klaus.dietrich(at)oracle. Guest
Posted: Tue Jul 13, 2010 9:41 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
after 10 years in service and some 800 hours with as many landings, my Landing Gear Retraction Lever Strut (Mod 51) had an oval oversize hole at the bottom end (14mm; for the MS 20392-5C37 bolt which is 9,5 mm) and it finally broke at the top (just below the AN 3 bolt probably due to some misalignment due to the play at the bottom...
no play at the top AN 3 bolt, however!
The three screws on the Landing Gear Retraction Lever at the top seem to hold (no play)....
I'm still searching for an explanation; my aluminum angle was probably not strong enough: material thickness: 1,5 mm; L-profile: 20 mm x 8 mm
also the strut is not absolutely straight and there is some sideways flexibility which may have favored the play...
Klaus
davidjoyce(at)doctors.org Guest
Posted: Tue Jul 13, 2010 1:53 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Klaus, Mine has gone exactly the same way. I have removed it and am relying
on the original three bolt joint with the two levers also bonded together. I
am also avoiding trailing the plane with the wheel locked in the up
position. Seems fine! Regards, David Joyce, G-XSDJ
budyerly(at)msn.com Guest
Posted: Tue Jul 13, 2010 4:23 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Klaus and others,
Please send me pictures of your elongations or failures of the strut for me to analyze. If you can provide the type material and thickness also.
Normally 6061 common aluminum angle of 1.6 mm or 1/16 inch is plenty strong enough.
Elongation of the hole at the bottom indicates slight movement of the gear lock ,retraction mechanism (most probably in the down position) due to not staying perfectly vertical with the gear down and eventually the stresses from bending, as Klaus said, or from the latch slot gear retraction arm interface bending, and or the three bolts elongation has caused fatigue of the material or too much force on the aluminum angle strut.
We will need some look see time to evaluate should if we go to steel or a specific material/dimensions, time change, or what.
In the mean time, if everyone can look at their Mod 51 landing gear retraction lever strut brace if over say 500 hours and look for wear, as soon as you can, and low time planes on your next annual, then send me updates, I'd appreciate it.
Many thanks,
Bud Yerly,
Europa Tech Assistance.
direct email: budyerly(at)msn.com (budyerly(at)msn.com)
or just hold control key and click below to email
via Europa website: mailto:enquiries(at)europa-aircraft.com (enquiries(at)europa-aircraft.com)
via Custom Flight Creations website: mailto:mail(at)customflightcreations.com (mail(at)customflightcreations.com)
rehn(at)rockisland.com Guest
Posted: Tue Jul 13, 2010 5:20 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Bud
I have not installed Mod 51 and have been flying with lots of landings for 10 years, am I living dangerously? I check the gear and don’t see issues but am I missing something? Am I the only one with out Mod 51?
Jerry
Mono 914
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bud Yerly
Sent: Tuesday, July 13, 2010 5:17 PM
Subject: Re: Check your Landing Gear Retraction Lever Strut (Mod 51)
Klaus and others,
[b]In the mean time, if everyone can look at their Mod 51 landing gear retraction lever strut brace if over say 500 hours and look for wear, as soon as you can, and low time planes on your next annual, then send me updates, I'd appreciate it.[/b]
Many thanks,
Bud Yerly,
Roger.Mills(at)btinternet Guest
Posted: Wed Jul 14, 2010 2:38 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
In my experience the danger is when you trailer the aircraft on a belly dolly with the Monowheel locked in the retracted position (although flying through prolonged choppy turbulence at 120kt might not be far behind?). The forces applied by the heavy weight of the wheel/tyre and long moment of the undercarriage arm when driving over potholes and other road surface problems are significant. Before fitting the strut I experienced significant distortion and elongation of the three holes through using a trailer with the wheel fully retracted just once and had to fabricate a new landing gear lever.
I hoped the strut would fix the weakness but it’s conceivable that the forces involved in rough/turbulent air flight might elongate the bottom hole - will have to disassemble and examine now.
Roger Mills
G-BVUV
Posted: Thu Jul 15, 2010 1:49 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
I a sure Roger is right, and that is why I leave the wheel down when
trailering on a dolly. However I first had trouble when flying though some
severe turbulence in rotor in fairly high wind conditions in Welsh
mountains. I only discovered the problem when I came to put the gear down
and found that the joint had moved so that the gear lever stopped something
like a cm short of its 'Down' detent. The problem was solved by pulling very
hard on the lever and then giving my right fist a mighty thump with the
other one. Since then I disassembled the joint, packed it with blue sticky
mixture and reassembled it with mod 51. I have had no problem since in spite
of lots of turbulence and knowing that mod 51 was shot & useless for some
years. Regards, David Joyce, G-XSDJ
nigel_graham(at)m-tecque. Guest
Posted: Thu Jul 15, 2010 3:00 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Gents,
This problem was identified a long time ago (1999) and one enterprising Scandinavian builder came up with an elegant and well engineered solution (stand up and take a bow - Jens).
