temco(at)telusplanet.net Guest
Posted: Sun Jul 18, 2010 12:01 pm Post subject: LOP!! |
Vic
I think Lynn means Lean Off Peak --- which is his carb setting to get the
most efficient cruise. If it's not right he'll probably be on later and
correct the meaning of LOP.
Ted
Edmonton, Ab
Model IV/912
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Sun Jul 18, 2010 12:42 pm Post subject: LOP!! |
Thanks Ted,
Sounds right. Of course we with the humble Rotax 912 trust Bing to do the
job....
Vic
Vic Baker
S7 912S Warp
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
Lynn Matteson
Posted: Sun Jul 18, 2010 2:34 pm Post subject: LOP!! |
Ted-
Pretty close...it's "lean OF peak". And just for the record, I've got
a throttle-body injector, not a carb, but you're right...it's a
setting of the fuel mixture that makes the engine use less fuel and
allows cooler running, but make less power. It can only be used when
you have a throttle setting of about 65-70% power.
Lynn Matteson
Jabiru 2200, #2062, 1007.1 hrs (since 3-27-2006)
Sensenich 62"x46" Wood (summer)
Rotec TBI-40 injection
Status: flying...1000 hrs. plus...
On Jul 18, 2010, at 4:00 PM, Ted Palamarek wrote:
<temco(at)telusplanet.net>
Vic
get the
and
Ted
Edmonton, Ab
Model IV/912
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Sun Jul 18, 2010 2:38 pm Post subject: LOP!! |
Vic-
Bing does a fine job of "hands off" flying, but once you leave the
ground with a particular fuel mixture....according to whatever jet
and metering needle you have on board...that's about what you've got,
and you can't change it on the fly like you can with a mixture-
controllable throttle body injector (TBI), or other such fuel
metering system.
Lynn Matteson
On Jul 18, 2010, at 4:41 PM, Vic Baker wrote:
Thanks Ted,
do the job....
Vic
Vic Baker
S7 912S Warp
Carson City, Nv
N369LM |
Vic Baker
Posted: Mon Jul 19, 2010 5:05 am Post subject: LOP!! |
Lynn,
Sounds like the Rotec throttle body does a good job.
Thanks for the clarification,
Vic
Vic Baker
S7 912S Warp
Carson City, Nv
Series 7
