vk3eka(at)bigpond.net.au Guest
Posted: Wed Jun 16, 2010 7:49 pm Post subject: Zenith-List: RE: Fuel Cap 601XL |
Thanks for the reply’s guys,
I’ll see if I can machine a piece of ally the same shape as the filler cap and try that.
Cheers
Peter
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jon Bateman
Sent: Thursday, 17 June 2010 1:24 PM
Subject: RE: Zenith-List: RE: Fuel Cap 601XL
To aid in getting my tank neck on and off I machined down a piece of nylon that just fit inside the neck with a hole near the top for a screwdriver or what not to turn it with. This has works great as there is zero chance for marring the neck. Before re-installing the neck use anti seize on the threads
Jon B.
2/3rds through upgrade.
Subject: Zenith-List: RE: Fuel Cap 601XL
Date: Wed, 16 Jun 2010 17:24:17 -0600
Peter:
If your fuel cap is the same as ours which stuck pretty hard, I cut a 2” piece of ¼” by 1” aluminum bar and gripped it with a pair of vice grips. I inserted into the slots and used a crescent wrench to turn the vice grips until it would unscrew by hand. Good Luck with your build. DO NOT ARCHIVE
Wes & Lurlene Bressler, Laramie WY, USA Working on the upgrade.
| Quote: | | >http://www.matronics.com/Navigator?Zenith-Listronics.comww.matronics.com/contribution |
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. 0123456789 | Quote: | | >http://www.matronics.com/Navigator?Zenith-List | 0 | Quote: | | >http://www.matronics.com/Navigator?Zenith-List | 1 | Quote: | | >http://www.matronics.com/Navigator?Zenith-List | 2 | Quote: | | >http://www.matronics.com/Navigator?Zenith-List | 3 | Quote: | | >http://www.matronics.com/Navigator?Zenith-List | 4 | Quote: | | >http://www.matronics.com/Navigator?Zenith-List | 5
