Bussman ATC fuse terminal removal tool
rv8iator
PostPosted: Thu May 20, 2010 5:41 am    Post subject: Bussman ATC fuse terminal removal tool Reply with quote
Cooper-Bussman panel mount ATC fuse blocks:
The BUSSMAN part number for the terminal removal tool is HT15710-01. See attached Bussman document.
I purchased mine from Waytek
http://order.waytekwire.com/
Also see:
http://tinyurl.com/2f6exx3
which is:
http://www.kirbyrisk.com/index.jsp?path=product&part=547215&ds=dept&N=0&Nf=&D=HT15710-01&Dx=mode+matchpartial&Nty=1&Ntx=mode+matchpartial&Ntk=primary&Ntt=HT15710-01&Ne=10000&No=0#
Also attached is a drawing for making your own tool.
chris stone
RV-8 Oregon
>Hello Chris,
>I am wiring my GlaStar panel right now and my fingers still hurt from
>removing fast ons ...
>So it was a great relief reading in Your AeroElectric-List post that a
>terminal removal tool exists ! Would You be so kind and give me a hint where
>I can order it ? Is "terminal removal tool" the correct name for searching
>it ?
>Thank You very much for Your help Heinz
>Heinz Staehli
>Hauptstr. 44
>8872 Weesen SG
>Switzerland
>Tel: ++41 55 616 1828
>Cell: ++41 79 616 1071
>Time: 06:25:11 AM PST US
>From: Chris Stone <rv8iator(at)earthlink.net>
>Subject: Bussmann fuse blocks
>Jef...
>The Bussman fuse blocks use separate terminals that are crimped to the wire
>then
>inserted into the fuse block. This requires the use of the appropriate
>crimper.
>The terminal is what determines the wire size. The terminals are sized
>for a range of wire sizes. Most of the connections require the 18-22 size
>terminals
>as most feeders are in this range. The max. wire size terminals are #10
>which is typically fused at 30 amps which is more suitably fused with a
>separate
>maxi fuse or fusable link. The 10-16 size terminal crimp to #16 wire very
>well. The only problem I had was crimping #22. The tabs that form the
>crimp
>on the terminal are too large to reliably crimp this small a wire. I
>carefully
>soldered the end of the wire opposite the end that exits the terminal being
>careful not to allow solder to wick down the wire past the end of the
>terminal.
>(This will cause the wire to become solid and drastically increase the
>likelihood of fatigue failure at the terminal/wire interface).
>There are no installation instructions as to the insertion of the terminals
>into
>the block. For me it required trial and error with a couple of spare
>terminals
>to figure out the correct insertion orientation. Be sue to get the terminal
>removal tool (it looks like a very small (10mm wide) two pronged fork).
BussmanTerminalBlock.pdf
 Filename:  BussmanTerminalBlock.pdf
 Filesize:  144.98 KB
 Downloaded:  782 Time(s)
BussmanTermTool.pdf
 Filename:  BussmanTermTool.pdf
 Filesize:  181.28 KB
 Downloaded:  708 Time(s)
C. Stone (RV8iator)
esco
PostPosted: Mon Oct 19, 2026 6:01 pm    Post subject: Re: Bussman ATC fuse terminal removal tool Reply with quote
From Eaton's support team, Oct 2026:
"... The best removal tool for our 15700-RTA Fuse Panel is two small flat blade screwdrivers. See attached.
I have attached a drawing of the HT15010-01 tool, it has been flagged obsolete in our system. Not sure it was ever purchased or very rarely if so.
I just use my old Delphi pick tools from back in the days of my harness building. Just don’t forget to gently bend the terminal locks back out if reusing the terminal in another cavity..."
HT15710-01-SALES.pdf
 Filename:  HT15710-01-SALES.pdf
 Filesize:  81.1 KB
 Downloaded:  36 Time(s)
RTA Terminal Removal.pdf
 Filename:  RTA Terminal Removal.pdf
 Filesize:  67.05 KB
 Downloaded:  32 Time(s)
