mrspudandcompany(at)veriz Guest
Posted: Wed Jun 23, 2010 11:53 am Post subject: Audio system design |
I have been thinking about the audio system for my 2 place IFR airplane. Have looked at the audio info presented in Bob's book and am not sure if the systems depicted will satisfy my needs/wants. The aircraft will have 2 NAVs, 2 COMs, Glass panel (GRT EFIS), and GPS, along with a music channel input.
1. I would like some elaboration on Bob's system, as to advantages and disadvantages.
2. Does anyone have any experience with the RST unit?
Comments, suggestions, helpful hints requested.
Roger
Posted: Wed Jun 23, 2010 12:05 pm Post subject: Audio system design |
If your music is planned to be in stereo - that might impact your audio panel selection.
Posted: Thu Jun 24, 2010 4:03 am Post subject: Audio system design |
At 02:51 PM 6/23/2010, you wrote:
| Quote: | I have been thinking about the audio system for my 2 place IFR airplane. Have looked at the audio info presented in Bob's book and am not sure if the systems depicted will satisfy my needs/wants. The aircraft will have 2 NAVs, 2 COMs, Glass panel (GRT EFIS), and GPS, along with a music channel input.
Comments, suggestions, helpful hints requested. |
I'm not sure what you're referring to as a 'system'.
I've described a variety of ways in the book and
in the instructions for the DIY audio isolation
amplifier that offers a wide range of options.
Those options will range from one radio and no
intercom to a panel full of radios, stereo
entertainment . . . and if the companion
intercom is so fitted, up to 4 seats.
What are YOUR requirements? How many different
audio sources do you anticipate? If there are
warning signals from the efis and gps systems,
then you may need to mix up to 6 different
sources with stereo entertainment on top of
that.
You can add more inputs to the device I've
described and it will handle stereo music.
There are sources for audio isolation amplifiers
that have more inputs also. Which intercom
are you looking at? It may have stereo mixing
features too and you then may only need a
mono-version of the audio isolation amplifier
which would provide all the inputs you'll need.
So it's not "bob's system" that has advantages/
disadvantages, it's YOUR system that describes
design goals that must be met whether you use
any data from the 'Connection or any other
source.
Bob . . . [quote][b]
Radioflyer
Posted: Fri Jun 25, 2010 5:58 am Post subject: Re: Audio system design |
You might also consider one of the pre-built, inexpensive, Audio mixers made for aviation use. I purchased a CS-408 unit (aprox. $100) from Precision Instrument & Control, Inc. (Ft Worth, TX). I needed to mix my Nav, coms, and various warning audio signals in my LongEz. Frankly, I have not yet tested the installation. However, the unit seems perfect for me. It is very small, well built, and can mix/equalize up to 8 channels.
I think there are a couple of other similar products out there, but can't remember the sources.
--Jose
retasker(at)optonline.net Guest
Posted: Fri Jun 25, 2010 6:52 am Post subject: Audio system design |
Where can one actually find and purchase this unit???
Dick Tasker
Radioflyer wrote:
You might also consider one of the pre-built, inexpensive, Audio mixers made for aviation use. I purchased a CS-408 unit (aprox. $100) from Precision Instrument& Control, Inc. (Ft Worth, TX). I needed to mix my Nav, coms, and various warning audio signals in my LongEz. Frankly, I have not yet tested the installation. However, the unit seems perfect for me. It is very small, well built, and can mix/equalize up to 8 channels.
--Jose
http://forums.matronics.com/viewtopic.php?p=302465#302465
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Posted: Fri Jun 25, 2010 7:40 am Post subject: Audio system design |
At 08:58 AM 6/25/2010, you wrote:
There's a List member who offers a multi-channel
mixer and as I recall he offered channel-by-channel
gain potentiometers too. See:
http://www.vx-aviation.com/page_2.html#AMX-2A_more
Posted: Fri Jun 25, 2010 7:55 am Post subject: Audio system design |
Hello Dick
I do not know about this unit, but I purchased and installed the Audio Mixer AMX-2A from Vern Little, and it works as advertised.
It is small, light, and perfectly suitable for the job. Nowadays (not when I bought it) it is not cheap though.
Carlos
[quote] --
sprocket(at)vx-aviation.c Guest
Have a look at http://vx-aviation.com/.
