gordon
Posted: Tue Jun 22, 2010 9:29 pm Post subject: ICOM A 210 matched with a Flightcom 403 intercom |
Several weeks ago you gave me some good info in that the ICOM A-210 and the Flight Com 403 are compatable.
I have it installed and with much adjusting ect everything except volume adjustment are fine.
I have called 2 times to Icom Tec and get no satisfaction. The way it is, You can only have a volumn control is
to go into Menu..The first item that comes up is “HP LEVEL” which is headphone level. This is the same as (Vol).
These are the 3 options I have.
AF gain: The output level is the same as (Vol).
Off (0) While muting the headphone.
01-80 Setting audio level from 1 to 80.
So according to ICOM Tec support—they recommend (and I am already using this method) is to put he Vol as high
as needed and then control it with the volume controls on my Lightspeed headsets.
If I try to use the normal Volume control like I normally would, just reach over and adjust ., Nothing happens
The scale shows up on the front, you know it goes up and down as you turn the knob but nothing happens.
So according to Icom that seems to be the only way it can be done unless I put in audio panel.
I don’t have the room and don’t want to do it.
Have flown with it this way and the com works fine. Doesn’t pick up the loud noise. And am able to communicate fine.
The transceiver works fine also.
Its just the Idea that if you want more volume if I don’t have enough thru the headset controls, I have to go into menu and
dial in more.
Does any one have any suggestions or has anyone had this problem . Thanks Gordon
[/list]
_________________ tailwind10 |
