n277dl
Posted: Tue Jun 08, 2010 11:17 am Post subject: Misc topics... First flight, Insurance, Rudder lock |
Group...
First things first. We made the first flight of N277CK, kit # 40761 over the Memorial Day weekend. Flys great. (There are some pictures at dougandlinda.smugmug.com in the rv10-all folder. Look to the end if interested.) Burning fuel most every night. Following the general path of AC90-89B test flights.
For a reference point for John's earlier post, my insurance quote went up around $1,000 for $175k hull from Dec to June. I'm about a 1000 hour instrument rated SEL with around 500 hours in a RV7A.
Most important question... Any recommendations for a good rudder lock for the -10. I used the spring loaded rod that fits on the rudder pedals for the -7A. Unfortunately, I also now have a 3 inch hole covered with duct tape in the rudder surface of the 7A where this lock failed to hold and the rudder stops broke after the rudder flopped around in the wind.
Doug
_________________ Doug
"Fools" are always more creative than process people and will always find ways to ruin a perfectly good set of processes. |
Albert Gardner
Posted: Tue Jun 08, 2010 1:07 pm Post subject: Misc topics... First flight, Insurance, Rudder lock |
If you like simple and cheap but effective this might work. After strapping
back the stick I install this restraint. I used it on my 9A also. On the 9A
I started out with the clip installed that others have pics of (holding the
rudder pulled completely to the side) but liked this better.
Albert Gardner
N991RV
Yuma, AZ
22.8 KB |
8339 Time(s) |
24.41 KB |
8339 Time(s) |
23.71 KB |
8339 Time(s) |
26.3 KB |
8339 Time(s) |
RV-10 N991RV |
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Jun 08, 2010 4:52 pm Post subject: Re: Misc topics... First flight, Insurance, Rudder lock |
No pics, but I have come up with a rudder lock system very similar to Alberts and it works quite well. I thought about building one of the locking systems out of PVC pipe that goes around the whole vert. stab and rudder, but really did not want to carry that around in the airplane.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
dave.saylor.aircrafters(a Guest
Posted: Thu Jun 10, 2010 9:02 am Post subject: Misc topics... First flight, Insurance, Rudder lock |
Here's our latest iteration. Best one we've used yet, simple, cheap.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Jun 8, 2010 at 2:06 PM, Albert Gardner <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
[quote] If you like simple and cheap but effective this might work. After strapping
Albert Gardner
N991RV
Yuma, AZ
75.95 KB |
8297 Time(s) |
79.73 KB |
8297 Time(s) |
78.7 KB |
8297 Time(s) |
78.95 KB |
8297 Time(s) |
n277dl
Posted: Thu Jun 10, 2010 1:47 pm Post subject: Re: Misc topics... First flight, Insurance, Rudder lock |
Thanks for the input.
Dave, is the only modification to the tow bar welding a tip that fits between the brake pedal and the rudder bar?
Doug
