI!!! The plane is still at Fletch's. I might have him do some cowl mods until I can get a new cowl.
Brock
Date: Tuesday, July 20, 2010, 3:11 PM
Hi Brock,
Discover
Posted: Tue Jul 20, 2010 5:47 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
The bottom line of the JPI EI 70 deg spread as it was discussed a few years ago was that Lycoming probes were like the EI probes so that the EI temps or the JPI minus 70 temps are what should be used when comparing to Lycoming limits
As far as you being in trouble I would agree that 440 is too high although it is within Lycoming limits
There are several things that should be looked at on your cooling system and perhaps your mixture in the carb
Sent from my iPhone it gin
On Jul 20, 2010, at 8:31 PM, Brock Windsor <n2_narcosis(at)YAHOO.COM (n2_narcosis(at)YAHOO.COM)> wrote:
[quote]Wow, I am in trouble. My plane has a single EI CHT probe on number three and was seeing CHTs in the 440s on climb. That would be 510 on the JPI!!! The plane is still at Fletch's. I might have him do some cowl mods until I can get a new cowl.
Brock
To: [url=mailto:teamgrumman-list(at)matronics.com]teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)[/url]
Hi Brock,
Ned
Posted: Tue Jul 20, 2010 8:47 pm Post subject: TeamGrumman-List:LoPresti Nose Bowl Performance |
First, before you panic, what kind of probe are you using? Under the spark plug? What shape are the baffles in? Send pictures. A single probe is really quite useless. It could be wrong.
Sent: Tue, July 20, 2010 6:31:54 PM
Brock
Hi Brock,
Ned
