Enco rivet gun on sale
rbutterfield(at)mebtel.ne
PostPosted: Wed Apr 26, 2006 11:24 am    Post subject: Enco rivet gun on sale Reply with quote
A shipment came in today from Enco Tools, and the flyer in the box
mentioned a pneumatic riveter on sale:
http://www.use-enco.com/CGI/INSRIT?PMAKA=801-1250&PMPXNO=950023&PARTPG=INLMK3
(or http://tinyurl.com/z3nlh )
Click on the master catalog page for a picture (regular price $4Cool.
I have _not_ seen or used this item, so cannot make any claims as to
whether, or how well, it works.
RonB
randy(at)shadycreekoutlaw
PostPosted: Wed Apr 26, 2006 12:08 pm    Post subject: Enco rivet gun on sale Reply with quote
Has anyone bought a similar tool and tried grinding the concave on the tip
for the Avex countersunk rivets? To me that seems like it might be a bit
difficult to get right...
Randy
N344RB
frank.hinde(at)hp.com
PostPosted: Wed Apr 26, 2006 12:26 pm    Post subject: Enco rivet gun on sale Reply with quote
Really need a lther and a ball end mill to do it right ..>At least that
was the way I did it...Or simply send your riet tip to ZAC who will
concave them for you...I wold get two sets done, spares are always
needed.
Frank
Jaybannist(at)cs.com
PostPosted: Wed Apr 26, 2006 1:03 pm    Post subject: Enco rivet gun on sale Reply with quote
I don't know that I got it exactly right, but close enough for me. I have
ground four of them for different rivet pullers. I just heated up the nose piece
to a cherry red and let it cool. Then it can be ground with any number of
tools. I have used a Dremel with both round cutting heads and round grinding
heads. I think the metal ones give a smoother result.
Jay in Dallas - 601XL half done with second wing.
n4546v(at)mindspring.com
PostPosted: Wed Apr 26, 2006 1:16 pm    Post subject: Enco rivet gun on sale Reply with quote
For a short article on the easy way to form puller heads using Dremel
tool, go to the archives for a short article I offered. It is message
#11121 or use the search word: "gottem" and it is the only message that
will come up.
Randy L. Thwing, 701 plans
Subject: RE: Enco rivet gun on sale
<frank.hinde(at)hp.com>
needed.
Frank
Tim Juhl
PostPosted: Wed Apr 26, 2006 3:10 pm    Post subject: Re: Enco rivet gun on sale Reply with quote
Zenith will grind your nosepieces for $8 apiece.
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
p.mulwitz(at)worldnet.att
PostPosted: Wed Apr 26, 2006 4:10 pm    Post subject: Enco rivet gun on sale Reply with quote
I have taken to making my own nose pieces for riveters.
I bought the set from ZAC and used it for a while. The problems I
have had with their design included poor looking finished rivets (the
A5 nose piece left gouges on one side of the rivet head) and a
tendency to set the rivets at an angle which I always wanted to drill
out and replace.
My latest set of nose pieces is a lot easier to use. I have a much
wider nose on each one so it is easy to see when it is parallel
(perpendicular?) to the work piece so the rivet is set straight.
I make my nose pieces from round stock on a metal lathe. The basic
cup shape is cut with a round nose milling cutter mounted in the tail
stock. After determining the correct cup depth with a few sample
rivet tests I round the edges on the front of the nose piece and
polish it all up with a dremel tool and rubberized abrasive thingies.
I hope this helps someone.
Paul
XL wings.
Larry Portouw
PostPosted: Wed Apr 26, 2006 4:29 pm    Post subject: Re: Enco rivet gun on sale Reply with quote
I just bought a pneumatic gun on ebay and send the nose pieces off to ZAC. What I got back pulls better rivets than the factory supplied hand riveter. My recomendation is to send 'em off to ZAC.
Larry Portouw
H. Stab 601XL Kit
Atlanta, GA
Larry Portouw
601XL Kit (H. Stab) (on hold)
PA-22 N8141C<< This project now taking all my time.
Fort Huachuca, AZ
View user's profile Send private message Yahoo Messenger
Ron Lendon
PostPosted: Wed Apr 26, 2006 7:08 pm    Post subject: Re: Enco rivet gun on sale Reply with quote
To modify the noses pieces:
3/8 Drill motor, Bench Vice, Die Grinder, Acorn shaped carbide bit.
Make sure you have centered the nose piece in the chuck by spining it. Put some color on the nose piece before begining the grinding. It lets you see better where the tool bit touches.
Start the drill motor and lock it on, start the die grinder and touch off in the center. Use a light touch and stop to see if it is really centered. If OK continue to shape untill it is about right, then test it. Once the tests prove good, use sandpaper and red scotchbrite to polish out the tool marks.
It really is easy and if you go to deep just grind it flat and start over. Using the carbide burr no heat is required.
River test strip.
 Filesize:  164.83 KB
 Viewed:  704 Time(s)
3/8 drill motor held in vice. Die grinder with acorn shaped carbide burr.
 Filesize:  124.21 KB
 Viewed:  725 Time(s)
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
PostPosted: Wed Apr 26, 2006 7:59 pm    Post subject: Enco rivet gun on sale Reply with quote
I've found if you go too deep you can fix it by taking a little bit
off the flat part of the nose piece with a normal file. You can
test the result by setting a rivet and cutting across it to see if
the internal layer is flat to the surface of the piece being riveted.
Paul
XL wings
PostPosted: Wed Apr 26, 2006 9:01 pm    Post subject: Enco rivet gun on sale Reply with quote
Since I didn't already have a pneumatic rivet gun, and deciding about 1/2
way through building my HS that I would have one before I started my wings,
I ordered one of these Enco riveters today... I believe I'll try the
methods described here to grind my own tips as well... My cousin who is
building a 601HD grinds his own, I'll get him to help me out on the first
set...
Thanks for all the input and help!
Randy
N344RB
