1/2 Wave Ring Antenna
PostPosted: Thu Apr 15, 2010 8:02 am    Post subject: 1/2 Wave Ring Antenna Reply with quote
Has anyone ever experimented with a 1/2 Wave Ring Antenna? It is described here: http://www.slvrc.org/902band/902antennas.htm
It could be mounted on a metal turtle deck and covered with non-conductive fabric or fiberglass for streamlining. Its low profile would have less drag than a quarter wave antenna at high speeds.
Joe
Joe Gores
PostPosted: Thu Apr 15, 2010 9:05 am    Post subject: 1/2 Wave Ring Antenna Reply with quote
described here:
I'm planning on building a cousin to this antenna for
my 2M storm watch transceiver. See:
http://www.antennex.com/preview/2mddrr.htm
This is the 1/4 wave version. Given that both the
1/4 and 1/2 wave antennas are vertically polarized
says that all the magic happens in that short vertical
mast that goes to ground. This becomes the same thing
as a short vertical with a strong top-hat loading
scheme. So whether the "top hat" is 1/4 or 1/2 wave
in circumference probably offers little difference in
performance.
Given the lengthening effect of so severe a
"rake angle" on this antenna, the physical length
of a 1/4-wave will be shorter than the classic
22" whip. 22" bent around in a circle would give
us less than 6" diameter and about 2" tall for VHF
Comm frequencies. This cross section, even if well
faired, could offer much more drag than the simple
whip stuck out in the breeze.
However, this form of antenna might perform well
inside a composite fuselage.
The biggest problem with heavily loaded antennas
is loss of band-width. They tend to be sharply
tuned at the design frequency with efficiency
falling off rapidly either side. The extreme example
of this phenomenon is demonstrated by small diameter
loop antennas for lower ham frequencies. They
have to be fitted with motor driven capacitors to
allow remote tuning to the frequency of interest.
Circulating currents tend to be very high, voltage
across the tuning capacitor is quite high. To keep
the losses low at such high currents, the antenna
is made from 3" DWV copper!
The DDRR antenna needs a high conductivity ground
plane that's at least 2x the antenna diameter. So
a 6" DDRR might be built on a 12" square piece of
copper clad that could become a "shelf" of sorts
in the tailcone. Further, that same sheet might
also be a good mounting location for the transponder
antenna. Food for thought.
FisherPaulA(at)johndeere.
PostPosted: Thu Apr 15, 2010 9:56 am    Post subject: 1/2 Wave Ring Antenna Reply with quote
There has been some discussion about a ring antenna here: http://www.vansairforce.com/community/showthread.php?t=52676
The discussion was specifically about APRS which uses 144.39MHz in the ham bands, but it's close enough to aviation frequencies that it might give you some ideas. The biggest issue on this thread is where do you mount such an antenna in an all metal airframe. Obviously, the problem becomes much simpler if you eliminate that!
Paul A. Fisher
Q-200, N17PF - copper foil dipole embedded in the vertical tail
RV-7A, N18PF - 1/4 wave sticking out in the wind!
tshankland(at)sbcglobal.n
PostPosted: Thu Apr 15, 2010 6:51 pm    Post subject: 1/2 Wave Ring Antenna Reply with quote
Boy that brings back memories I had a two meter halo antenna on the back
of my car in the the 1960's, the principle advantage was that it was
horizontally polarized like most of the other hams base station's. By
the way a much younger version of myself is the middle one of the group.
Tim Shankland 601HD flying ( no halo antenna)
Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
> <fran4sew(at)banyanol.com>
> described here:
performance.
 Filesize:  1.83 MB
 Viewed:  4971 Time(s)
