Seeing Matronics List Attachments
bakerocb
PostPosted: Sun Jun 13, 2010 5:13 am    Post subject: Seeing Matronics List Attachments Reply with quote
bakerocb
PostPosted: Mon Jun 21, 2010 3:54 am    Post subject: Seeing Matronics List Attachments Reply with quote
6/21/2010
Hello Fellow KIS Listers, I wrote: " PS: There is sort of a gotcha. I posted
a jpg picture on the KIS list (see here I hope):
http://forums.matronics.com/viewtopic.php?t=71560
and the picture posted just fine except that its layout on the forum was
so huge such that one had to scroll all over the place to find the area of
interest."
I have modified (shrunk) the original posted vortex generator picture
significantly. Please see if this attached view is better for you.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
 Filesize:  189.87 KB
 Viewed:  5435 Time(s)
ftyoder(at)yoderbuilt.com
PostPosted: Mon Jun 21, 2010 6:04 am    Post subject: Seeing Matronics List Attachments Reply with quote
'OC',
What are your test results? ( On the vortex generator. )
Tim
lgdavid(at)roadrunner.com
PostPosted: Mon Jun 21, 2010 2:09 pm    Post subject: Seeing Matronics List Attachments Reply with quote
OC, you can shrink the display of the picture by holding the control key down and pressing the minus key a couple of times. (This works in Firefox and I assume other browsers.) Of course the accompanying text will shrink also. It looks like the device is about 6-8 inches in front of the leading edge of the tail and the device itself is about 6-8 inches long. Am I guessing right on the sizing? Larry
On 6/21/2010 4:53:24 AM, bakerocb(at)cox.net (bakerocb(at)cox.net) wrote:
[quote] 6/21/2010
bakerocb
PostPosted: Mon Jun 21, 2010 7:24 pm    Post subject: Seeing Matronics List Attachments Reply with quote
6/21/2010
Hello Larry, Thanks for the picture tip.
These vortex generators go on each side of the fuselage in front of the
wing. Their purpose is to generate higher energy air in the area of the wing
to fuselage juncture.
They are more on the order of 4 inches long -- that is all the aluminum
angle that I had available.
Take a look at the ones on the Cirrus airplanes to see what I am trying to
replicate.
