Matco brakes break in procedure
Tom Jones
PostPosted: Mon May 17, 2010 5:20 am    Post subject: Matco brakes break in procedure Reply with quote
Can someone tell me the procedure to break in new matco brake pads? I can only find it on the Matco web site which is to taxi 30 to 40 mph and then brake to 5 mph a few times. I don't want to taxi that fast.
Somewhere I read that the procedure on a kitfox is to taxi a certain speed and distance while applying some break pressure but I can't find that now. I seem to get everything but brake information when I search for this.
Tom Jones
Classic IV
Ellensburg, WA
kirkhull(at)kc.rr.com
PostPosted: Mon May 17, 2010 5:37 am    Post subject: Matco brakes break in procedure Reply with quote
Breaking from 40 to 5 sounds like a normal landing. So 3 or 4 full stop
landings should do it
Tom Jones
PostPosted: Mon May 17, 2010 1:35 pm    Post subject: Re: Matco brakes break in procedure Reply with quote
Kirk, I was thinking about just normal landings too but I got the impression that the brake pads need to get fairly hot. They would probably be cooled down between landings. They emphasize not to come to a full stop between breaking actions during the procedure also and to release brake pedal pressure as soon as you park after the procedure and wait until the disk is cool to the touch before using them again.
It seems to me the procedure was in my builders manual but I can't find it now so maybe not.
Tom Jones
Classic IV
Ellensburg, WA
Roger Lee
PostPosted: Mon May 17, 2010 3:13 pm    Post subject: Re: Matco brakes break in procedure Reply with quote
Hi Tom,
You don't have to taxi that fast. You are only trying to heat the pads up to a certain temp. Just taxi 15mph and drag the brakes for about 10-15 minutes. You don't need to stop, just heat them up. After I get done with that little procedure I try a few hard stops. The next 6 or so landings don't baby them use them to stop fairly quickly, but don't try to stop real hard. They will get better and better during the first 6 or so landings. I have mounted and installed at least 40+ Matco brake sets and have never had any issue.
Matco recommends Loctite 567 to seal all you brake application threads. I use it and have never had a leak. I have tried other things in the past and had oozing past the threads. This heating procedure will increase the brake performance by 50%.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
temco(at)telusplanet.net
PostPosted: Mon May 17, 2010 3:22 pm    Post subject: Matco brakes break in procedure Reply with quote
Tom
Here is Matco's break in procedure --- I got it from Matco's site.
Cheers
Ted Palamarek
Edmonton
KF-IV/9`12UL
Question:
Why do my brakes feel spongy or weak?
Answer:
Check to ensure that there is no air in the system. Air can be trapped in
any high spot in the line and often cannot be "pumped" out. Ensure no high
spots during bleeding. The following bleeding procedure may be used:
Check to ensure that your linings have been adequately broken in using a
standard break in procedure. Your lining should produce a shiny transfer
layer if properly conditioned. The following procedure should be adequate to
condition the linings: 1) Apply brake pressure for high throttle static
run-up. Note RPM at creep if any. 2) Perform 2-3 high-speed taxi runs (firm
braking from 30-40 mph to 5 mph) to generate 300-400 degrees at brake pads.
Do not bring aircraft to a complete stop during the taxi runs and also allow
the aircraft to roll until back to the tie down area. Release brake pressure
at tie down area as soon as practicable and park with brake pressure off. 3)
Allow brakes to cool 10-15 minutes. 4) Repeat step 1. There should be a
noticeable increase in holding torque. Repeat steps 1-3 if necessary.
Properly conditioned pads and discs will have a uniform, shiny appearance on
the surface.
Tom Jones
PostPosted: Tue May 18, 2010 5:53 am    Post subject: Re: Matco brakes break in procedure Reply with quote
Okay thanks everyone. I'll give taxiing with brakes dragging a try. Roger, and everyone else too, what I am doing is breaking the pads in after sandpapering the disks and pads to rejuvenate them.
Tom Jones
Classic IV
Ellensburg, WA
Roger Lee
PostPosted: Tue May 18, 2010 6:11 am    Post subject: Re: Matco brakes break in procedure Reply with quote
here is what I use for a brake bleeder. works like a charm. and it is only about $10. I picked it up at Ace Hardware. One of the best things I ever bought. It makes bleeding brakes very easy and fast. It blows out all the air bubbles.
Brake Bleeder
 Filesize:  295.48 KB
 Viewed:  15361 Time(s)
Brake Bleeder
 Filesize:  285.91 KB
Roger Lee
Tucson, Az.
Cell 520-349-7056
icubob(at)gmail.com
PostPosted: Tue May 18, 2010 9:52 am    Post subject: Matco brakes break in procedure Reply with quote
why not just give george a call?
                 bob noffs
On Tue, May 18, 2010 at 8:53 AM, Tom Jones <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)> wrote:
[quote]--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=298061#298061
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
Matt Dralle, List Admin.
Tom Jones
PostPosted: Wed May 19, 2010 1:38 pm    Post subject: Re: Matco brakes break in procedure Reply with quote
I did the break in this morning. Before I started I held the brakes and increased engine power until the plane started to creep. At 5000 rpm I couldn't hold it. Then I taxied at 5000 RPM holding firm pressure on the brakes to keep speed about 10 mph for about 200 yards. Then I let it roll to a stop without using the brakes. The disks were too hot to touch when I first got out.
After the break in run and letting the brakes cool down I tried a static run up again and was able to easily hold it with full (6200 rpm) engine power.
Tom Jones
Classic IV
Ellensburg, WA
Float Flyr
PostPosted: Wed May 19, 2010 4:59 pm    Post subject: Matco brakes break in procedure Reply with quote
The trick is not to build up too much heat... You do that basically by clow
taxiing with minimal but consistent brake application. It's well worth
doing.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
jridgway
PostPosted: Sun May 23, 2010 6:41 pm    Post subject: Re: Matco brakes break in procedure Reply with quote
Roger,
I am having a heck of a time bleeding all the air out of my duel MATCO brakes. Can you explain your procedure using the ACE pump.
Can I get your phone/email so I can chat more.
thanks..jack Crying or Very sad Crying or Very sad
