Allen Gandy
Joined: 10 Jan 2006 Posts: 3 Location: Huntsville, Alabama
Posted: Mon Jun 14, 2010 4:38 am Post subject: 912ULS Recommended Oil |
Recently bought a 6 yr old RANS with 912ULS engine (~300 hrs), we are 3rd owner. Last owner was using Castrol GPS 20W50.
What are current Rotax recommended oils?
Are there issues/considerations in changing from Castrol to some other petroleum based oil?
Allen Gandy
bob(at)fly-ul.com Guest
Roger Lee
Posted: Mon Jun 14, 2010 5:36 am Post subject: Re: 912ULS Recommended Oil |
Hi Allen,
There are better oils to use other than Castorol and Rotax doesn't recommend some of the Castorol oils. It also needs to be a motorcycle oil because of the additives for the gearbox operation. This engine like motorcycles share the oil between the gearbox and the engine. Unless you absolutely can't find a motorcycle oil then a regular car oil shouldn't be used. It doesn't have the additives for the gearbox.
It kind of depends a little on the fuel you use. If you are using 91 octane unleaded auto fuel then you can use a good full synthetic. Such as Mobile One Racing 4T a 10-40w, Amsoil motorcycle oil 10-40w or 20-50w since it is summer time temps or Aero Shell Sport Plus 4 a 10-40w a semi synthetic or Golden Spectro 4 or Honda G4 oil. The Honda oil would be my last pick.
If you have to use 100LL with all the lead you need to use a semi synthetic so it will suspend the lead and will drain out during the changing of the oil. It all won't all drain out, but if you use a full synthetic with 100LL then the lead tends to fall out of solution and settle in areas of your engine. So the Aero Shell Sport Plus 4 a semi synthetic would be a good pick. It is not recommended to use a straight dino base oil because under certain conditions it doesn't offer the higher quality protection as does a synthetic.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Mon Jun 14, 2010 6:38 am Post subject: Re: 912ULS Recommended Oil |
| Allen Gandy wrote: | Recently bought a 6 yr old RANS with 912ULS engine (~300 hrs), we are 3rd owner. Last owner was using Castrol GPS 20W50.
Allen Gandy
Lots and lots of good and bad fights on the various lists about this issue.
My .02. The only _hard_ requirements on the oil you use:
- API service grade (has to be at least API SG as noted in the service instruction)
- viscosity (has to be correct for your expected range of operating temps).
- synthetic vs. semi-synthetic (the use of leaded gas like 100LL determines which choice you make here).
- not _specifically non-recommended_ by Rotax (i.e. if Rotax has identified a particular oil formulation that they _dont_ want you to use).
If it meets these requirements, the rest is gravy. If you can find an oil that Rotax _recommends_, definitely go with that, but don't worry about it if you have to use a substitute that meets the HARD requirements.
I personally use the Aeroshell but have used Valvoline 10W40 (API SJ) in the past with fine results so far.
Now all you gotta do is ask what oil filter to use, and the fun will _really_ begin
LS
_________________ LS
Titan II SS |
Goodone
Posted: Tue Jun 15, 2010 4:46 pm Post subject: Re: 912ULS Recommended Oil |
If you don't have a slipper clutch the Honda motorcycle oil with molybdenum can be considered. This is a very high quality semi-synthetic product. I have been told by several people very involved with Rotex engine training and repair in this country that this is a great product that Rotex will never suggest since they consider Honda a major competitor. My 80 hp 912 UL has lived on the stuff for about 600 hrs now and is in great shape.
Roger Lee
Posted: Tue Jun 15, 2010 6:09 pm Post subject: Re: 912ULS Recommended Oil |
They have recommend the Honda oil in a Rotax class. This is one of the questions that gets ask quite frequently. oil usage.
Tucson, Az.
Cell 520-349-7056 |
dashwood
Joined: 24 Jan 2009 Posts: 73 Location: sw ontario canada
Posted: Thu Jul 08, 2010 4:37 am Post subject: Re: 912ULS Recommended Oil |
i am in need of oil advice too . you can follow some of the more recent post by me. the latest is a report from my ame that the gearbox is toast after 400hrs. i took it in for inspection of a leak in the front seal. the history that i can get to is 1992 to 99 engine was in a box in georgia usa, not sure if pickled proper or not. then installed in a 701 in canada and used for 200hrs on amsoil semi 10/40 . then i purchased airplane and used amsoil for a short time then switched to the mobil mx4 as a rotax recommended oil. baced on the parts list i was given the case is fine the rest not so good. worn parts and gear tooth galling. my next question is if gearbox is so bad ????? about the engine. the oil nad filter changed faithfully every 50 hrs. what oil to use? what oil not to use?
update 7/19/10: flying again. new gearbox is a great improvment. coutd not believe the smoothnes and quiet of the new box. gradual wear is hard to recognize. only thing saved was the case. the shime and washer were very bad and the clutch washers were showing wear. bearing seemed fine but not a big expense to do now. the gear wear points pointed out by the ame were hard to see with the naked eye. ... but have "0" time box now. the vdo oil pres sender ( see prev posts about this) craped out again after 10 hrs. i now have a new mechanical unit installed at a lower cost then the replacement elec. sender that was going to take 6 weeks to get here anyway.
