rparigoris
Posted: Mon Jul 05, 2010 8:55 am Post subject: Headset and mic shield question |
My 2 place Europa has a PS audio panel. I need to route shielded headset and mic wires out the port side of instrument module through a D-sub connector.
Curiosity question, what would happen if the shields were connected at the D-sub?
Thx.
Ron Parigoris
Posted: Mon Jul 05, 2010 10:09 am Post subject: Headset and mic shield question |
At 11:55 AM 7/5/2010, you wrote:
Quote: |
<rparigor(at)suffolk.lib.ny.us>
a D-sub connector.
at the D-sub?
What does the PS installation instructions say about
shielding? It should describe their recommendations
for terminating the shields. Do they use the shields
a part of the signal paths (i.e. grounds) or are they
simply shields over an array of wires? It makes
a difference and they should tell you exactly how
to do it.
For example, on page 1.10 of
http://www.aeroelectric.com/Catalog/AEC/9009/9009-700L.pdf
you can see examples of shield-only and shield-plus-signal
connections for shielded wires.
rparigoris
Posted: Mon Jul 05, 2010 12:16 pm Post subject: Re: Headset and mic shield question |
Hi Bob
I have a PS Engineering PMA 4000.
See:
Page #21:
http://www.ps-engineering.com/docs/PMA4000_IM.pdf
Each 2 or 3 conductor cable has the shield connected to a different pin on the 25 pinb P1 Bottom Unit Connector.
If pin 1, 2 , 6 and 7 were to touch each other at my D-sub connector, what trouble (if any) might that cause?
Thx.
Ron Parigoris
Posted: Sat Jul 10, 2010 5:10 pm Post subject: Headset and mic shield question |
At 03:16 PM 7/5/2010, you wrote:
Hi Bob
See:
Page #21:
None. All their shields are open at the far end, i.e.
only shields and not part of the audio path. "audio LO"
connections in virtually all such systems is a common
signal ground.
