Resistor too hot?
donjohnston
PostPosted: Sat Jun 12, 2010 12:27 pm    Post subject: Resistor too hot? Reply with quote
I'm planning on using some LED strips for courtesy lighting. I found a 19" strip with 30 LEDs that draw 130mA at 12v. Since I'm going to using a 24v system, I'm going to need to use a resistor.
So using 28v as the supply with a voltage drop of 12v and a current of 130mA gave me a 123 ohm 2 watt resistor. I have access to some 123 ohm, 2 watt, metal film resistors so I tried those.
When I set it up on the breadboard the current was reading 100ma but the resistor was almost immediately too hot to touch. Using a point and shoot thermometer (not the most accurate for this) showed 120 degrees within about 1 minute and after 5 minutes it was up to 140 degrees.
Now I don't expect these lights will stay on much longer than 5 minutes as they will most likely be used during loading and unloading but that heat doesn't seem right.
How hot is too hot for a resistor?
Should I bump up to a 5 watt resistor?
Did I miscalculate?
Don
N20DG
PostPosted: Sat Jun 12, 2010 1:06 pm    Post subject: Resistor too hot? Reply with quote
In a message dated 6/12/2010 3:32:06 P.M. Central Daylight Time, don(at)numa.aero writes:
Where
Tks
Dick
PostPosted: Sat Jun 12, 2010 1:11 pm    Post subject: Resistor too hot? Reply with quote
At 03:27 PM 6/12/2010, you wrote:
--> AeroElectric-List message posted by: "donjohnston" <don(at)numa.aero>
I'm planning on using some LED strips for courtesy lighting. I found a 19" strip with 30 LEDs that draw 130mA at 12v. Since I'm going to using a 24v system, I'm going to need to drop use a resistor.
Did I miscalculate?
No. The normal "full power" operating temperature
for some power resistors is pretty toasty. Typically
over 100C (will sizzle spit).
For example:
[img]cid:.0[/img]
Here'a de-rating curve for a typical metal film power resistor.
Note that it's good for 100% of power rating at 70C ambient.
When ambient rises to about 225 degrees C (that's
really toasty), you cannot call upon the device to handle
ANY power. I.e., At full power in a 70C environment, one
can expect the surface temperature to be over 200C.
The specifications for your resistor of choice should
be available on the 'net . . . but it's unlikely that
you've got a problem with respect to the resistor itself.
A significant risk for incorporating high power devices
into a system may not be for the device itself but for
surrounding devices and/or materials that will degrade
in performance when subject to local heating.
 Filesize:  52.38 KB
 Viewed:  7384 Time(s)
mdnanwelch7(at)hotmail.co
PostPosted: Sat Jun 12, 2010 1:26 pm    Post subject: Resistor too hot? Reply with quote
Did I miscalculate?
Don
Don,
From what I see, and according to the information you stated, no, you didn't miscalculate. A 12 volt forward voltage does sound high, though. Most LEDs have a forward voltage in the 2 volt range. Hmm?
From my experience with LEDs, why not just give a higher resistor a try? The only thing
a higher resistor will affect is the luminosity of the LED, and from my experience it takes a lot more resistance to reduce the brightness any significant degree. Why not try 330 ohm resistors, or maybe even some 470's? Just a thought....
Mike Welch
The New Busy is not the old busy. Search, chat and e-mail from your inbox
donjohnston
PostPosted: Sat Jun 12, 2010 1:34 pm    Post subject: Re: Resistor too hot? Reply with quote
Mike,
It's not a single LED, it's a strip of 30 LEDs. According the information, they're designed for a 12v supply.
Spec's are here:
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2FFLS.htm
It's the first one one the list (xFLS-CW30).
Sounds like I'm okay. I just need to figure out where to mount the resistor so the heat isn't an issue.
-Don
rparigoris
PostPosted: Sat Jun 12, 2010 3:07 pm    Post subject: Resistor too hot? Reply with quote
Hi DonJust a thought, can you find two light strips you can put in series? Do you have a Pep Boys automotive store near you? They sell various length LED light strips, I have one that is bout half the length you want to use. There is a good chance on your light strip you have if it is like picture on website, there are 3 LEDs in series with a resistor. If you made a cut of wires at the 15 LED mark and put them in series instead of parallel you could get rid of your resistor all together.Ron Parigoris [quote][b]
enginerdy(at)gmail.com
PostPosted: Sat Jun 12, 2010 5:30 pm    Post subject: Resistor too hot? Reply with quote
Or, use a resistor like this:
http://mouser.com/ProductDetail/Ohmite/TBH25P150RJE/?qs=sGAEpiMZZMvhlCB8CTbT5P3ZZcE9WVSjJn%252bo%252b5MXx0c%3d
Screw that down to some convenient large piece of metal and it will stay much cooler. Just be sure to heat-shrink the leads so they don't short to the heat sink surface. The tab is electrically insulated, so there's no need for a mica sheet underneath it.
--Daniel
On Jun 12, 2010, at 6:04 PM, rparigor(at)suffolk.lib.ny.us (rparigor(at)suffolk.lib.ny.us) wrote:
Hi Don
Ron Parigoris
