tc1917(at)hughes.net Guest
Posted: Wed Apr 26, 2006 3:07 am Post subject: soldering |
I would like to add something to the 'solder the end of the cable to keep it
from slipping through the nico' discussion. I have been building and flying
RC models almost forty years and have built several large models. WWI
planes have cables and you have to figure a way to replace them or repair
them in the field usually. I have crimped, swedged, screwed and soldered
and one thing came out clear. If you heat a steel/SS cable even to solder
it, it seems to lose its ability to flex and will become brittle and break
upon bending. I just want to add this. I ALWAYS use two nicos -- both done
perfectly -- which adds to the redundancy and I NEVER have to worry about
them. I use the two bolt swedge unit from Aircraft Spruce. Tough to use at
times but well worth the time. The big trick is make SURE you have the
swedge tool centered so it does not squeeze the cable at the end of the
nico. It will bell out at the ends very nicely. If it is not done right,
carefully use a dremell cutting tool and cut it in half and start again.
Done that many times. After all, it is ONLY your life that depends on it.
Oh, yeah, watch out you dont have a bow in one of the cables between the
nicos. Take your time and do it right and you will live forever until you
die. Ted Cowan. Alabama. By the way, Beverly and I are having an
Ultralight get to gether on June 10 again this year. All are welcome.
Camping available. For info go to: www.airnav.com AL51. Contact me off
list for further info. Also info at: www.homestead.com/southernflyers at
the events section.
George Alexander
Posted: Thu Apr 27, 2006 4:06 am Post subject: Re: soldering |
MAY BE A DUPLICATE RESPONSE... but anyway
Although nico sleeves weren't involved, from a personal experience, I would like to support what Ted said about heating the cable.
In my case, the throttle cable was heated and solder applied to keep it from slipping through the connector to the throttle lever. The good news is that it snapped, on the ground, as part of my regular preflight. (Open the throttle to full and close it listening for the infamous "click" of the slides as they return home. They certainly clicked this time when the cable let go and they went home in a hurry!)
On examination, there was noticeable discoloration from the point that was soldered, back about 1". The general consensus, of those that examined it, was that the break was caused by the effect on the cable of the heat application. (The failure may have been accelerated by the humid conditions here in FL.) The cable actually rusted through. Miffed that I didn't see the rust before it broke. Some of the discoloration/rust protruded from the connector enough to be seen. Conceptually a good idea, with not so good results.
| tc1917(at)hughes.net wrote: | I would like to add something to the 'solder the end of the cable to keep it
<<<<SNIP>>>>
If you heat a steel/SS cable even to solder it, it seems to lose its ability to flex and will become brittle and break upon bending. |
_________________ George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net |
biglar
Posted: Thu Apr 27, 2006 5:49 am Post subject: soldering |
I'm coming into this late, and don't want to step on any toes, but I've had
considerable experience with soldering, and some with cables. Here's a few
thoughts.............
As Chief Engineer of the hotel I work at, an un-enviable part of my job is
to teach others some of my skills, one of which is soft soldering. (I also
teach them silver soldering and gas welding, but that's another ulcer
building story)
Soft solder melts easily, at something around (I think) 500 F., just barely
enuf to make the metal change color. Almost without exception, even with
practise, almost everyone will heat the metal too much. Far too much. My
guys drive me crazy with this. They'll burn the flux almost every time,
even with me telling them, "Enuf, Enuf ! ! !" Practise on copper tubing.
Steel wool, wire brush, or emery cloth it till shiny - both male and female
surfaces. ALL surface contaminants MUST be removed. Coat the surfaces
lightly with a flux. Heat the joint gently with a propane or mapp torch in
the area you want the solder to flow to. It will flow TO the heat. As the
area warms up, start scratching the surface with the solder stick. Soon it
will start to leave streaks of silver on the surface. Just a little more,
and the solder will suddenly flow into the joint. STOP HEATING at this
point. A little more - repeat, a little more - heat and solder will smooth
and fill the joint. If the flux turns black, you got it too hot and you
will NOT make the solder stick. It'll just make beads. Take it apart and
start over.
OK, wire..........much tougher, but do-able. I've found it best to
carefully unwrap the strands and clean them with a solvent, even steel wool
them, re-wrap them, then flux and solder. Great care must be taken, since
individual wires will heat almost instantly and others won't. Some will
glow red hot quickly, and then won't take the solder. I've done this
successfully - sometimes - on motorcycle cables, and other times not. Many
factory cables are (or at least were, in my day) soldered. Would I trust
this on my airplane ?? Nope. Too iffy for my skill level. Properly done,
yah, probably. Once again, almost everyone uses far too much heat, which is
what ruins the cable. Take it easy. Clean parts are everything.
