Using flaps for takeoff
timb
PostPosted: Mon Jun 28, 2010 2:07 pm    Post subject: Using flaps for takeoff Reply with quote
I just had a conversation with a gentlemen from our airpark who said during the last flyin all the RV-s took off with some flaps. I had been told previously the flaps in the RV were drag flaps only and did no real good for lift. I also did my transition training a few years ago with Mike Seager and he did not have me using any flaps for take off. Since I have not tried it (yet) I was wondering if some of you are using flaps for takeoff and if you can tell any real difference. Would love to hear your thoughts.
Tim Bryan
RV-6 N616TB
Frankston, Texas
Tim Bryan
RV-6 Flying
N616TB
rice737(at)msn.com
PostPosted: Mon Jun 28, 2010 2:24 pm    Post subject: Using flaps for takeoff Reply with quote
Hey Tim,
I don't see how the flaps on RV's would only be drag flaps, if so, they would not lower your stall speed when extended.  Mine surely do. (RV8)  Just like a Piper, Cessna, or Mooney for that matter, adding a little flap (10 degrees or so) should reduce your take off run and get you over the tree line a little faster.
Good flying,
Paul
To: rv-list(at)matronics.com
Date: Mon, 28 Jun 2010 17:06:28 -0500
Subject: RV-List: Using flaps for takeoff
--> RV-List message posted by: N616TB <N616TB(at)btsapps.com>
Tim Bryan
RV-6 N616TB
Frankston, Texas
&g========================>
tcone1(at)comcast.net
PostPosted: Mon Jun 28, 2010 2:41 pm    Post subject: Using flaps for takeoff Reply with quote
I only use flaps on takeoff when I have someone in the back seat. I'm certain the tail comes up more easily with a little flap.
As to whether it improves runway performance in terms of shortening the required field length or not...are you kidding? It would have to be a REALLY short field before my -8 started having to worry about it.
Tim
Terry Watson
PostPosted: Mon Jun 28, 2010 3:56 pm    Post subject: Using flaps for takeoff Reply with quote
Way back before the turn of the century when I got my free ride in the factory RV-8a here at Arlington, WA with Bill Benedict, then general manager of Van’s, I remember him commenting that although it wasn’t necessarily recommended procedure, he “did it like a Cessna” and put in a little bit of flaps on takeoff. I don’t recall his reason, if he gave me one.
Terry
Stalled (on the ground) RV-8A project
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Timothy E. Cone
Sent: Monday, June 28, 2010 3:36 PM
Subject: Re: Using flaps for takeoff
Tim
----- Original Message -----
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Monday, June 28, 2010 3:23 PM
Subject: RE: Using flaps for takeoff
Hey Tim,
Good flying,
Paul
> From: N616TB(at)btsapps.com
> Subject: Using flaps for takeoff
> Tim Bryan
> RV-6 N616TB
> Frankston, Texas
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
acepilot(at)bloomer.net
PostPosted: Mon Jun 28, 2010 3:57 pm    Post subject: Using flaps for takeoff Reply with quote
I'm not sure with RVs, but....wouldn't flaps (ie 10 degrees) be used for
soft field takeoffs and no flaps for short field takeoffs (ie clearing
trees at the end of a short field)? That's how it works with Cessnas
and I assume Pipers and Mooneys as well. That's the way I was taught
(in our Cessna 140), but maybe that's old school thinking Wink
Scott
http://corbenflyer.tripod.com/
Flying Corben Junior Ace - Building RV-4
Gotta Fly or Gonna Die
Paul Rice wrote:
Hey Tim,
Good flying,
Paul
Kellym
PostPosted: Mon Jun 28, 2010 4:01 pm    Post subject: Using flaps for takeoff Reply with quote
Well, I can tell you that in a Cessna 170B and up, flaps shorten takeoff
roll and clearing an obstacle until DA is more than 4500 ft. The old
ones used 20 degrees until the 172 added a notch for 10 degrees and that
was what was used. The Mooney uses 15 degrees of flaps for all takeoffs
unless crosswind is too strong to handle with flaps, regardless of DA.
for soft field takeoffs and no flaps for short field takeoffs (ie
clearing trees at the end of a short field)? That's how it works with
Cessnas and I assume Pipers and Mooneys as well. That's the way I was
taught (in our Cessna 140), but maybe that's old school thinking Wink
Scott
Paul Rice wrote:
> Hey Tim,
> Good flying,
> Paul
Kelly McMullen
KCHD
PostPosted: Mon Jun 28, 2010 4:24 pm    Post subject: Using flaps for takeoff Reply with quote
I can see how 10 degrees might lessen the takeoff roll due to being able
to lift off at a slightly lower airspeed. Can anyone explain why the
obstacle clearance would be better with flaps down? There is more drag,
so wouldn't rate of climb be slightly less? I suppose if you climb at
just above stall speed, your ground speed would be lower, thus taking
longer to get to that tree line? So, why do instructors teach flaps for
soft field and no flaps for short field?
