Circuit To Combine Mag P-Lead For RPM Measurements
Site Admin
PostPosted: Sun Apr 11, 2010 9:28 am    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
Has anyone found a device or circuit to pick off the output from the P leads on the left and right mags for feeding to an RPM measuring device such as the GRT EIS-4000? The EIS-4000 only has a single RPM input. The installation manual suggests installing a SPDT switch between the left/right mags and then to the input on the EIS-4000 for manually switching between the mags during drop testing. But that's pretty hoekey. Seems like someone should have come up with a simple prioritized switching circuit that would, say, always read the left mag p lead unless there wasn't a signal, then read the right mag P lead output. In my "spare time" maybe I'll make one if there isn't something already out there like this.
I thought that once upon a time I saw an electronic gizmo you could screw into the standard tack drive that would give an electronic output. Anyone have a line on this device and whether its compatible with the GRT EIS?
Thanks!!
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Final Bits/Inspection/Test Flight
gfr56(at)comcast.net
PostPosted: Sun Apr 11, 2010 10:49 am    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
I can offer nothing on the pick off option from the P lead....but... The GRT EIS 4000 now can take 2 inputs for RPM and displays RPM #1 if it is present . Your older unit may be upgradable. Jerry
Site Admin
PostPosted: Sun Apr 11, 2010 1:20 pm    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
Yes, I do remember that thread. In fact, I have those pickups installed, but I'm not getting any reading on the EIS-4000 with either one of them. I'm using the vent hole closest to the engine block. Have you successfully interfaced them to the EIS-4000?
RV-8 #82880 N998RV
At 02:12 PM 4/11/2010 Sunday, you wrote:
Matt,
You may recall that I provided a suggestion of using a Westach inductive sender when you asked this question on the GRT yahoo group over a year ago:
http://groups.yahoo.com/group/GRT_EFIS/message/6872
Skylor
Sent from my iPhone.
Thanks!!
RV-8 #82880 N998RV
skylor4(at)yahoo.com
PostPosted: Sun Apr 11, 2010 1:47 pm    Post subject: Circuit To Combine Mag P-Lead For RPM Measurements Reply with quote
What are you using for excitation voltage to the sender?
Honestly, I haven't run my engine yet, but I was able to get the EIS to indicate an RPM readind by "waving" a small magnet across the sensor. The excitation voltage has to be 12 volts or so (a 5 volt source doesn't produce enough signal voltage for the EIS).
Skylor
RV-8 #82880 N998RV
Matt,
Skylor
Thanks!!
RV-8 #82880 N998RV
