The Miracle Whip series antennas
PostPosted: Thu Apr 15, 2010 8:45 am    Post subject: The Miracle Whip series antennas Reply with quote
At 10:41 AM 4/15/2010, you wrote:
<nuckolls.bob(at)aeroelectric.com>
Robert Victor, President (VA2ERY)
Miracle Antenna
Montreal, Canada
<snip>
I would like to be capable of advising my readers
from a position of knowledge and understanding about
your products. Anything you can offer to assuage my
ignorance would be appreciated. I'd like to add
this technology to the discussion on antennas when
the book is updated.
I received a pleasant phone call from Mr. Victor.
He was unwilling to share any test data . . . backed
by the notion that such sharing left his venture
open to competition by folks who might exploit
his IR&D efforts.
This is a real risk for simple, easily fabricated
products. He did offer the idea that the Miracle
Whip was not an end-fed but center-fed half-wave
dipole. He explained that the dipole is formed by
exposing 1/4-wave of center conductor of the far end of
the feed line. One then moves 1/4-wave toward the
transmitter and inserts a high efficiency, common-
mode choke. That's what the 7-turns of coax through
the torroid core is all about.
This inserts a discontinuity in the shield. The
effect is that the INSIDE of the coax is a feed-line
out to the center and the outside of the coax shield
beyond the choke becomes one-half of the dipole.
This means that the "wire" we see wrapped through
the core in . . .
http://forums.matronics.com//files/themiracleinside_131.jpg
is actually an unbroken length of coaxial cable. The
magic comes from core selection for high permeability
while offering the lowest possible losses at VHF
frequencies. No doubt a high quality ferrite material.
When I get the RF bench running fully and have the
time, I'll fiddle with the concept a bit and see what
I can confirm with the test equipment.
klburris
PostPosted: Sun Apr 18, 2010 11:45 pm    Post subject: The Miracle Whip series antennas Reply with quote
Folks;
From the 'for what it's worth' dept --
I bought a plane that had a standard Comant antenna mounted on the bottom on an almost all metal plane. Sitting on the ground, I was unable to receive weather. I replaced that antenna with a miracle whip placed in a small fiberglass portion of the plane at about the same distance from the ground. I was amazed at the results in reception and also the cleanliness of reception. Friends told me my radio coms were crystal clear. I am a happy Miracle Whip user. The antenna is also in one piece, so if you don’t glue it in place, it will serve as a great rubber duck replacement for a handheld.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->-- Keith
 Filesize:  4.29 KB
 Viewed:  3959 Time(s)
 Filesize:  7.65 KB
Michael Wynn
PostPosted: Mon Apr 19, 2010 2:45 pm    Post subject: The Miracle Whip series antennas Reply with quote
What is a Miracle Whip antenna?
Michael Wynn
RV 8 Finishing
San Ramon, CA
In a message dated 4/19/2010 12:47:59 A.M. Pacific Daylight Time, klburris(at)frontiernet.net writes:
Folks;
-- Keith
 Filesize:  4.29 KB
 Viewed:  3951 Time(s)
 Filesize:  7.65 KB
Michael Wynn
RV 8
San Ramon, CA
lists(at)stevet.net
PostPosted: Mon Apr 19, 2010 3:44 pm    Post subject: The Miracle Whip series antennas Reply with quote
http://www.miracleantenna.com/AirWhip.htm
Steve Thomas
________________________________________________________________________
On Apr 19, 2010, at 3:28 PM, MLWynn(at)aol.com wrote:
[quote] What is a Miracle Whip antenna?
Michael Wynn
RV 8 Finishing
San Ramon, CA
<image001.jpg>
Folks;
-- Keith
<image002.gif>