_________________ Ross Alexander: CH701 driver 912ul 788tt
It only takes two things to fly, airspeed and money
Roger Lee
Posted: Thu Jul 08, 2010 5:15 am Post subject: Re: 912ULS Recommended Oil |
read this about oils then you'll know why certain oils are better than others.
You can't go wrong with the oils listed in the previous post.
Oil Comparison.pdf |
2.01 MB |
643 Time(s) |
Tucson, Az.
Cell 520-349-7056 |
flyadive(at)gmail.com Guest
Posted: Thu Jul 08, 2010 9:45 am Post subject: 912ULS Recommended Oil |
Ross:
As from my reading on AMSOIL they are ALL 100% Synthetic. They are NOT advertised as a 50/50 blend.
Many - Many years ago I did a study on model RC engines and ... Long story short --- 100% Synthetic is NOT the way to go. Synthetic is great for lubrication but that is only half the story. What oil MUST do is REMOVE the HEAT.
Your petroleum based oils do that NOT the Synthetics.
You also want to use something that is 20W 50.
There has been millions of words written about automotive oil in aviation engines... I have heard some Good and Bad reports.
The only thing that holds some... Not much water is: An aviation oil is designed with more ingredients to take care of the EP range of the oils. Aviation engines run at 65% to 75% power 95% of the time. Automotive engines run at 15% to 20% power 95% of the time. Much Less Load on automotive.
So, that is where I believe the problem could have originated from.
Barry
On Thu, Jul 8, 2010 at 8:37 AM, dashwood <dashwoodlock(at)hotmail.com (dashwoodlock(at)hotmail.com)> wrote:
[quote]--> RotaxEngines-List message posted by: "dashwood" <dashwoodlock(at)hotmail.com (dashwoodlock(at)hotmail.com)>
i am in need of oil advice too . you can follow some of the more recent post by me. the latest is a report from my ame that the gearbox is toast after 400hrs. i took it in for inspection of a leak in the front seal. the history that i can get to is 1992 to 99 engine was in a box in georgia usa, not sure if pickled proper or not. then installed and used for 200hrs on amsoil semi 10/40 . then i purchased airplane and used amsoil for a short time then switched to the mobil mx4 as a rotax recommended oil. baced on the parts list i was given the case is fine the rest not so good. worn parts and gear tooth galling. my next question is if gearbox is so bad ????? about the engine. what oil to use? what oil not to use?
Ross Aalexander: CH701 driver 912ul 398tt
http://forums.matronics.com/viewtopic.php?p=304153#304153
h as List Un/Subscription,
www.matronics.com/Navigator?RotaxEngines-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
Matt Dralle, List Admin.
rampil
Posted: Thu Jul 08, 2010 2:55 pm Post subject: Re: 912ULS Recommended Oil |
Barry,
Are you sure you want to offer opinions on the care of $20k aircraft
engines different from the factory, the service centers, and experienced
mechanics based on your experience in rc engines. Not many RC engines
have water cooled heads.
Synthetic oils are preferred in Rotax 900 series engines in general
and should not be used in the specific case of using AV Gas with lead.
Rotax adds and deletes oils to the Service Letter based on testing
and also on promotional/competitive reasons. Recently Mobil One for
Rotaxwas introduced as a synthetic which does not sludge in the
presence of tetraethyl lead. At SnF this year Rotax was highly promoting
this oil as the best available.
Roger Lee
Posted: Thu Jul 08, 2010 4:36 pm Post subject: Re: 912ULS Recommended Oil |
Full synthetic or semi synthetics oils for a 4 stroke engine are well above a standard dino oil for performance and high stress situations. This has been demonstrated by many institutions. Personally I would never put a dino oil in a high performance, high compression, close tolerance and gearbox sharing situation engine like the Rotax. As a Rotax mechanic I tear into enough of them and seen enough pictures from Rotax themselves to keep me in the synthetics and out of the pure dino oils.
Tucson, Az.
Cell 520-349-7056 |
daberti(at)sbcglobal.net Guest
Posted: Thu Jul 08, 2010 6:52 pm Post subject: 912ULS Recommended Oil |
The other factor in Rotax recommendations is foaming. With the average
system using only 3 liters of oil, foamed oil can easily enter the
pressurized side of the engine. Air compresses, fluids don't. Air in the
lifters causes collapsed lifters, loose pushrods that can then get bent and
hammered rocker arms. Air in the main galleys results in poor oil flow to
cam bearings and mains. Foam in the oil causes reduced pressure indications
and a jumpy needle on an analog gage.
