Posted: Tue Apr 13, 2010 9:35 am Post subject: copper foil groundplane |
Hi guys,
I've just joined this group and have a couple of questions. I have searched the archives, but finding my particular answers is tough, to say the least.
I'm getting very close to installing the Icom A200 comm antenna in my tube & fabric airplane (Kolb MkIII). I think I've chosen to go underneath the fuselage, between the main gear legs, with the 23" steel rod mast pointing down and rearward.
Here's my first question; is the center solid wire RG58 antenna lead the one that point down and away? In other words, the shielding cable is the lead that I make the groundplane with, right? I also assume they are NOT interchangeable, true?
I can build a decent dipole antenna using a 1/8" welding rod using Dean Scott's design plans. But, the groundplane rod of the dipole would be inside the steel frame fuselage, which isn't good. I would include the Pawsey stub for the balun.
Second question; can I build a 1/2" copper tape "X" groundplane and attach it to the inside of the fabric at the center of the BNC connector. If it's possible to use this style of groundplane with the solid rod antenna, can a guy use 6 legs of the copper foil? Any advantage to more than just the (4) 23" strips?
Thanks for your help!
Mike Welch
PS. Here is the link to Dean Scott's antenna design I would probably be using.
http://forums.matronics.com//files/antenna_design_118.pdf
Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. See how. [quote][b]
doug.ilg(at)verizon.net Guest
Posted: Tue Apr 13, 2010 12:04 pm Post subject: copper foil groundplane |
Mike,
Have you looked at Miracle Antenna's Air Whip? http://www.miracleantenna.com/AirWhip.htm It's a full dipole antenna that's made completely of flexible wire. It's also end-fed, so you don't need access to the middle of the antenna for connection. You can put it anywhere in the fuselage that's not shielded by conductive parts.
I'm not flying yet, but mine seems to work very well on the ground. It fits quite well in the fiberglass nose cone of my Challenger. Based on a quick look at a picture of a Kolb M3X, I'd guess you could do something similar in your airplane. It might save you some of the hassle you're dealing with.
FYI.
-Doug
Doug Ilg
Grumman Tiger N74818, College Park Airport (KCGS), Maryland
Challenger II LSS LW (N641LG reserved) - kit underway at Laurel Suburban (W18)
Sent: Tue, April 13, 2010 1:15:25 PM
Subject: copper foil groundplane
Hi guys,
Posted: Tue Apr 13, 2010 1:48 pm Post subject: copper foil groundplane |
Doug,
No, I hadn't heard of this one. It sounds like this could be the perfect setup. Do you know how the wire is "oriented"? Can you just make a circular loop, or ????
I do like the idea of this antenna, but since I'm between jobs right now, funds are very scarce. Plus, I really wanted to make the antenna for my plane, just for the experience.
Does anyone know of a DIY plan for this type of dipole end-fed com antenna? What is in that little black box? (hopefully not some of that "special smoke" that leaks out when you touch two wrong wires together!!)
If anyone knows of a way to make one these single wire dipole end-fed antennas, I'd sure appreciate a drawing or two.
Thanks again, Doug, for the tip!!
Mike Welch
.ExternalClass DIV {;}
Mike,
FYI.
-Doug
Doug Ilg
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} Hi guys,
Posted: Tue Apr 13, 2010 8:30 pm Post subject: copper foil groundplane |
At 01:15 PM 4/13/2010, you wrote:
Mike,
The end-fed half-wave antenna has been around
for a long time and is a popular topic of
discussion and debate in the amateur radio
antenna forums. There's a particularly lucid
study of these beasties to be found at:
http://www.aa5tb.com/efha.html
Of course, this article is dealing with the lower
HF frequencies of interest to amateurs but the
physics scales nicely into the higher VHF range.
My sense is that while they can be "tuned" to
accommodate effects of installation, they're not
your grandpa's plug-n-play buggy whip. It's unlikely
that an end-fed half-wave stuck inside the fuselage
of a composite aircraft will be optimized out of the
box for that particular installation.
Having said that, we also know that antenna efficiency
in airplanes can be all over the map and still provide
satisfactory performance. I have no doubt that the
antenna offered has many "satisfied" users.
If the builder is not DIY shy, a few dollars in
materials can be crafted into an quarter-wave
over ground-plane antenna that will certainly
perform as well with more predictable results
for SWR. Getting to the center of a half-wave
dipole isn't hard if you put the center
half way up on the side of the fuselage and
wrap around the inside surface.
Distorting from a straight antenna will have
the effect of electrically lengthening the
antenna so trimming after installation with
some form of SWR instrument would be useful
. . . but probably wouldn't produce observable
differences in performance
[/b]I've just joined this group and have a couple of questions.
answers is tough, to say the least. I'm getting very close to
That will probably work as well as anything else.
