jchang10
Posted: Tue Jun 01, 2010 5:13 pm Post subject: Nose gear fairing trim for IO-540 only |
Just to satisfy my curiosity, i am wondering about page 48-23, the nose fairing template has a line that says "Trim here for IO-540 left side only". I can't see why the cutout is needed. Does anyone know?
Jae
#40533
coop85(at)verizon.net Guest
Posted: Tue Jun 01, 2010 6:40 pm Post subject: Nose gear fairing trim for IO-540 only |
Might be for the starter but it's been quite awhile and I don't have my
plans handy. I'm sure someone with a more useful answer will chime it.
Marcus
Do not archive 'cause it's probably bad info.
toaster73(at)embarqmail.c Guest
Posted: Tue Jun 01, 2010 6:43 pm Post subject: Nose gear fairing trim for IO-540 only |
Prop governor
-Chris
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Tue Jun 01, 2010 6:58 pm Post subject: Re: Nose gear fairing trim for IO-540 only |
I thought it was for the vent hanger fairing that is on one side coming down the middle bottom of the cowling. I'm not sure, I don't have my plans in front of me.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Tue Jun 01, 2010 7:53 pm Post subject: Nose gear fairing trim for IO-540 only |
The bracket that holds the bottom fairing in the center (basically the gap
between the gear and bottom fusellage) is in that location.
Pascal
#40720
so close to starting to finish
Sent: Tuesday, June 01, 2010 6:13 PM
Subject: Nose gear fairing trim for IO-540 only
Jae
#40533
http://forums.matronics.com/viewtopic.php?p=299662#299662
jchang10
Posted: Tue Jun 01, 2010 8:31 pm Post subject: Nose gear fairing trim for IO-540 only |
oh, yeah, i forgot about that bracket. thanks!
Jae
On 6/1/2010 8:52 PM, Pascal wrote:
gap between the gear and bottom fusellage) is in that location.
Pascal
#40720
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
partner14
Posted: Wed Jun 02, 2010 6:25 am Post subject: Nose gear fairing trim for IO-540 only |
Pascal, and group.... Make a new bracket to support the bottom cowl... heavier material, and wider.... otherwise it WILL break. I was just installing the one I made (of course I made several) and Mark Carey came by to ck on my progress.... and said his just broke.
Texas status:
Kim made it to the Pecan Platation here in Texas about an hour before I did. About 1,400 miles.... two 4 hour flights seperated by a short refueling stop. No problems... with the exception of the one towering cumulous, that I thought contained no lightning.... at least until I was skirting the edge.... then lighning,.... then I turned to create more distance between it and me... and I succeeded in escaping.
Will keep in touch. Don
--- On Tue, 6/1/10, Jae Chang <jc-matronics_rv10(at)jline.com> wrote:
Subject: Re: Nose gear fairing trim for IO-540 only
Date: Tuesday, June 1, 2010, 9:30 PM
--> RV10-List message posted by: Jae Chang <jc-matronics_rv10(at)jline.com (jc-matronics_rv10(at)jline.com)>
Jae
40636 |