What does the POH in the 170B say about soft and short field ops?
Scott
takeoff roll and clearing an obstacle until DA is more than 4500 ft.
The old ones used 20 degrees until the 172 added a notch for 10
degrees and that was what was used. The Mooney uses 15 degrees of
flaps for all takeoffs unless crosswind is too strong to handle with
robin(at)PaintTheWeb.com
PostPosted: Mon Jun 28, 2010 4:42 pm    Post subject: Using flaps for takeoff Reply with quote
The reason is the same for most airplanes, Vans included. More lift.
To Tim’s question that included the statement “all the RV-s took off with
some flaps”
Well it’s hard to get all pilots to do anything the same let alone us
non-conformist “don’t tell me what to do” Experimental pilots. I have never
heard of a flap that was “drag only” seems near pointless, might as well
avoid the weight & complexity of flaps that do not produce lift (and drag).
The entire RV product line is extremely versatile and can take off with no
flaps in most environments. The RV-10 is the only Vans design (I don’t know
about the RV-12) with a 3 degree flap take off setting to improve hard
surface take off performance. That being said adding some flap to all RV
models should shorten take off roll. How much is needed or ideal depends on
the plane, weight configuration, runway surface etc... Most important is
that you as a pilot remember the flaps are deployed and do not exceed Vfe.
So Tim give 10 degrees a test to see how it makes a difference on your ship
denis.walsh(at)comcast.ne
PostPosted: Mon Jun 28, 2010 5:06 pm    Post subject: Using flaps for takeoff Reply with quote
I can't speak for Cessnas, since I have very little time in them.
Every other airplane I have flown is designed to get off as soon as it
can, that is at the lowest speed with which you can be assured of
flying under good control. I have not flown any airplane which takes
off without using flaps, if it has them.
The RV-6 I do know about and have quite a few take offs. Here is my
take:
the first 10 degrees (1/4) flap is mostly a lift gain and very little
drag added at low speed. You also get a new MAC line which gives you
a higher angle of attack at a given deck angle. If you go further
than 10, you start getting mostly drag and little or no add to the
lift. As I see it, your choice is to use 10 flaps and get off a
little sooner, or use no flaps and roll a little longer. I believe
the plane will accelerate better once the wheels get air under them,
so the obstacle clearance will be better, too. Lastly, the deck angle
is lower with the ten flaps and you can see better for that point in
the take off where you are just lifting off. Retracting the flaps is
the first thing I do after take off. before boost pump, RPM, or
throttle.
Consequently, I always use 10 flap for take off, except in a severe
cross wind (above 25K). In that case I am going to "pull it off" for
take off with a raid rotation. If you use any flap in that condition
it may crow hop toward the down wind side of the runway. Very
difficult to control..
A lot of RV guys don't use flap for take off and I don't think it is a
big deal. I do recommend every one try it, and try some stalls at 10
also. I think you will find the plane has a much more solid feel at
low airspeeds with the flap down a little. My personal observation is
that those folks who don't use flaps are operating at a lot higher
airspeed than I am. That's ok too. If you are going to not lift off
until you have 70 knots then why would you use flaps? Same applies
for landing.
I will offer that my tires last longer than most. Personally I
believe this to be because I try to touch down at 45K, and take off at
the same speed.
I don't think there is a good solution for everyone. For those who
don't fly much it makes sense (to me) to use higher speeds and longer
take off rolls. That is not for me, however.
For most of us, the RV normally accelerates so fast that this one or
two knot difference in stall/lift off speed is hard to even notice any
way. You will really notice it at high altitude hot day max gross
weight.
I hope this "one man's opinion" helps. Everyone sees it a little
different.
