Landing gear fairing install
wroe1(at)dbtech.net
PostPosted: Thu Jun 17, 2010 9:03 am    Post subject: Landing gear fairing install Reply with quote
I need some recommendations as to the best way to elevate my completed RV7 fuselage so that I can align the gear leg fairings. The weight should be around 600lb. Is there a better way than jack stands under the center section and weighting the tail?
Thanks!
Wade Roe
RV7 in the final stretch
n223rv(at)wolflakeairport
PostPosted: Thu Jun 17, 2010 9:53 am    Post subject: Landing gear fairing install Reply with quote
I used saw horses.
On Jun 17, 2010, at 1:02 PM, "Wade Roe" <wroe1(at)dbtech.net (wroe1(at)dbtech.net)> wrote:
Thanks!
Wade Roe
wroe1(at)dbtech.net
PostPosted: Thu Jun 17, 2010 10:06 am    Post subject: Landing gear fairing install Reply with quote
How did you get the fuselage on the saw horses? Did you elevate the tail then physically lift on side at a time and insert the horses?
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Michael Kraus
Sent: Thursday, June 17, 2010 12:51 PM
To: rv-list(at)matronics.com
Subject: Re: Landing gear fairing install
I used saw horses.
Thanks!
Wade Roe
craigtxtx(at)yahoo.com
PostPosted: Thu Jun 17, 2010 11:04 am    Post subject: Landing gear fairing install Reply with quote
I rigged a motorcycle jack under the center section. That worked well for me.
Thanks!
Wade Roe
smittysrv
PostPosted: Thu Jun 17, 2010 11:37 am    Post subject: Landing gear fairing install Reply with quote
Check this posting:
http://www.vansairforce.com/community/showthread.php?t=11956
Smitty
http://SmittysRV.com
Smittys RV-9A
SmittysRV.com
Bill Schlatterer
PostPosted: Thu Jun 17, 2010 6:06 pm    Post subject: Landing gear fairing install Reply with quote
Transmission jack works really nice for that but you still have to tie the tail down.
Bill S
7a almost there
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Wade Roe
Sent: Thursday, June 17, 2010 12:03 PM
Subject: Landing gear fairing install
Thanks!
Wade Roe
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
 Filesize:  109.09 KB
 Viewed:  6814 Time(s)