Pictures below FYI.
Nigel
[img]cid:8600810E0D8C4FA1B4390566FD2283FD(at)hurricane[/img][img]cid:AAF62BA6396743B1A7A19B25D929BDD3(at)hurricane[/img]
88.78 KB |
15949 Time(s) |
91.38 KB |
15949 Time(s) |
fklein(at)orcasonline.com Guest
Posted: Thu Jul 15, 2010 5:59 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
On Jul 15, 2010, at 2:47 AM, David Joyce wrote:
| Quote: | knowing that mod 51 was shot & useless for some years. Regards,
David Joyce, G-XSDJ
David,
..t'would be enlightening to me if you could elaborate a bit on what
led you to this conclusion...
Fred
Posted: Thu Jul 15, 2010 6:44 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Fred I haven't got a picture to hand, but the bottom bit of the additional
strut is bent and the hole in the bottom is worn to a bigger diameter.
David
Posted: Thu Jul 15, 2010 4:28 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jerry,
You are not alone and not living dangerously, as it seems you have a well built reliable gear. However the non mandatory mod 51 arm helps keep the stress down on the three bolts in the retraction arm. Eventually, through trailering, rough air, rough airstrips and countless landings you may experience trouble. If the arm flexes at the connection to the LG08 it may be difficult to lower the gear and it may require you to unload the aircraft to near negative G to flop the gear handle out of the slot. On takeoff, you may find that the gear will not lock up properly. Extending the gear may leave the LG08 mechanism at less than vertical. Looseness at this joint will progress rapidly through normal use as the gear has no over center lock per say and will bend at its pivot points slightly both up and down, exacerbating the problem.
Even with mod 51, if the gear is not perfectly vertical from LG8 down, the gear handle takes the load. That dog leg in the gear handle with the bends will flex over time, causing a higher than anticipated tension load on the Mod 51 diagonal brace. We'll have a material and proper dimensions to use for the arm soon. We all used Home Depot aluminum on previous builds and I should have questioned it, but I fly a trigear and rarely get a monowheel of significant age in the shop. No one reported the problem so it was unknown to me until now.
I would recommend one look at his retractable gear carefully on his annual, and at 5 years or 500 landings do a full inspection and rebuild. Call me conservative in a liberal world, but the bushings and landing gear block take a beating and are never cared for (I hate that dirty hole..). All the retractable gear certified planes I have experience with require not just a retraction check but a complete check of the bearings and bushings annually, slop and play are defined in the maintenance manual for the aircraft. Why shouldn't we do the same thorough inspections and replace known wear points at a specific time to preclude future problems.
Klaus and I discussed time changing out the following:
At 5 years or 500 landings,
Replace the bungee.
Wheel bearings KLNJ 1 1/2 They are sealed bearings, and I haven't seen a failure but why wait until they break.
Brake pads (inspect caliper for corrosion)
Upper and lower bushings AIC 060816/AIC 060820. Inspect annually for play and replace if detected and replace at 5 years anyway.
Inspect Mod 51 arm for wear and replace as necessary
Inspect shock absorbers and rubber block. If it hops like a bunny, change the shocks, if it sits low, change the block. I don't know how low, low is, but the block is about 70mm on an empty mono, so if it has lost 10 mm in height since new, it probably needs replacing.
Look at the long bolts Euro 26 and pins LG 04 for deformation, replace as necessary
Change the outrigger legs, inspect the pivot points and the locking mechanism for corrosion and wear. Remove and replace as necessary.
Replace the outrigger tires/wheels if worn.
I do not have a checklist for how I check the mono gear for play, and frankly just look at the mechanics as I do not own one... I support the aircraft, push on the lower arm and watch the mechanism when down, especially the locking arm. Look at the LG 04 pin and support for cracks and wear. Any deformations of the gear requires replacement. Then partially retract the gear and check for play in the joints, wiggle the arms to check for play, and pivot points for play (nasty dirty job), and finally lock the gear up and check movement of the gear mechanism by pushing up on the gear and using my bore scope to see if there are problems. I have never removed the mod 51, but I have also never worked on a high time mono. As for the outriggers, I have to look at the book if I have to take one apart just to figure how to put it back together. I make sure that the gear leg locks down and that the flap moves through the proper number of degrees before unlock. I was not familiar with the Europa Club bushing mod many of you had on the outriggers until Jim Butcher led me through one. I have only seen the standard factory build. If there is a comprehensive checklist other than the FAA condition inspection, I'd like to see one for my own education.