I prefer the Mobil Racing (MX4T) but use Penzoil when stuck using 100LL such
as flying in the western states where the autogas is unavailable or just
inconvenient to transport.
Dave
dashwood
Posted: Fri Jul 09, 2010 4:04 am Post subject: Re: 912ULS Recommended Oil |
the oil analysis posted puts amsoil at the top of the list.... sponsored by amsoil ..go figure. the mobil oil in both 40 scored very low in the foaming category and reasonably high in most others. i wonder if this is as good an oil for th 9XX for this reason. the text indicates that anti foam capabilities is one of the most important factors in gear wear.
It only takes two things to fly, airspeed and money |
Dick Maddux
Posted: Fri Jul 09, 2010 4:19 am Post subject: 912ULS Recommended Oil |
Or...Or you could switch to Aeroshell plus 4 oil. It is made specifically for the 912 Rotax engine. It is a semi synthetic that can be used with auto fuel or avgas. Problem solved! That's all I use now. Lockwood uses it in their training aircraft and has it available. LEAF also carries it.
Dick Maddux
Fox 4,912UL
Milton,Fl
Roger Lee
Posted: Fri Jul 09, 2010 5:12 am Post subject: Re: 912ULS Recommended Oil |
That article is a few years old, but it was done by an independent tester. I was hoping that everyone one would take the article as an educational tool to see what the additives are and what they do. There have been a few changes and other oils added. If you use 100LL off and on then Aero Shell Sport Plus 4 would be a good addition to this group being a semi synthetic. They had a foaming issue at the beginning, but have taken care of that. The Rotax with the small oil tank can't tolerate high foaming oils.
Dave is exactly right about what can happen if you allow the oil level to get too low and or have a high foaming oil. The help combat oil foaming, which was worse many years ago, Rotax raised the oil level using a new dip stick by 30%. The old dip stick had a round handle where all the new ones are more square looking and the flat oil level zone is higher up the stick. This generally affected engine that are around the 5-6 year old and older engines.
Oil is the life blood of any engine so I don't scrimp here. I do my oil changes still at 50 hrs and not 100 hrs. If you do oil changes like this, and stay away from 100LL, except when you travel occasionally, then there is no reason you can't see 3000 plus hrs on a engine. Use 100LL all the time and you'll be doing a top end at 1000 hrs. and a gearbox sooner.
Tucson, Az.
Cell 520-349-7056 |
pchristensen10(at)austin. Guest
Posted: Fri Jul 09, 2010 5:33 am Post subject: 912ULS Recommended Oil |
AMEN Roger!. Aren't you tired of Tucson. Why not move to the Austin area
so I can hang out with you?
Pete
ex Pima County Deputy Sheriff
rampil
kevann(at)gotsky.com Guest
Posted: Fri Jul 09, 2010 6:14 am Post subject: 912ULS Recommended Oil |
I think this thread started with symptoms of gear box component wear, and is
focused only on oil used. It is my understanding (from a Rotax service
class) that gear box wear could very well be the result of running with
less than balanced carbs and or lots of excessive low idle running. The
thought being that rough running, vibration, is the cause of early gearbox
wear.
Is it possible that the first several hundred hours on this engine's gearbox
included less than ideal carb balance and idle?
Kevin
914 Europa
lucien
Posted: Fri Jul 09, 2010 2:22 pm Post subject: Re: 912ULS Recommended Oil |
| kevann(at)gotsky.com wrote: | I think this thread started with symptoms of gear box component wear, and is
wear.
Kevin
914 Europa
This one actually started with a direct "what oil should I use?", so straightaway I went and got the popcorn. You know it's going to be entertaining when that question comes up
As for gearbox wear, I'd put type of oil used near the bottom of the list of suspects and instead suspect poor carb balance and etc. like you say.
Also, don't forget these gigantic props a lot of guys put on these things, with these mile long extensions, etc. Remember the MOI spec on the 912 box is the same as 2-stroke C-box (6000 kg/cm2, IIRC), so you can't really get away with those 200lb monsters on the 912 any more than with the C box... I'm sure that's a culprit a lot of the time too in addition to rough or too slow of an idle, etc...
LS
Titan II SS |
Roger Lee
Posted: Fri Jul 09, 2010 2:36 pm Post subject: Re: 912ULS Recommended Oil |
As far as gearbox wear I'm with Kevin and Lucien.
Oils are like Chevy's and Ford's. You may like one not the other, but they both get you there.
Kevin,
I lived in Houston back in the mid 70's for 2 years and went back to Tucson. Too much mud, rain, mosquitoes and prejudice for me. I'm an outdoor boy and the first three made it hard to have fun. I forgot to mention and no mountains.
Tucson, Az.
Cell 520-349-7056 |
