Lycoming 0-235 crankshaft end play
gil
PostPosted: Sun May 23, 2010 2:07 am    Post subject: Lycoming 0-235 crankshaft end play Reply with quote
When I push or pull on the propeller hub I notice some end play, is this normal? If so how much end play is normal?
dsleepy47
PostPosted: Sun May 23, 2010 6:02 am    Post subject: Lycoming 0-235 crankshaft end play Reply with quote
You need to verify in the overhaul manual but the numbers I have for the O-290 which is in the same family is manufacturing limits of 0.009 - 0.016" and max service limit of 0.026".
Deems
Subject: Lycoming 0-235 crankshaft end play
Date: Sun, 23 May 2010 03:07:18 -0700
To: lycomingengines-list(at)matronics.com
The New Busy is not the old busy. Search, chat and e-mail from your inbox
dsleepy47
N1491R