Sorry to be so long winded.
Bud Yerly
Posted: Thu Jul 15, 2010 5:21 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Bud
Wow, thanks for a very thorough answer, I have a longer list for my next inspection.
Jerry
Sent from Iphone
On Jul 15, 2010, at 5:26 PM, "Bud Yerly" <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote] <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Jerry,
Replace the bungee.
Bud Yerly
hurstkr(at)redzone.com.au Guest
Posted: Thu Jul 15, 2010 11:34 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
FWIW, the attached photos depict what I have done. Photos were taken during
construction.
When the wheel is latched up, the undercarriage lever is free in the up
detent with no load on it whatsoever.
Kingsley in Oz
383.8 KB |
15925 Time(s) |
328.97 KB |
15925 Time(s) |
429.83 KB |
15925 Time(s) |
339.25 KB |
15925 Time(s) |
386.38 KB |
15925 Time(s) |
tonyrenshaw268(at)gmail.c Guest
Posted: Fri Jul 16, 2010 8:52 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
show off
On 16/07/2010, at 5:20 PM, Kingsley Hurst wrote:
| Quote: | FWIW, the attached photos depict what I have done. Photos were taken during construction.
When the wheel is latched up, the undercarriage lever is free in the up detent with no load on it whatsoever.
Kingsley in Oz
<Undercarriage unlatched.JPG><19mm Sealed bearing on side of suspension trailing arm.JPG><Latch Arm with makeshift spring.JPG><Undercarriage latched up viewed from below.JPG><Undercarriage Latched up.JPG>
Posted: Fri Jul 16, 2010 9:44 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Kingsley,
As you know, I admire your work...in this case, I admire your analysis
which anticipated the problem...of which I've been blissfully ignorant.
Do you have a pix of the pivot point along the side of the tunnel?
Fred
Posted: Fri Jul 16, 2010 2:28 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Good idea though !
Sent: Friday, 16 July, 2010 17:51:54
Subject: Re: Europa-List: Re: Check your Landing Gear Retraction Lever Strut (Mod 51)
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com (tonyrenshaw268(at)gmail.com)>
show off
Posted: Fri Jul 16, 2010 5:44 pm Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Go back to your burrow Renshaw ! <g>
| Quote: | > Do you have a pix of the pivot point along the side of the tunnel?
Fred,
Attached are the only two photos I have that may help.
I was a little fortunate with this project because I had at my disposal, the
drum brake actuator from a Blanik sailplane. The shaft that goes through
the bush has a spline on one end and a removable square piece on the other.
The arm you see attached to the spline is the original part off the
sailplane so all I had to do was extend it.
The alloy bush is home made of course and goes right through the plywood
stiffener.
I made square holes in the latch arm and the doubler to fit over the square
on the wheel well side and stuck it all together with glue. (to think I
didn't even know such stuff as Redux existed before embarking on the
Europa!!) The square piece is discernable in one of the photos in my last
post just below the split pin that wasn't split in the photo !
Twould be a breeze for you Fred !
Cheers
Kingsley
339.11 KB |
15902 Time(s) |
431.72 KB |
15902 Time(s) |
Posted: Sat Jul 17, 2010 3:36 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
Fred,
| Quote: | > As you know, I admire your work...
I have just realised how ignorant I was in not acknowledging your compliment
on the list.and I feel quite bad about it. It was a genuine oversight on my
part and I do apologise.
The fact that we have developed such mutual respect for each others
abilities means a lot to me and gives me a much better feeling than what I
have now in realising my misdemeanour.
Sorry mate.
Kingsley
Posted: Sat Jul 17, 2010 7:35 am Post subject: Check your Landing Gear Retraction Lever Strut (Mod 51) |
On Jul 17, 2010, at 4:35 AM, Kingsley Hurst wrote:
Fred,
compliment and I feel quite bad about it. It was a genuine
oversight on my part and I do apologise.
Pullease Kingsley...take off the hair shirt and burn it...I'm honored
to be considered an Aussie's "mate" on our shared Europa adventure.
Fred
