europa trailer height ?
rambug(at)gmail.com
PostPosted: Thu Jul 01, 2010 7:54 pm    Post subject: europa trailer height ? Reply with quote
Greetings everyone,
GREAT NEWS !  I am indeed acquiring N202Y, as Canada's MD-RA has given a green light for its import into Canada.
I now need to get my Europa shipped from Georgia to Montreal, which is about 20 hours drive away.
I have uship.com proposals to put the Europa monowheel trailer into an enclosed "car trailer", which has an internal dimension of 6'3", to get it from GA to the Canadian border.
Is this high enough ?
Are there any recommended extra straps to add to the Europa trailer to make sure nothing falls off ?
What is the weight of the Europa trailer ?
What size trailer hitch ball is supported on the Europa trailer ?
Anything else I should be worried about ?
Luc
P.S.: I decided it was better not to use the Europa trailer directly to ferry the airplane, as it is in an unknown state, and that I do not have proper registrations for it yet.  Also I am trying to avoid having road contaminants damaging the airplane.
raimo.toivio(at)rwm.fi
PostPosted: Fri Jul 02, 2010 2:51 am    Post subject: europa trailer height ? Reply with quote
Hi Luc
1) The highest point is a fintip + a possible strobo. When trailered, the tail wheel bottom distance to the ground is about 300 mm = 12 inches.
That means I think (imho) 6`3" is *just enough* and ok but when you pull Europa trailer into a car trailer you could lower the trailer´s front wheel even more if necessary or even take a front wheel away.
I would like to support it sideways to prevent all the movings.
I have a highly modified Europa trailer with double axle and the full floor. I assume it´s weight is around 350 kgs = about 770 lbs.
Original trailer would be about 250 kgs = 550 lbs.
Trailer hitch ball? My cars have an European standardized towing balls and it´s size /diameter is about 50 mm = 2".
I purchased my trailer from Germany - I cannot be sure does it have same female ball in the UK.
Drive carefully!
Towing the plane is the biggest risk to damage it!
Why not to fly it to Canada?
VERY good idea to use an enclosed trailer and a trailer inside anyway if you really had to tow it!
Check your Europa in every 60 miles or so!
How about you stay inside the trailer (inside the Europa!) a whole trip with continous radio or phone contact to the professional car driver?
Support your Europa well (sideways) to the trailer (otherwise your main gear leg is stressed more or less)!
Notice extra side supports (a pic)!
Notice to use wing safety film (a pic)!
Remember to lock the tailwheel to the trailer!
Remember to strap the Europa trailer well to the car trailer to prevent all the movings!
Do not ever never put your tailplanes to the Europa trailer - please pack them well separately (I have made a softened aluminium box like a huge suitcase for them)!
Notice the ball weight! You have to pull your trailer inside so that your prop is towards a towing car and tailwheel is behind to get a positive trailer hitch ball load - otherwise it is VERY dangerous!
When I am trailering, I use always an another car behind the trailer. So it is a two cars + a trailer formation. That is to prevent any other moving hostile object to come near or behind my trailer and to prevent possible following accidents. I know - I am almost a hysteric person - but I hate an idea to have a traffic accident with my Europa!
Attached a couple of my trailer pics (a floor was not installed during those days).
I hope this helps - good luck (drive carefully, again and keep the distance to the car you follow!
Terveisin, Raimo Toivio
Europa XS Mono OH-XRT #417 +150 hrs
37500 Lempäälä
FINLAND
p +358-3-3753 777
f +358-3-3753 100
toivio(at)fly.to (toivio(at)fly.to)
www.rwm.fi
Luc
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
 Filesize:  68.4 KB
 Viewed:  6679 Time(s)
 Filesize:  50.86 KB
 Filesize:  88.11 KB
 Filesize:  89.91 KB
 Filesize:  28.11 KB
 Filesize:  48.47 KB
 Filesize:  66.17 KB
 Filesize:  60.6 KB
kheindl(at)msn.com
PostPosted: Fri Jul 02, 2010 5:50 am    Post subject: europa trailer height ? Reply with quote
Congratulations Luc.  But why do you want to complicate life and put the trailer inside a trailer ? Not to mention the expense.
The mono trailer is very well designed and has a low profile. What contaminants are there on the road ?
The owner would know the trailer hitch size. It is most likely 50mm, which means a 1 7/8th inch ball is fine.
Regards,   Karl
Date: Thu, 1 Jul 2010 23:52:42 -0400
Subject: europa trailer height ?
Greetings everyone,
Luc
ronics.com
ww.matronics.com/contribution
erichdtrombley(at)juno.co
PostPosted: Sat Jul 03, 2010 6:38 am    Post subject: europa trailer height ? Reply with quote
Luc,
I agree with Karl, why complicate it. I personally tow my plane to and from the airfield every flight. Additionally, I have towed the plane on a couple of very long trips over 500 miles each without issue. Except for the local trips, I remove the tailplanes and store them in the tow vehicle. They move around too much on the trailer. I also add an extra strap over and around the monowheel/wheel ramp/support structure keeps that end from moving around. I also know of another builder that towed his Europa from Arizona to Nebraska and back a few times without issue on the standard Europa trailer.  That is almost 1,000 miles each way.
The added benefit of towing the Europa on its trailer is that you are able to keep an eye on it from the tow vehicle. Either way you go (trailer in a trailer or just trailer) make sure the wing supports fit snug. I think the sling is much better than the foam supports Europa had for awhile. I replaced mine with a 4" wide strap covered with carpet. Seems to work well.
Good luck.
Erich Trombley
N28ET Classic Mono 914
$0.99/day Car Insurance?
Insurance deal just passed allows YOU to legally pay $1/day
iQuotes.org [quote][b]