You can ground the feedline shield to the steel-tube
structure.
[/b]
Posted: Wed Apr 14, 2010 5:14 am Post subject: copper foil groundplane |
Hi Bob,
Thanks for the detailed and informative response. Yes, I am very much a DIY person.
I don't really have the $100 for the Miracle antenna (end-fed halfwave dipole), so I guess I'll have to stick with a homemade one.
So far, I'm still leaning toward the belly mount dipole, and making a spoke style grid of copper foil, where the steel rod mast mounts in the center of the grid. I'll sure to get a good ground of the groundplane to the tube frame.
Does more than four legs of a cu foil groundplane make it better? Or, is that just a waste of copper tape?
I'm curious. After I get this antenna constructed, mounted and finished, how does one check it's adjustment with a SWR meter. I mean, there aren't many things you could do to the mast, except cut off a little. But, what if you cut off too much?
Could you possibly explain the actual nuts and bolts of using an SWR meter, and how it can allow a guy to improve his antenna's performance?
One more thing.... I am also building a GlaStar, and bought the factory copper foil dipole antenna. I noticed it has triax cable, rather than regular RG58. I assume this is because the extra layer of the triax acts as a balun. I meant to check out how the triax connects at the junction of the two copper strips, but forgot, and mounted it in the tail and closed it up.
For fiberglass airplanes that might use this type of "triax cable copper foil dipole", how and where is the triax soldered, if it's soldered at all?
Thanks a lot!!
Mike Welch
structure.
[/b]
-List">http://www.matronics.com/Navigator?AeroElectric-List
ronics.com
ww.matronics.com/contribution
| The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. [quote][b]
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Wed Apr 14, 2010 6:26 am Post subject: copper foil groundplane |
Check this out
http://rst-engr.com/rst/catalog/airplane_antenna.html
Dick
In a message dated 4/14/2010 8:16:26 A.M. Central Daylight Time, mdnanwelch7(at)hotmail.com writes:
| Quote: | Hi Bob,
Thanks a lot!!
Mike Welch
structure.
[/b]
ronics.com
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. | Quote: |
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Wed Apr 14, 2010 7:35 am Post subject: copper foil groundplane |
Dick,
I'm very familiar with Bob Weir's stuff, and in fact, I built one of these copper foil antennas a few years ago. I haven't installed it yet. If I can find it, I think I'm going to go ahead and use it.
I built the mast out of fiberglass, with the copper foil sandwiched inside it. The mast is then soldered to a BNC connector, and faired in with more fiberglass. Finally, I sanded everything nice and smooth, and painted it grey.
Thanks for the reference, tho.
Mike Welch
Date: Wed, 14 Apr 2010 10:19:48 -0400
Subject: Re: RE: copper foil groundplane
Check this out
Dick
| Quote: | Hi Bob,
Thanks a lot!!
Mike Welch
structure.
[/b]
ronics.com
ronics.com
Posted: Wed Apr 14, 2010 7:48 am Post subject: copper foil groundplane |
At 08:12 AM 4/14/2010, you wrote:
Hi Bob,
much a DIY person. I don't really have the $100 for the Miracle
a homemade one.
I've had an antenna building article on my to-do list
for years. Unfortunately that list is long and the
antenna project is pretty far down. Suggest you start
with a manufactured "mount" like . . . .
http://tinyurl.com/y3a4lpf
This is an example of MANY similar products which
you can find at about any truck-stop on a major highway.
You can install the mating PL-259 coax connector
on your coax -OR- install a SO Male to BNC female
adapter to mate with your own installed BNC cable
male -OR- consider this pre-mfg assembly from
Radio Shack . . .
http://tinyurl.com/y7dzxpf
It has a PL-259 on one end that will mate with
your "truckers antenna mount". You can cut the
connector off the other end and install a cable
male to mate with your transceiver.
"dipole" or "vertical 1/4-wave"?
of the groundplane to the tube frame. Does more than four legs of
copper tape?
Tests have shown that there's a diminishing return
on investment for adding radials to the ground plane.
To make a significant improvement one needs to double
the radials. The step from 4 is up to 8 . . . you can
see where that's taking us.
You'll need some sort of structural bracket
that grips a tube and supplies a suitable
flat against the inside surface of the fabric
for attaching the antenna. This bracket also be
suitable for grounding the coax shield to the
airframe. Getting robust connection to a ground
plane attached inside a fabric 'skin' is problematic.
The ship's existing metallic structure is a
reasonable substitute for the classic "spider
legs" ground plane.
