Neal.George(at)hurlburt.a Guest
Posted: Mon May 24, 2010 6:44 am Post subject: Exhaust |
Listers –
I have a friend’s RV-4 apart for the annual Condition Inspection. It has a Lyc O-360-A3A adapted with up-draft Airflow Performance injector servo and what I believe is a Vetterman cross-over exhaust.
The exhaust hangers are broken in several places – have been for some time. I’d appreciate some photos or words describing exhaust hangers that seem to work well on the -4 and withstand the punishment…
Neal George
Navarre, FL
| | - The Matronics RV4-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV4-List |
smime.p7s |
5.09 KB |
779 Time(s) |
WGUNN(at)dot.state.tx.us Guest
Posted: Mon May 24, 2010 7:32 am Post subject: Exhaust |
Four pipe Vetterman system RV 4 - 870 hours to date - rubber connectors are rubber heater hose sections - note on both sides of the hangar. Make sure there is NO tension or load on the hangars when you support them.
| Quote: | >> "George, Neal E Capt USAF ACC 505 TRS/DOJ" <Neal.George(at)hurlburt.af.mil> 5/24/2010 9:38 AM >>>
Listers -
I have a friend's RV-4 apart for the annual Condition Inspection. It has a Lyc O-360-A3A adapted with up-draft Airflow Performance injector servo and what I believe is a Vetterman cross-over exhaust.
The exhaust hangers are broken in several places - have been for some time. I'd appreciate some photos or words describing exhaust hangers that seem to work well on the -4 and withstand the punishment.
Neal George
Navarre, FL
| Quote: | ====================
Buckle up!
Safety belts and child safety seats save lives, prevent injuries,
and can also keep you from getting a ticket.
Click It or Ticket |
185.45 KB |
6745 Time(s) |
bluesidedown
Posted: Mon May 24, 2010 9:43 am Post subject: Exhaust |
I used something similar but used exhaust hangars from Summit Racing for my RV4 and my other planes. Take a look all kinds of different styles.
[url=http://www.summitracing.com/search/Department/Exhaust/Part-Type/Exhaust-Hangers/?Ns=Rank|Asc]http://www.summitracing.com/search/Department/Exhaust/Part-Type/Exhaust-Hangers/?Ns=Rank|Asc[/url]
From: owner-rv4-list-server(at)matronics.com [mailto:owner-rv4-list-server(at)matronics.com] On Behalf Of Bill Gunn
Sent: Monday, May 24, 2010 11:18 AM
To: rv4-list(at)matronics.com
Subject: Re: Exhaust
Listers -
Neal George
Navarre, FL
[quote]====================
Buckle up!
Click It or Ticket[b]
martinaerodrome(at)gmail. Guest
Posted: Wed May 26, 2010 5:08 am Post subject: Exhaust |
Neal,
I experienced this with my RV8 8 plus years ago when I flew off the initial flight testing. I tried several things that did not work. I then went to the local hardware store and purchased some 2
compression springs approx. 2 inches long wound from approx. 100 thousands wire and approximately 3/4 inch diameter. I made band type loop hangers to connect springs to the exhaust pipe and the engine mount legs. The springs absorb the shock from landings etc. ( I fly from a grass field (bummpy). I now have 9 years and 1900 hours on this set up. Good Luck.
Dick Martin
RV8 N233m
the fast one
On Mon, May 24, 2010 at 9:38 AM, George, Neal E Capt USAF ACC 505 TRS/DOJ <Neal.George(at)hurlburt.af.mil (Neal.George(at)hurlburt.af.mil)> wrote:
Listers –
Neal George
Navarre, FL
