tonyrenshaw268(at)gmail.c Guest
Posted: Sat Jun 26, 2010 11:38 pm Post subject: gascolators |
Gidday,
I have a small Andair, that I probably am NOT going to use, and am looking for alternatives. Ideally I'd like a clear bowl solution so that I wouldn't have to open it up unless a visual inspection through the sides indicated a problem. The small glass (?) filters supplied by Europa may well satisfy that, but I know the fuel filtering capability is near to nought. I have an Ezy-Flow 90 micron aluminium circular cartridge filter that I think I'll probably use on my Reserve side, and ironically I might use a smaller filter or gascolator on my Main side. So, I am interested if there is a gascolator other than Andair that someone has used, and is happy with in operational use?
Thanks in anticipation.
reg
Tony Renshaw
Sydney Aussie
mikenjulie.parkin(at)btin Guest
Posted: Sun Jun 27, 2010 12:43 am Post subject: gascolators |
| Quote: | > that, but I know the fuel filtering capability is near to nought.
Tony,
I am using the Sytec Pro filters as supplied by Europa. Do you have the
data that led you to the above conclusion.
Mike
Checked by AVG - www.avg.com
07:35:00
hurstkr(at)redzone.com.au Guest
Posted: Sun Jun 27, 2010 2:53 am Post subject: gascolators |
Tony,
| Quote: | So, I am interested if there is a gascolator other than Andair that
someone has used
If you really want a see through gascolator, see if there is a wrecker in
Sydney with a gascolator from a C172.
They have a glass bowl and a drain tap on the bottom. . . . well at least
my "F" model did !
Cheers
Kingsley
Posted: Sun Jun 27, 2010 7:39 pm Post subject: gascolators |
Tony,
I have a 914 installation. I used the original plumbing layout circa 2000.
The standard fuel selector feeds the 2 fuel pumps mounted in parallel and
each pump has its own PRO filter. I know that later than 2000 there was
much discussion about the necessity for check valves and I understand that
the latest build instructions reflect that change. The latest drawing I
have seen puts the fuel pumps in series with a parallel check valve
arrangement designed to bypass a blocked pump I guess. There was also a lot
of discussion about the fuel pressure to the engine.
In practice I have found that the original parallel pump arrangement works
well. Testing the fuel flow to the engine I found that No 1 pump provided
89 L/Hr and No 2 pump 94 L/hr, both pumps together gave about 200 L/Hr. I
always filter the fuel when refuelling with the standard water/separator
funnel. Until recently, I never had any problems - changing the filters as
part of the maintenance routine rather than a necessity.
I also have a fuel pressure switch which feeds both a warning light and my
voice warning system.
After an extended layup, I emptied the tank and recalibrated the fuel
contents system. I also checked the carb bowls for any gunge - there was a
little gummy residue that came out easily with carb cleaner. A filter check
showed no problems.
On returning home from the Popham fly-in, I had several voice warning alerts
of 'Fuel Pressure Low' - nothing was seen on the Fuel Low Pressure light.
While working through the system fault diagnosis, I noticed a very short
flicker of the fuel pressure light with an attendant voice warning. Having
changed tanks and tried the different fuel pump combinations (it was
necessary to trip the CB to isolate the No 1 pump) I concluded that the
problem was either a No 1 filter clogging or the No 1 pump on its way out.
Normal SOP, both pumps on below 1000 ft agl, a normal landing followed.
Inspection on the ground showed that No 1 fuel pump PRO filter was indeed
starting to clog. Filter changed no further problems.
I was very pleased with the Voice Warning system it provided an early
indication of an impending problem that could be worked well before the
world went silent.
The twin PRO filter configuration does seem to work quite well and it offers
an alternative path for the fuel if one of the filters clogs - as I
understand it, some Andair installations result in a possible single point
of failure. I guess 2 Andair filters is the perfect (but costly) solution.
In summary, the PRO 805 filters are probably not the perfect solution, but
they do work. There are many Europas out there with lots of hours happily
using the in line filters without problem.
All the above is just my opinion and probably not worth a lot. (tin hat
on).
Mike (G-JULZ)
Do not archive.
g-iani(at)ntlworld.com Guest
Posted: Mon Jun 28, 2010 1:04 am Post subject: gascolators |
Mike
You do not need your tin hat.
G-IANI has the same set up as G-JULZ and although not perfect it works very
well. G-IRON has the serial pump setup which is no better, costs a lot more
and takes up more space.
My only contribution is that I have self sealing quick release connectors on
the system (see the attached picture). This allows the whole thing to be
removed without fuel going every ware.
These connectors are not available from the usual sources (Europa and Demon
Tweeks) as they are 5/16. You have to get them from a specialist and the
details are below
Tom Parker Limited Web site www.tom-parker.co.uk
Each connector consists of a cPLCD17005V coupling and a cPLCD2205 insert.
Both are self sealing
Ian Rickard G-IANI XS Trigear, 300hours
Europa Club Mods Specialist
e-mail g-iani(at)ntlworld.com
157.53 KB |
3475 Time(s) |
