		vk3eka(at)bigpond.net.au Guest
				 Posted: Wed Jun 16, 2010 7:49 pm    Post subject: Zenith-List: RE: Fuel Cap 601XL |
				Thanks for the reply’s guys,
 I’ll see if I can machine a piece of ally the same shape as the filler cap and try that.
 Cheers
 Peter
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jon Bateman
  Sent: Thursday, 17 June 2010 1:24 PM
  Subject: RE: Zenith-List: RE: Fuel Cap 601XL
     To aid in getting my tank neck on and off I machined down a piece of nylon that just fit inside the neck with a hole near the top for a screwdriver or what not to turn it with. This has works great as there is zero chance for marring the neck. Before re-installing the neck use anti seize on the threads
      Jon B.
            2/3rds through upgrade.
  Subject: Zenith-List: RE: Fuel Cap 601XL
  Date: Wed, 16 Jun 2010 17:24:17 -0600
 Peter:
 If your fuel cap is the same as ours which stuck pretty hard, I cut a 2” piece of ¼” by 1” aluminum bar and gripped it with a pair of vice grips. I inserted into the slots and used a crescent wrench to turn the vice grips until it would unscrew by hand. Good  Luck with your build. DO NOT ARCHIVE
 Wes & Lurlene Bressler, Laramie WY, USA Working on the upgrade.
    	  | Quote: | 	 		  |   >http://www.matronics.com/Navigator?Zenith-Listronics.comww.matronics.com/contribution  |
 The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy.   0123456789 	  | Quote: | 	 		  | >http://www.matronics.com/Navigator?Zenith-List | 	  0 	  | Quote: | 	 		  | >http://www.matronics.com/Navigator?Zenith-List | 	  1 	  | Quote: | 	 		  | >http://www.matronics.com/Navigator?Zenith-List | 	  2 	  | Quote: | 	 		  | >http://www.matronics.com/Navigator?Zenith-List | 	  3 	  | Quote: | 	 		  | >http://www.matronics.com/Navigator?Zenith-List | 	  4 	  | Quote: | 	 		  | >http://www.matronics.com/Navigator?Zenith-List | 	  5
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Thruster87
				 Posted: Wed Jun 16, 2010 9:41 pm    Post subject: Re: Zenith-List: RE: Fuel Cap 601XL |
				Use a piece of wood, NOT alloy so there is no chance of damaging the fuel cap internals. When I put mine on originally I used some permatex  on the threads but it was still a bit hard coming off. Cheers
