Raptors Rule- although the canopy costs $182,205
martin(at)buzzardaviation
PostPosted: Sun Apr 23, 2006 11:49 pm    Post subject: Raptors Rule- although the canopy costs $182,205 Reply with quote
At 03:50 24/04/2006, Roger Kemp wrote:
--> Yak-List message posted by: "Roger Kemp" <viperdoc(at)mindspring.com>
Martin,
The canopy could not be opened. For a number of reasons. Have seen that up
close and personal in the Viper.
doc
No doubt a 50 cent washer was the cause Smile
Happy Landings
   ____|____
        \O/
        o'o           Martin Robinson
Auster AOP 9  G-BKVK (WZ662)
Yak 18T  HA-YAV
gyoung
PostPosted: Tue Apr 25, 2006 7:35 am    Post subject: Raptors Rule- although the canopy costs $182,205 Reply with quote
 http://www.spaceref.com/news/viewsr.html?pid=20396
Langley Air Force Base Briefing: F-22 03-041 Stuck Canopy STATUS REPORT
Date Released: Monday, April 24, 2006
Source: Department of Defense
[img]outbind://373-00000000B2A6FFB466FCEC4B817A05DDBE330990070061832E0598D9CC4E92BEC5048819BD1A00000000CEF3000061832E0598D9CC4E92BEC5048819BD1A000000184A2C0000/http://images.spaceref.com/news/2006/f22.cut.jpg[/img] F-22 03-041 Stuck Canopy
TSgt Robinson 1st MXG/MXQ
• On 10 April 06 at approximately 0815 aircraft 03-041 had a Red Ball for a canopy unlock indication. Attempts to clear the problems by cycling the canopy failed. The final cycling of the canopy resulted in it being in the down and locked position. The canopy would not cycle up form this position trapping the pilot in the cockpit. The aircraft subsequently ground aborted.
• Attempts to manually open the canopy were unsuccessful
• 27th AMU consulted Lockheed Martin and the F-22A System Program Office to determine alternate methods to open the canopy and extract the pilot
• After all maintenance options were exhausted, the canopy was cut by fire department personnel and the pilot was extracted at approximately 1315
• Trouble-shooting of the aircraft is in work
• Canopy replacement cost is $182,205
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Buzzard Aviation
Sent: Monday, April 24, 2006 2:46 AM
To: yak-list(at)matronics.com
Subject: Re: Raptors Rule- although the canopy costs $182,205
Martin,
doc
 Filesize:  12.88 KB
 Viewed:  301 Time(s)
