Terminating Coax Cable to VOR Antenna
bobair(at)me.com
PostPosted: Thu May 20, 2010 7:39 pm    Post subject: Terminating Coax Cable to VOR Antenna Reply with quote
I have a RAMI AV-12 VOR antenna that has the two machine screws/studs for electrical connection to the coax cable -- it doesn't take a BNC twist-on connector. I believe the coax that I have is a double shielded type but it isn't RG400 -- it has a bright yellow outer jacket.
How do I terminate this coax cable to this antenna? Do I just crimp PIDG terminals (or solder suitable lugs?) to the braided shield and to the center conductor? I'd also use some heat-shrinked tubing. Is anything more than this required?
Best regards,
Bob Falstad
GlaStar N248BF
310 Hours in two years
PostPosted: Fri May 21, 2010 3:45 am    Post subject: Terminating Coax Cable to VOR Antenna Reply with quote
How did you acquire the ooax? Did it come with the
antenna as a kit?
Yes, make the lengths of these leads as short as practical.
Nope.
Neal.George(at)hurlburt.a
PostPosted: Fri May 21, 2010 3:56 am    Post subject: Terminating Coax Cable to VOR Antenna Reply with quote
Bob -
Connectors appropriate to the antenna's lugs, either crimped or soldered
will do just fine. Keep the length of exposed center conductor to a
minimum. Support the cable with a clamp very near the end of the jacket,
fastened to the airframe to provide strain relief and vibration protection.
Neal
this required?
Best regards,
Bob Falstad
GlaStar N248BF
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  546 Time(s)
Eric M. Jones
PostPosted: Fri May 21, 2010 4:41 am    Post subject: Re: Terminating Coax Cable to VOR Antenna Reply with quote
For frequencies near or above 1 MHz, coaxial cables are best terminated with a connection method that is easy to make or buy that avoids the unnecessary losses in pigtailing the shield.
Yes, you can "get away with" pigtails, but Google "Kimmel Gerke pigtails" and learn how to do this important task....
And see my "Dabbling with Electricity...It's Child's Play" attached for more explanation. (I have also attached for your pleasure the Popular Mechanics 1943 Army Test.)
Army Test.pdf
1943 Army Test
 Filename:  Army Test.pdf
 Filesize:  327.91 KB
 Downloaded:  528 Time(s)
Dabbling with electricity.pdf
 Filename:  Dabbling with electricity.pdf
 Filesize:  139.87 KB
 Downloaded:  552 Time(s)
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
mdnanwelch7(at)hotmail.co
PostPosted: Fri May 21, 2010 4:49 am    Post subject: Terminating Coax Cable to VOR Antenna Reply with quote
How did you acquire the coax? Did it come with the
antenna as a kit?
Bob,
  Yes, it does.   One of the two experimental planes I'm building is a GlaStar.  When ordering some of their options, I got the dipole com radio antenna kit.  Evidently, whoever they have build their antennas likes to use this triax cable.
  I got the com antenna fastened to the inside of the vertical stabilizer, and glued the two halves of the plane together.  I forgot to look at how they handle the antenna end of the cable, that's why I asked previously about the balun information.
  In the present topic, do I understand correctly that you combine the inner and outer shields together on the solder lug, at the antenna end?
Mike Welch
The New Busy is not the too busy. Combine all your e-mail accounts with Hotmail. Get busy. [quote][b]
PostPosted: Fri May 21, 2010 5:08 am    Post subject: Terminating Coax Cable to VOR Antenna Reply with quote
> antenna as a kit?
> Bob . . .
Bob,
Just making sure it wasn't some form of ohterwise
un-identified cable . . .
Adding the balun is a technically satisfying thing
to do for this style antenna but will offer no
observable improvement in your VOR system performance.
In the present topic, do I under stand correctly that you combine
Yes, you can do that. But if you do the elegant
breakout of the center conductor through the shields
like . . .
http://aeroelectric.com/articles/shldwire/shldwire.html
. . . you'll find that the bulk of strand for
two sets of shields demand a rather hunky
PIDG terminal. This is an exceedingly non-critical
application that doesn't really benefit from
double-shielding. At the antenna end, you can
simply cut away all of the outer shield at the
outer jacket and terminate only the inner shield
as suggested above.
