heat shield
clemwehner
PostPosted: Sun Apr 11, 2010 4:35 pm    Post subject: heat shield Reply with quote
Do we need to make a thin aluminum heat shield to protect the firewall blanket from the muffler heat on a 912 installation in a model IV?
If so, how much of the lower firewall does it need to cover?
thanks for the help,
Clem
Oklahoma KFIV, 912
Clem
Oklahoma
Kitfox IV-912, under construction since 1991
vetdrem
PostPosted: Sun Apr 11, 2010 5:17 pm    Post subject: Re: heat shield Reply with quote
I have a model III with a 912, and have about 200 hours on it. I noticed that the blanket was getting a little discolored behind the exhaust, and it started getting brittle.
I decided to do exactly what you asked about. I cut and shaped some aluminum to cover the blanket right behind the exhaust. The only places that needed it on my installation was for the exhaust lines from the back cylinders to the muffler. I don't know if it is really needed or not, but I don't get as many questions from friends looking things over, and besides, it makes me feel better.
Louie
Dick Maddux
PostPosted: Mon Apr 12, 2010 4:08 am    Post subject: heat shield Reply with quote
Clem,
I have an aluminum exhaust shield on mine also. I too found the area where there was no shield did get scorched. If you don't have your engine mounted yet, you could form a nice alum/ss piece to fit the lower firewall. That fabric material does flake and crack next to the muffler..
    Dick Maddux
    Fox 4,Milton,Fl
PS: headed to Lakeland this morning, weather looks good, should be a good show!
Roger Lee
PostPosted: Mon Apr 12, 2010 5:34 am    Post subject: Re: heat shield Reply with quote
If you have stainless exhaust pipes and muffler. You could use header wrap and take care of the problem. Easy and controls radiated heat much better. You can pick up a roll at most automotive stores. They claim it cuts down up to 70% heat. I can put my hand on my exhaust after flying. So that means that much less heat under the cowl and radiated heat to hoses and wires. It has been on there since Jan. 2008. Never any issues and a lot of our fleet followed along and has had no issues.
08 01 28 FD Manufacturer Approval for CTSW 06-10-04 Thermo Tec header wrap.pdf
Header wrap on a Flight Design. Mfg. approved
 Filename:  08 01 28 FD Manufacturer Approval for CTSW 06-10-04 Thermo Tec header wrap.pdf
 Filesize:  1.03 MB
 Downloaded:  511 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
