jbr79r(at)yahoo.com Guest
Posted: Mon Jul 05, 2010 8:25 pm Post subject: stray RF |
Hi Bob
I have recently developed a problem when I transmit my VSI and other features on my Cheltons goes crazy. I have added a engine monitor EI MVP-50 recently. Is there a way to isolate the cause. This is a recent occurance No prior problem for 350 hrs
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Posted: Tue Jul 06, 2010 8:43 am Post subject: stray RF |
At 11:18 PM 7/5/2010, you wrote:
| Quote: | Hi Bob
A high-probability possibility is that a feed line
shield has become detached at one end or the other
on your comm antenna. A simple inspection may suffice.
An organized troubleshooting effort suggest you
dummy load the transceiver at the back of the tray
with a device like this:
http://aeroelectric.com/Pictures/Tools/RF_Antenna_Test_Tools/DummyLoad.jpg
See if the problem goes away. If so, then
move the dummy load to the other end of the
feedline. You'll need a male-male adapter, a
t-connector can be used too. Try again to see
if the problem goes away or is still there.
If the problem does not manifest with either
dummy load experiment, then it's likely that
something has changed in system conditions
for the Cheltons. But I'm betting it's a feed
line problem.
Posted: Tue Jul 06, 2010 9:28 am Post subject: stray RF |
Thanks Bob!!!!
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Tue, July 6, 2010 10:45:17 AM
Subject: Re: stray RF
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | Hi Bob
