KIS TR-1 Nose Gear Heat Treat
bakerocb
PostPosted: Tue Jun 22, 2010 7:36 pm    Post subject: KIS TR-1 Nose Gear Heat Treat Reply with quote
6/22/2010
Hello Ken, Rich wrote: "........ the later spring/shock gears were not heat
treated."
Just wanted to let you know that when Lyle Hendricks converted my airfoil
shaped spring / shock nose gear strut to a round tube that it was heat
treated on 11/14/01.
It went through: Normalize at 1650 degrees; Autenitie** at 1575 degrees; and
Temper at 1050 degrees. Rockwell C hardness was 28-31.
Please see the attached picture.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
**PS: My knowledge of heat treatment is pretty limited. This term may really
be austenite as austenitie is something fairly exotic. Maybe Lyle can
clarify this.
 Filesize:  294.17 KB
 Viewed:  3035 Time(s)
