jim.naylor(at)talktalk.ne Guest
Posted: Fri May 14, 2010 3:52 am Post subject: Outrigger leg failure |
We have had a recent failure of the nylon outrigger legs on our mono. The material seems to have gone brittle and simply snapped, despite 14 years of service during which they have been subject to quite sever bending on numerous occasions when landing and taxing on rough strips without incident. They failed towards the end of a landing run on reasonably smooth grass after a smooth touchdown on a lightly loaded aircraft, so they were not subjected to any abnormal loads. There is no sign of previous cracks or damage, they have simply snapped like match sticks.
I recall reading about some failures in cold climates, but have not heard of any problems in warmer climes. As most people know we have had a quite severe winter in the UK as far as I can remember the coldest since our Europa has been flying. So the question is, has the properties of the material changed due to being exposed to sub zero temperatures, or has it work hardened or age hardened? On the day they failed the temperature was about 12C, so one would expect the material to have regained its flexibility.
Any one else had problems?
Also any alternate material suggestions?
Jim
rampil
Posted: Fri May 14, 2010 5:09 am Post subject: Re: Outrigger leg failure |
Nylon slowly depolymerizes in sunight leading to embrittlement,
and 14 years of service should have slowly accumulated a number
of small cracks due to constant flexing loads.
Shouldn't these components be replaced at some interval?
pete(at)lawless.info Guest
Posted: Fri May 14, 2010 5:49 am Post subject: Outrigger leg failure |
Jim
Do I read this right – both legs failed on the same landing?
No damage done I hope?
pete
kevann(at)gotsky.com Guest
Posted: Fri May 14, 2010 6:53 am Post subject: Outrigger leg failure |
Jim,
I too have brought up this subject after several failures. There were lots of replies of lots of failures. Some say replace the nylon legs annually. I believe that nylon is just not the right material for this application.
"There is no sign of previous cracks or damage, they have simply snapped like match sticks." I don't like that failure mode. I have had several failures, one of which ended with taking out my Airmaster Prop. That really hurt.
"Also any alternate material suggestions?" I am testing out some legs made out of 5/8" fiberglass rod material from McMaster-Carr.
I did some load testing in the shop to find that this 5/8" diameter rod has almost the same flex under the same load as the 1 1/4" nylon. However, it has a very different failure mode. It of course does not simply shatter like the nylon. The fibers in tension (on the "leading edge" of the installed leg flexing back) start to snap and separate from the rod. It is a more gradual failure. I think partial damage will show easily during preflight inspection, but I have not yet seen any.
I have attached a drawing that shows the "bushings" that were made (from broken nylon legs) so the thinner fiberglass rod fits in our OR-1 and wheel fork. The complete legs are about 3 ounces lighter,each.So far they are doing well. I just installed them last month before flying to Florida from California and back.
Now I am making new wheel forks to run 105mm inline skate wheels. These will have 5/8" ID tube so the lower nylon socket won't be needed.
UpperPogoNylonBushing.pdf |
20.73 KB |
402 Time(s) |
fklein(at)orcasonline.com Guest
Posted: Fri May 14, 2010 7:20 am Post subject: Outrigger leg failure |
On May 14, 2010, at 7:17 AM, Kevin Klinefelter wrote:
| Quote: | | I too have brought up this subject after several failures. There were lots of replies of lots of failures. Some say replace the nylon legs annually. I believe that nylon is just not the right material for this application. |
Kevin,
I salute you for your analysis and thoughtful testing of an alternative to the nylon, as well as your idea to fabricate new wheel forks to match up w/ the skinny wheels...quite intriguing.
Fred
roberthatton1(at)googlema Guest
Posted: Fri May 14, 2010 7:59 am Post subject: Outrigger leg failure |
I had the starboard outrigger fail during a landing in January. This happened on a final landing after two other successful landings within the past hour of flying (none of the landings were touch and goes). I cannot remember the exact temperature but there was snow on the ground and I put the failure down to a combination of dry climate (I am based in Colorado USA) and cold temperatures making the leg brittle. Certainly the landing seemed fine and smooth and the leg just broke during the deceleration phase and not during the actual aircraft to ground contact phase of landing.