When I was a logger, we'd make up choker cables on the spot by sliding the
bell over the cable, then inserting a tapered, fluted steel wedge into the
end of the cable to spread the strands. Then smack the bell over the spread
strands at the end and they were locked solid. Strong ?? Yah, they'd take
the slam of a D6 Cat hitting the end of them when hooked to a tree to be
skidded to a landing, and do it repeatedly, day after day. Do they make
small enuf bells and wedges to fit these small cables ?? I dunno. Never
seen one, but a fairly handy person may be able to make one. Maybe solder
it in ?? Lar.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
Posted: Thu Apr 27, 2006 5:58 am Post subject: soldering |
I've had extremely good luck with the throttle cables that come with
Kolb Kits. Never had to solder one.
KISS (keep it simple)
_________________ John Hauck
Titus, Alabama |
Posted: Thu Apr 27, 2006 7:03 am Post subject: soldering |
Kolbers,
I have had good luck with tandem bicycle de railer cables. The are super
long, inexpensive, and can be found with a Teflon coating. I believe they
are a little smaller in diameter than the Kolb throttle cables. You have to
reduce the diameter of the lead bead so that it will fit into the throttle
slide. It may be possible to drill out the retaining hole to accept the
non-modified bead.
I have had more problems with the other end. I clip them off square and try
to not frazzle them. Then I use a soldering iron and rosin core solder to
solder the cut end cable strands together. After this is done, I wick a
drop of crazy glue up next to the soldered end. This stabilizes the cut end
so that one can pull the cable for cleaning and re-lubrication, and
re-insert the cable with little trouble. Before I did this, the frazzled
end made it very difficult the thread the cable from the engine to the
throttle and to get the end in the small clevis hole.
I believe using an iron helps with heat control so that you do not over heat
the cable. I do not believe one should use acid flux, as it likes moisture
and will keep eating away at the metal over a period of time.
Jack B. Hart FF004
Winchester, IN
HShack(at)AOL.COM Guest
Posted: Thu Apr 27, 2006 7:43 am Post subject: soldering |
In a message dated 4/27/2006 8:08:14 AM Eastern Standard Time,
gtalexander(at)att.net writes:
No expert here, but to solder the cable, you may apply flux or use acid core
solder. When the cable is heated, the flux migrates up the cable. That acid
or flux is corrosive to steel.
Perhaps if rosin core solder was used.....
Howard Shackleford
FS II
SC
rsanoa
Joined: 10 Jan 2006 Posts: 71 Location: Bell Buckle,TN
Posted: Thu Apr 27, 2006 8:34 am Post subject: soldering |
In my humble opinion, one should NEVER use any flux on the cables except resin. At the same time, with me a big no-no is never heat them with a torch, but a medium heat soldering iron. I have soldered many cable ends, and other sensitive wires,etc. using this combination. Then when finished, brush the area with alcohol. Have never seen any change in strength or evidence of corrosion.
Ray
UltraStar Tenn.
Howard Shackleford
FS II
SC
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
_________________ Ray S.Anderson |
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Thu Apr 27, 2006 8:56 am Post subject: soldering |
=0D
=0D
| Quote: | end of the cable to spread the strands. Then smack the bell over the
spread=0D
| Quote: | strands at the end and they were locked solid. Strong ?? Yah, they'd t=
ake=0D
=0D
Use a soldering iron. The kind that goes on a propane torch works great.
Keep the flame small & the iron clean & tinned. Use only resin for flux.
Have the cable ends secured in an upright condition & slightly spread. Wi=
pe
a very small amount of flux on the ends. Put the solder on the tip & let =
the
solder heat the strands. Don't touch them with the iron. The solder will
heat & tin the strands. Apply the solder to the iron, not the cable. Clea=
n
thoroughly with alcohol then rub in grease. woiks liika charm.=0D
George
George Myers
Posted: Thu Apr 27, 2006 9:51 am Post subject: soldering |
maybe this is easier to read
| Quote: | end of the cable to spread the strands. Then smack the bell over the spread
Have the cable ends secured in an upright condition & slightly spread. Wipe
a very small amount of flux on the ends. Put the solder on the tip & let the
heat & tin the strands. Apply the solder to the iron, not the cable. Clean
George