Denis
RV-6A 4,300 take offs, 4300 landings
Tim Bryan
RV-6 N616TB
Frankston, Texas
Gary.A.Sobek
PostPosted: Mon Jun 28, 2010 5:08 pm    Post subject: Using flaps for takeoff Reply with quote
Tim:
I do not use flaps for takeoff. I was not able to to measure any difference in takeoff with no flaps, 10 flaps, and 20 flaps. This was over 12.5 years ago.
I will use 10 flaps on SOFT grass fields. I do not think it reduces ground roll on grass but I feel that it may reduce some of the weight on the mains
ceengland(at)bellsouth.ne
PostPosted: Mon Jun 28, 2010 6:08 pm    Post subject: Using flaps for takeoff Reply with quote
Tim Bryan
RV-6 N616TB
Frankston, Texas
As others have said, they definitely add lift.
I came to a purchased -4 after ~200 hrs in a Swift, with flap settings
of full or none (never used for T/O). Never thought to try T/O flaps
through 7 years of flying that 1st -4, and through about 3 or 4 years of
flying the 2nd one. Then one day at a neighboring strip's flyin, I
forgot to retract them (full flaps) on T/O. I was off much quicker than
expected, and seemingly near pattern altitude before the end of the
strip. Felt like departing into a 20kt headwind. Since then I've played
with them several times, but just for fun. Even with only 160 hp, it
would take a really short strip to make flaps seem necessary. On the
obstacles issue, I'm no authority but I'd assume that the reason
flaps-down gets you over obstacles better is that you have an improved
climb *angle*.
Anyway, I can't see any reason to avoid using them on T/O, except the
surprise you might get if you aren't prepared to be off the ground so
quickly. Try it; you might like it. Smile
Charlie
Slobovia Outernational
flying purchased -4; -7 finish kit
jsflyrv(at)verizon.net
PostPosted: Mon Jun 28, 2010 7:39 pm    Post subject: Using flaps for takeoff Reply with quote
Hi Gary,
Living 6 miles form Van and watching him fly frequently, I guess the
best evidence for using flaps is to watch him takeoff, almost always uses
flaps and consistently shorter takeoff roll then most others.
RV6 Flyer wrote:
Tim:
on the mains.
If anyone has some data that shows a difference, please share it.
Also let us know what model RV, HP, and prop.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,381+ Flying Hours So. CA, USA
> Tim Bryan
> RV-6 N616TB
> Frankston, Texas
Hotmail has tools for the New Busy. Search, chat and e-mail from your
inbox. Learn more.
<http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_1>
Checked by AVG - www.avg.com
Kellym
PostPosted: Mon Jun 28, 2010 7:53 pm    Post subject: Using flaps for takeoff Reply with quote
POH for a C170B last produced in 1956? Surely you jest. It had a one page 5X8" two sided FAA approved flight manual. You climb at Vx, which for most planes is flaps and gear down. Best angle of climb, which is what you need when obstacle is near. The FAA short field definition rarely meets real world...paved runway, just short distance to obstacle. Most real world short fields are also either soft or rough fields and flaps are needed. Just my experience in 700 hours of flying 170B in Alaska. Instructors teach what the FAA dictates to pass the test. I do happen to have a C177B POH handy, which calls for 10 degrees for normal takeoff and 15 degrees for max performance takeoff:
[img]cid:part1.04030601.09070902(at)aviating.com[/img]
[img]cid:part2.06050302.01040504(at)aviating.com[/img]
On 6/28/2010 5:24 PM, Scott wrote:
--> RV-List message posted by: Scott <acepilot(at)bloomer.net> (acepilot(at)bloomer.net)
I can see how 10 degrees might lessen the takeoff roll due to being able to lift off at a slightly lower airspeed. Can anyone explain why the obstacle clearance would be better with flaps down? There is more drag, so wouldn't rate of climb be slightly less? I suppose if you climb at just above stall speed, your ground speed would be lower, thus taking longer to get to that tree line? So, why do instructors teach flaps for soft field and no flaps for short field?
Scott
--> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com)
Well, I can tell you that in a Cessna 170B and up, flaps shorten takeoff roll and clearing an obstacle until DA is more than 4500 ft. The old ones used 20 degrees until the 172 added a notch for 10 degrees and that was what was used. The Mooney uses 15 degrees of flaps for all takeoffs unless crosswind is too strong to handle with flaps, regardless of DA.
 Filesize:  119.96 KB
 Viewed:  11052 Time(s)
 Filesize:  1.97 KB
Kelly McMullen
KCHD