After my first landing during the taxi back on the taxi-way, the outrigger that failed did get stuck briefly in a pile of snow, which I guess in hindsight would not have helped, although I completed a successful landing after this had happened. I had replaced the legs within the last two years and they were direct from the factory.
The moment the outrigger departed and the wing dropped to the ground made me feel sick – the Airmaster propeller and gearbox had just been replaced on the aircraft and I was fully expecting the propeller to contact the runway. This all happened in an instant and I was concentrating on trying to keep the falling wing up with opposite aileron, steer straight and brake without nosing over so had no hands left to shut the engine down.
It then became obvious that the propeller was ok and had not contacted the runway – which was a huge relief. Although I was fully expecting the underside of the wing to be a mess. Once I had stopped I had time to run the engine for a couple of minutes to correctly shut it down before hopping out to inspect the worst. Amazingly there was no damage to the wing, aileron or flaps. The stub of the outrigger that had been left after the break was worn down to the OR1, which had also been worn down at quite an angle, but this had left an inch clearance between the lowest point of the wing and the ground. I went from despair to elation in a split second! The damage was just to the outrigger and the OR1.
Currently I am replacing both outrigger legs with MDS-Filled Nylon 6/6 Rod. This was a recommendation from the forum – I think Fred Klein – and I shall see how that goes. This I have sourced from McMaster-Carr and I found their ordering system and delivery excellent. This rod only seems to come in black, and is also very slightly lighter than the standard Nylon. It is meant to have greater strength than the standard nylon rod.
I also ordered up the Easy-Roll Rubber tread wheel to try out, although I will be getting the inline skate wheel to try also. I have not found the “Easy-Roll” wheel to be particularly easy at rolling! The pair of wheels I have do not roll with ease at all, but I will try them first before the inline skate wheel.
The only thoughts I have to this are that the OR1 saved my wing and probably propeller. I would consider replacing OR1 with a slightly longer version in order to provide more of a comfort clearance – that inch of space is very small and not far to go before greater damage.
I also did think about the possibility of incorporating a spring between the OR1 and the outrigger in order to provide flexibility. Rigid enough to hold the two together but for any sharp impact allowing for flexibility.
Robert Hatton
Posted: Fri May 14, 2010 8:34 am Post subject: Outrigger leg failure |
Kevin there was a lot of testing of the outriggers, many failures. The nylon grade was chosen after a lot of experience and was the best available alternative at the time, near 20 years ago. There may well be a better alternative now but factory don't have the technical enthusiasts to find it so it's up to you guys I'm too old too!
Graham
Sent: Friday, 14 May, 2010 16:18:31
Subject: Re: Outrigger leg failure
Kevin,
Fred
[quote]http://=======================
Posted: Fri May 14, 2010 9:22 am Post subject: Outrigger leg failure |
On May 14, 2010, at 8:58 AM, Robert Hatton wrote:
| Quote: | | Currently I am replacing both outrigger legs with MDS-Filled Nylon 6/6 Rod. |
Robert,
Thanks for your report on your outrigger failure...glad to hear that there was no damage to your aircraft.
Twas not me who suggested use of MDS-filled nylon 6/6 rod...I know nothing of its properties.
Re: wheels...I'm not familiar w/ "Easy-Rolls", but the 100 or 105 mm skate (or scooter) wheels spin silently forever...be advised that when buying them you will enter the world of ABEC ratings for various bearings...I opted for #9s but you can go for the ceramics for a few more bucks...I bought my inline wheels online at www.skates.com,,,bushes are also available to enable fitting within the SS forks.
Related comment: From Kevin's drawing, he's apparently mastered the art of machining the factory-stock nylon rod...I had a devil of a time turning down my rods so that they might fit into the OR 1s.
Fred
Posted: Fri May 14, 2010 10:30 am Post subject: Outrigger leg failure |
I had the left one fail while taxi turning right at an average fast walking speed. When the leg breaks, the wigtip just clears the ground. But the noise you may hear from the OR-1 grinding on the pavement made me want to stop right now! The glider pilot in me probably took over and I think I applied the brake. That's the wrong thing to do, especially in a turn away from the low wing. It will nose over MUCH easier in that configuration. That was it for the prop, and the wingtip lost some paint.
