sarg314(at)gmail.com Guest
Posted: Sat Jun 12, 2010 3:35 pm Post subject: fuel placards |
Does any one know a source for fuel filler placards that say "100LL only" ? I got a couple from aircraft spruce and they are much bigger than they need to be. It's the circular, doughnut-shaped type of placard. The placard is 6" in diameter - you could read it from 20 feet away. I've looked for something smaller, but haven't come up with anything yet. I thought Vans would sell something appropriate, but if they do, I can't find it in the on-line catalog.
Tom Sargent, RV-6A, trying to schedule the airworthiness inspection.
Posted: Sat Jun 12, 2010 4:24 pm Post subject: fuel placards |
Most people get the fuel cap engraved.
Here is one place that does it: http://www.rvengraving.com/
Carl Froehlich
RV-8A (540 hrs)
RV-10 (systems install)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Saturday, June 12, 2010 7:25 PM
To: rv-list
Subject: fuel placards
Tom Sargent, RV-6A, trying to schedule the airworthiness inspection. | Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
bobbyhester(at)newwavecom Guest
Posted: Sat Jun 12, 2010 4:34 pm Post subject: fuel placards |
http://www.aircraftspruce.com/catalog/cspages/fuelplacards.php
Local vinyl lettering shop can make one up cheap and quick
thomas sargent wrote: [quote]Does any one know a source for fuel filler placards that say "100LL only" ? I got a couple from aircraft spruce and they are much bigger than they need to be. It's the circular, doughnut-shaped type of placard. The placard is 6" in diameter - you could read it from 20 feet away. I've looked for something smaller, but haven't come up with anything yet. I thought Vans would sell something appropriate, but if they do, I can't find it in the on-line catalog.
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
dan.pat.b(at)gmail.com Guest
Posted: Sat Jun 12, 2010 5:01 pm Post subject: fuel placards |
TOM:IF I REMEMBER CORRECTLY I GOT SOME REAL SMALL LABELS AS PART OF AN EAA EXPERIMENTAL AIRCRAFT CERTIFICATION PAPERWORK PACKET. THERE WERE ALL KINDS OF INSTRUMENT PANEL LABELS AND SOME SMALL RECTANGULAR FUEL TANK "100 LL" LABELS. I EVENTUALLY HADE MY FILLER CAPS ENGRAVED WITH "100 LL - 21 GALS." INCIDENTALLY - THE FILLER CAP TENSION IS ADJUSTABLE. BE CAREFUL HOW MUCH TENSION YOU CRANK INTO THEM - TOO MUCH AND YOU'LL SNAP THE PINS - THEY'RE ROLLED AND NOT SOLID. IF YOU SNAP THEM THEY'RE EASILY REPLACED WITH CUT DOWN SHANKS FROM 1/16" DRILL BITS.
DAN BERGERON
RV-7A - N307TB
149 HOURS SINCE
FIRST FLIGHT ON 08/04/09
On Sat, Jun 12, 2010 at 7:25 PM, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
| Quote: | Does any one know a source for fuel filler placards that say "100LL only" ? I got a couple from aircraft spruce and they are much bigger than they need to be. It's the circular, doughnut-shaped type of placard. The placard is 6" in diameter - you could read it from 20 feet away. I've looked for something smaller, but haven't come up with anything yet. I thought Vans would sell something appropriate, but if they do, I can't find it in the on-line catalog.
==== t="_blank">http://www.matronics.com/Navigator?RV-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution [/b] | [b]
Gary.A.Sobek
Posted: Sat Jun 12, 2010 6:38 pm Post subject: fuel placards |
I had mine engraved WITHOUT my N number. IF they fall off in flight and hit someone, it will not be traceable back to me.
Others had good answers.
Brother Label makers make good labels that meet the FAA requirement, they last a long time plus are cheap to replace.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,377+ Flying Hours So. CA, USA
Date: Sat, 12 Jun 2010 16:25:20 -0700
To: rv-list(at)matronics.com
| Quote: | | <//www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?R========== | Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. [quote][b]
