Seat back material
maarten versteeg
PostPosted: Sun Apr 25, 2010 9:10 am    Post subject: Seat back material Reply with quote
Hello All,
A question, the seat-backs are not mentioned in the plan or builders guide
at all, what material should I use. I though about word, plywood, how
thick would be sufficient?
Any experience with suitable material, some other kind of board?
maarten,
plans building 601xl: N581SL
Maarten Versteeg
601XL scratch building wings
jaybannist(at)cs.com
PostPosted: Sun Apr 25, 2010 9:41 am    Post subject: Seat back material Reply with quote
Maarten,
Here is what I did. That's 1/4" plywood, aircraft grade, of course  (;>) from the aircraft section at Lowe's.
Jay
 Filesize:  157 KB
 Viewed:  8906 Time(s)
 Filesize:  115.22 KB
 Filesize:  167.21 KB
larry(at)macsmachine.com
PostPosted: Sun Apr 25, 2010 10:56 am    Post subject: Seat back material Reply with quote
Hi Marten,
I did a plywood back insert for the seats with a 1/4-inch plywood
finished both sides.
The thing I'd recommend with this kind of process is keeping the back as
thin as possible.
I went with 2-inch total thickness and should have gone with a 1-inch
back because taller
people do better with the extra inch back clearance. I could have shown
the plywood slips
into an envelope sewn into the back and the retainer channel hangs out
to grab the seat in place .
No other fasteners are needed. See the link below for pictures of how the
seat was done. Click on the picture to get a larger image.
www.macsmachine.com/html/seatupholstery.htm
Good luck,
mversteeg wrote:
Hello All,
guide
maarten,
bryanmmartin
PostPosted: Sun Apr 25, 2010 11:33 am    Post subject: Seat back material Reply with quote
I had some 3/16 plywood flooring laminate that I used for the seat backs. I used a piece of aluminum L riveted to these and bent down over the top of the baggage shelf lip to hold them in place, similar to the way Jay did his.
Hello All,
maarten,
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
PatrickW
PostPosted: Sun Apr 25, 2010 12:44 pm    Post subject: Re: Seat back material Reply with quote
Ditto here. 1/4" plywood. I think it came from one of the Zenith crates, so it's "real" aviation quality...
Patrick
N63PZ
650-B/Corvair
pchap(at)primus.ca
PostPosted: Sun Apr 25, 2010 3:12 pm    Post subject: Seat back material Reply with quote
Since everyone is mentioning plywood, I'll mention the different (but
not necessarily better) solution my dad and I tried, that's worked
fine for years:
2 layers of fibreglass enclosing a core of 3/8" foam board
Weight for one seatback was about 1.25 lbs, while I calculated 3/8"
plywood would weigh very roughly 2.5 lbs each. Others were mentioning
using a lighter 1/4" plywood, where the fibreglass weight advantage
would be much smaller.
So the fibreglass & foam method can save a little weight but clearly
takes more time to build.
A bigger factor in seat weight is that of all the foam, particularly
when using the heavy Confor foam.
Peter Chapman
Toronto, ON 601 HDS / 912 / C-GZDC
Juan Vega Jr
PostPosted: Sun Apr 25, 2010 3:35 pm    Post subject: Seat back material Reply with quote
mine is 1/8 inch.
juan
pmaxpmax(at)HOTMAIL.COM
PostPosted: Sun Apr 25, 2010 3:51 pm    Post subject: Seat back material Reply with quote
My plane has two aluminum panels slightly larger than the opening with two L angles for stiffeners. Three screws hang it from the luggage rack. It's light weight and works great.
Phil Maxson
601XL/Corvair
Northwest New Jersey
maarten versteeg
PostPosted: Sun Apr 25, 2010 4:27 pm    Post subject: Seat back material Reply with quote
Thanks, 1/4 inch plywood with aluminum clips seems the way to go,
I will try to keep the cover as thin as possible, I am only 6 foot 1 but
I have very short legs and hence a long back to I don't have too much
margin to play with.
This morning I also sat for the first time in my plane (and made the
required airplane noises). Even though I just has a tiny cushion on the
bottom the shape of the seat was quite comfortable so I may be able
to keep the foam thin.
maarten,
Maarten Versteeg Southwest Research Institute
Phone: (210)522-5029 P.O. Drawer 28510
Fax: (210)522-5499 San Antonio, TX 78228-0510
Maarten Versteeg
davgray(at)sbcglobal.net
PostPosted: Sun Apr 25, 2010 6:52 pm    Post subject: Seat back material Reply with quote
You can go thinner than 1/4 inch. Lowes aircraft isle has birch plywood
that is either 1/8 or 3/16 and quite stiff and light.
I used this without regrets. I made panels that slide in from the top down.
A small section that rests on the center console is all that keeps it from
sliding too far down while the other side rests against the outer side
panels.
I also used this for the side panels coverd first in a thin sheet of dacron
appolstery padding then the fabric attached on the backside with contact
cement. Velcro assists the side panels maintain their position.
I have a picture up at
http://picasaweb.google.com/Papawobo/Variations#
This works well but is not a beautiful as the refined leather interior that
many have done.
Gary Ray
