gordonrsmith921@yahoo.com
Posted: Sun Jun 27, 2010 2:34 pm Post subject: Toggle Relay |
Is there a 12V. Relay device (SPST or SPDT) that can be toggled OFF/ON from a remote momentary SPST mini switch? It should remain in the off or on position until toggled again. I am looking for something in the class of a S704-1 regarding robustness and capacity.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Gordon Smith
Bob McC
Posted: Sun Jun 27, 2010 6:39 pm Post subject: Toggle Relay |
Gordon;
See my reply to Valin re: the speed brakes thread, a couple of posts up the list. This bi-stable relay does what you are describing. The one I cited is a DPDT device rated 15 amps per contact. You could parallel the two contacts to approximate the 704’s rating. The contacts won’t precisely share the load but unless you are running at absolutely max rating they’ll work well. If the switch ratings are a real concern, the supplied switches on this relay could be replaced with Omron V-15-1C5 switches which are rated at 15Amps 250VDC.
Bob McC
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Gordon Smith
Sent: Sunday, June 27, 2010 6:33 PM
Subject: Toggle Relay
Gordon Smith 0123456789
_________________ Bob McC
Falco #908
(just starting) |
