colind
Joined: 10 Jan 2006 Posts: 32 Location: Sydney, Australia
Posted: Wed Apr 26, 2006 2:57 pm Post subject: KF IV Windscreen |
Thanks guys. I apreciate the info.
I think I need to enlarge the cutout somewhat before I proceed.
Graeme - I'll take a few shots today and send them to you.
I haven't actually fired up the engine yet, but am close to that. I am
finishing off the radiator connections, and having a few problems plumbing
the connection between the right front cyclinder and the pump, as well as
the inlet to the pump which comes from the radiator. These two connections
basically point straight at the right rear exhaust pipe, which is only
about 5 - 6 inches away. Anyone else out there have any
suggestions/solutions on this problem?
I am also fitting a cabin heater that was included with the kit, but it's
a bit complicated, and there are absolutely no notes/instructions included
in the documentation I have.
Colin Durey
Sydney
+61-418-677073 (M)
+61-2-945466162 (F)
_________________ Colin Durey
Sydney
+61-418-677073 |
roncarolnikko(at)hotmail. Guest
Posted: Wed Apr 26, 2006 3:18 pm Post subject: KF IV Windscreen |
Colin I often look at the pics on Barnstormers.com or ebay to see how others
have done things. Do a search for kitfox at each site and you will find
some pics. Unfortunately there are no Kitfoxes with VW redrives around for
me to copy. Ron NB Ore
| Quote: | From: "Colin Durey" <colin(at)ptclhk.com>
Subject: KF IV Windscreen
Date: Thu, 27 Apr 2006 08:55:42 +1000 (EST)
Colin Durey
Sydney
+61-418-677073 (M)
+61-2-945466162 (F)
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Graeme Toft
Posted: Wed Apr 26, 2006 3:53 pm Post subject: KF IV Windscreen |
If you lived in Queensland you wouldn't need a heater. OOPs, sorry ,
couldn't resist a dig at the cockroaches.
Graeme
kerrjohna(at)comcast.net Guest
Posted: Thu Apr 27, 2006 7:16 am Post subject: KF IV Windscreen |
the tendancy is to try to fit the windscreen to tightly around the spar attach point. Relieving windscreen to match the spar is the minimum. You will be better served to look at the size/shape of the butt rib as just beyond the maximum, arriving there incrimentally.
John Kerr
Crazed Windscreen, 725 hours later
-------------- Original message --------------
Colin Durey
Sydney
+61-418-677073 (M)
+61-2-945466162 (F)
<html><body>
<DIV>the tendancy is to try to fit the windscreen to tightly around the spar attach point. Relieving windscreen to match the spar is the minimum. You will be better served to look at the size/shape of the butt rib as just beyond the maximum, arriving there incrimentally.</DIV>
<DIV> </DIV>
<DIV>John Kerr</DIV>
<DIV>Crazed Windscreen, 725 hours later</DIV>
<DIV> </DIV>
<BLOCKQUOTE style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">-------------- Original message -------------- <BR>From: "Colin Durey" <colin(at)ptclhk.com> <BR><BR>> --> Kitfox-List message posted by: "Colin Durey" <COLIN(at)PTCLHK.COM><BR>> <BR>> Thanks guys. I apreciate the info. <BR>> <BR>> I think I need to enlarge the cutout somewhat before I proceed. <BR>> <BR>> Graeme - I'll take a few shots today and send them to you. <BR>> <BR>> I haven't actually fired up the engine yet, but am close to that. I am <BR>> finishing off the radiator connections, and having a few problems plumbing <BR>> the connection between the right front cyclinder and the pump, as well as <BR>> the inlet to the pump which comes from the radiator. These two connections <BR>> basically point straight at the right rear exhaust pipe, which is only <BR>> about 5 - 6 inches away. Anyone else out there have any <BR>> suggestions/solut
ions o
mail L