Correct. If you were going to "go for the gold",
you'd make it extra long by about an inch and
then trim to length for best SWR at the selected
center frequency. The theroetical 1/4-wave centered
in the VHF comm band (129.5 Mhz) is 23.34 inches.
If you cut it to 22.34 inches the antenna is
calculated to center on 132.14 Mhz. So the
"tuning sensitivity" for this antenna is on the
order of 2.6 Mhz per inch of length. So trimming
say .1" at a time would let you "sneak up on it".
Alternatively, you can calculate a new length based
on measured center frequency using the 2.6"/MHz
sensitivity factor.
Now that we've fine tuned the theory, know also
that there are other factors that influence the
resonant frequency. An important one is a correction
for length/diameter ratio. I speak to this effect
in figure 13-6 of the 'Connection. If your antenna
rod is .125" diam stainless and is about 23" long,
then the l/d ratio is about 160. This translates
to an electrical "lengthening" of about 3.5% or
.81 inches. Gee, this translates to about 2 Mhz
shift in center frequency.
Further, bending your antenna aft for a rakish
appearance (or better ground clearance) has a
further lengthening effect. All this calculator
key-punching goes to demonstrate that the ideal
antenna is trimmed to length after installation
using some form of instrumentation.
Return on investment? The guy listening to your
transmitted signal wouldn't know the difference
between the "ideal" and "pretty close" antenna.
Further, DIRECTIONAL effects of airframe geometry
can have a PROFOUND effect on the very best of
antennas. This effect is discussed in the BALUN
construction article cited below.
Bottom line: 22" for a 1/4-wave stick is close
enough for government work. An SWR test at the
transceiver end of the feed line is most useful
as a gross check of antenna integrity. Check SWR
at say 1 Mhz steps from 118.0 to 135.0 and plot the
results. The "dip" in the plot shows the center
frequency of the antenna. The SWR shouldn't be
more than 3.0:1 over the full range of interest.
An antenna with a broken connection along the feed
line will have very high SWR numbers and probably
exhibit no clear "dip" in the plot.
That IS a problem only if you're pedantic about
getting the antenna performance centered on
129.5000000000 Mhz. If you "overshoot" a trimming
operation and the durn thing now centers at 131
Mhz, no big deal.
performance?
It's pretty simple. Use your ship's transmitter
as a signal source and plot measured SWR against
transmit frequency. When you're all done, the
SWR will be LOWEST at the design center. SWR
should not be more than 3:1 at the edges of
the band.
soldered at all?
I've heard of this design but never had the opportunity
to run it through the lab. It's better than NO balun but
again, ROI is problematic. The outer shield could be
used two ways: Soldered to the inner shield 1/4-wave from
the antenna end only. This makes it a "bazooka" decoupling
sleeve.
http://tinyurl.com/y6xgese
Alternatively, it can solder to the inner shield 1/4-wave
away from the antenna as above. The other end of outer
shield solders to the center conductor at the antenna
end. This makes it a piece of transmission line. This
type of balun is easily synthesized without the use
of triaxial coax as shown here:
http://tinyurl.com/yytxwd3
I wouldn't discourage anyone from going for the best-
we-know-how-to-do in selection/fabrication, installation
and testing of antennas on the airplane. At the same
time, know that "missing the mark" by some small amount
is probably not a reason for ripping it out and starting
over.
n81jg(at)aol.com Guest
Posted: Wed Apr 14, 2010 10:02 am Post subject: copper foil groundplane |
Check out Slim Jim and J-pole antennas on Google. They are end fed dipoles.
John Greaves
VariEze N81JG
Redding, CA
longg(at)pjm.com Guest
Posted: Wed Apr 14, 2010 10:44 am Post subject: copper foil groundplane |
Found this. Just put in the freq and it tells you how long to make it.
Does that mean the length we're shooting for is the middle of the band?
http://www.m0ukd.com/Calculators/Slim_Jim/index.php
Glenn
checkn6
Posted: Wed Apr 14, 2010 1:32 pm Post subject: Re: copper foil groundplane |
Inside the magic box
53.02 KB |
14135 Time(s) |
Posted: Thu Apr 15, 2010 5:56 am Post subject: copper foil groundplane |
Actually I'd pay $90 just for the packaging. I've now seen some of the
homemade jobs and while I've not clue on how to build antennas, I have
less of clue how any of these folks got their inventions in the
airplane. Copper strips, pipe, soldering, 3 ft tall, etc. etc. I have a
Lancair not a Suburban.
$90.00 is a no brainer. Thanks for the reference.
Do Not Archive.
Glenn