The AMX-2A supports 10 channels, with volume control for four channels.
Works with any intercom or comms radio without additional components and is
very small and light. We take PayPal and shipped from stock, free shipping
anywhere in the world. Similarly packaged gizmos support music players and
cell phones (or both).
Thanks, Vern Little
RV-9A, HR-II (in gestation)
www.vx-aviation.com
From: "Richard E. Tasker" <retasker(at)optonline.net>
Sent: Friday, June 25, 2010 7:43 AM
To: <aeroelectric-list(at)matronics.com>
Subject: Re: Re: Audio system design
Dick Tasker
Posted: Fri Jun 25, 2010 10:50 am Post subject: Audio system design |
Thanks to all who responded. Unfortunately, I do not need a 10 channel
mixer and certainly can't see spending $160 for about six channels more
than I need.
I am perfectly capable of designing and building my own but I was hoping
to find a simple, cheap solution.
Dick Tasker
Carlos Trigo wrote:
Hello Dick
<http://www.vx-aviation.com/page_2.html#AMX-2A_more>, and it works as
advertised.
Carlos
Posted: Fri Jun 25, 2010 4:32 pm Post subject: Audio system design |
At 01:49 PM 6/25/2010, you wrote:
channel mixer and certainly can't see spending $160 for about six
channels more than I need.
hoping to find a simple, cheap solution.
Dick Tasker
We still offer boards for this DIY
audio isolation amplifier that can
be fabricated in both mono and stereo
versions. We've sold about 50 boards
over the past 10 years and have received
no reports of difficulties getting it
assembled and integrated into the
builder's project.
http://www.aeroelectric.com/Catalog/AEC/9009/9009-700L.pdf
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Fri Jun 25, 2010 5:51 pm Post subject: Audio system design |
The link(below) won't work for me, neither does accessing your catalog at your AeroElectric web site
Can you steer me in the right direction
Dick
In a message dated 6/25/2010 7:33:13 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
| Quote: | | http://www.aeroelectric.com/Catalog/AEC/9009/9009-700L.pdf |
Bob McC
Posted: Fri Jun 25, 2010 6:24 pm Post subject: Audio system design |
Dick;
Both the website catalogue and the provided link work fine for me. Must be something with your computer or e-mail programme, it’s not Bob’s documents.
Here’s the link pasted from my computer. See if it works better than the original.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RGent1224(at)aol.com
Sent: Friday, June 25, 2010 9:50 PM
Subject: Re: AeroElectric-List: Re: Audio system design
Dick
0123456789
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sat Jun 26, 2010 3:49 am Post subject: Audio system design |
At 08:49 PM 6/25/2010, you wrote:
Try starting with the front page at http://aeroelectric.com
and navigate through the various index pages.
N20DG
Posted: Sat Jun 26, 2010 6:06 am Post subject: Audio system design |
Tried that last night and it didn't work but lo and behold today it works - Just the wonders of this age of communication.
Dick
In a message dated 6/26/2010 6:51:36 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
Bob . . . | Quote: |
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Radioflyer
Posted: Sun Jun 27, 2010 3:03 am Post subject: Re: Audio system design |
Someone asked where to get the unit I suggested. The CS-408 unit is from Precision Instrument & Control, Inc. (Ft Worth, TX). The company sells these directly. They are an electronics OEM for several aircraft manufacturers. I'm away from my files so can't provide the phone number, but they are probably listed in the phonebooks. Harvey is the main contact there for this product. Between the CS-408, the VX unit, and the Aerolectric unit, there is no longer any excuse for not having an almost invisible "audio panel".
--Jose
enginerdy(at)gmail.com Guest
Posted: Sun Jun 27, 2010 10:05 am Post subject: Audio system design |
Is this it?
http://maps.google.com/places/us/tx/haslet/aviator-dr/512/-precision-instrument-&-control?hl=en&gl=us
--Daniel
On Jun 27, 2010, at 6:03 AM, Radioflyer wrote:
--Jose
http://forums.matronics.com/viewtopic.php?p=302661#302661
Radioflyer
Posted: Mon Jun 28, 2010 9:28 am Post subject: Re: Audio system design |
yes, that's the one. 817.439.4645
-Jose