I had another one break on a bouncy landing with my insructor in the right seat.No brake applied and some loss of directional control. Damage was limited to the OR-1.
I broke another on a bounced go-around. I thought I heard it break, but of course you can't see it from the cockpit. I made a low pass and saw it littering the runway.That inspired me to do a good landing (finally) and hold the wing up with aileron to a full stop with brake after slowing and turning slightly toward the broken side.
I broke one in the hanger. I was pushing down on the wing tip to see the flex of my newly replaced outrigger and it shattered.
All these failures happened in above freezing temps, but I did not record actual temps. I bought replacement Nylon 6/6 from McMaster.
Look at the data sheets before deciding on the MDS-filled Nylon (available on McMaster site). As I recall, it is no better for this application.
I'll let ya'll know if I ever break one of my fiberglass legs.
Kevin
N211KA
Posted: Fri May 14, 2010 10:48 am Post subject: Outrigger leg failure |
I think it was Erich Trombley that said he was using the above...
Thanks for that link, they have good service and reasonable prices.
I am fortunate to have a friend close by with a lathe and a milling machine in his garage. He made the drawing and turned the rod into the part drawn. I plan to get with him on drawing up new slim forks for the skate wheels to go with the 5/8" fiberglass legs.
Kevin
N211KA
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
Posted: Fri May 14, 2010 11:47 am Post subject: Outrigger leg failure |
Sorry Fred, I must have got mixed up for I was looking at wheels at the same time as outrigger material etc. Apologies if I caused any confusion.
Robert
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Fred Klein
Sent: Friday, May 14, 2010 6:20 PM
Robert,
Fred
| Quote: | | http://www.matronics.com/Navigator?Europa-List | 0123456789
rampil
Posted: Fri May 14, 2010 11:55 am Post subject: Re: Outrigger leg failure |
I don't believe nylon polymer is the wrong material for the application.
When new it is probably a lot better in flex than some sort of FRP.
Fourteen years just seems a really long time to have any sort of
plastic exposed to UV. Inspection of condition should include
a hand lens for checking and small cracks. There is a UV-resistant
nylon which is unfortunately black in color. Even lexan polycarbonate
windshields will deteriorate after 14 years in sunlight.
FRP will need to painted with UV-resistant primer for protection from
the sun also.
erichdtrombley(at)juno.co Guest
Posted: Sun May 16, 2010 1:50 pm Post subject: Outrigger leg failure |
Yes, it was me who suggested the use of MDS-filled nylon material from McMaster-Carr. I did some research during the selection process and if I remember correctly the MDS-filled nylon had the same or better flexural strength, better UV protection and slightly better impact strength. I have had my legs in service for just over seven years without issue. I too am using inline scooter wheels with a slimmed down mounting fork. I will take a picture and post it.
Erich Trombley
N28ET Classic Mono 914
Time: 11:48:18 AM PST US
Kevin
N211KA
Penny Stock Jumping 2000%
Sign up to the #1 voted penny stock newsletter for free today!
http://thirdpartyoffers.juno.com/TGL3131/4bf068533df1a4862fbst04vuc
Posted: Sun May 16, 2010 3:37 pm Post subject: Outrigger leg failure |
On May 16, 2010, at 2:47 PM, Erich Trombley wrote:
| Quote: | I too am using inline scooter wheels with a slimmed down mounting
Erich...please consider posting some pixs and description of your
retraction mechanism as well...I was quite intrigued by your
description at SnF last year...Fred
Posted: Sun May 16, 2010 6:02 pm Post subject: Outrigger leg failure |
Hi Erich,
What materials did you use to make your scooter wheel forks? I just got some
.080 4130 steel sheet for a first try on the forks and .058 wall 3/4" (which
is 5/8"ID) 4130 tube for the outrigger leg socket.
Looking forward to seeing a picture, too.
And I'm glad to hear that the MDS-filled nylon legs are serving you well. I
thought I remembered that the MDS-filled nylon had lower friction
properties, but was not any stronger. I'll see if I can find that info
again.
Did you ever break a Nylon 6/6 leg?
Kevin
N211KA XS Mono 914
