360 vs 320 "flywheel"
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
dean.psiropoulos(at)veriz
PostPosted: Tue Jun 22, 2010 7:54 pm    Post subject: 360 vs 320 "flywheel" Reply with quote
Hi all:
Quick question…..the perimeter bolt holes (the ¼ inch holes just under the
ring gear, not the prop bolt holes) on the 0-360 flywheel vs those on an
0-320…is there any difference? In other words, if I lay an 0-320 flywheel
on top of one for an 0-360 will the perimeter bolt holes all line up? Need
to know if my Landoll steel ring for 0-360 will bolt onto 0-320 "flywheel".
Thanks for the help.
Dean Psiropoulos
RV-6A N197DM
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
flyadive(at)gmail.com
PostPosted: Wed Jun 23, 2010 3:50 am    Post subject: 360 vs 320 "flywheel" Reply with quote
Yes, Dean...
They will bolt onto each other BUT! What you have to check - COUNT -
is the number of teeth on the ring gear. A mis-match on teeth will
cause problems with the starter.
Barry
On Tue, Jun 22, 2010 at 11:53 PM, DEAN PSIROPOULOS
<dean.psiropoulos(at)verizon.net> wrote:
Hi all:
Dean Psiropoulos
RV-6A   N197DM
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
