Kellym
Posted: Sun Apr 11, 2010 7:27 am Post subject: Hartzell Prop Grease gun & Fittings |
I've not had an issue with zerk fittings on my Hartzell with standard
grease gun hose. However, be certain to remove the second zerk from the
same end of the hub(you should have 2 on each end, with one on each end
removed.) If you do not do this, you will push grease through the seals
and start your prop hub leaking. Also be certain you are using the same
grease that the hub has been serviced with in the past. There is
supposed to be a sticker on the hub as to which grease to use...often
Aeroshell #6.
Kelly
A&P/IA, KCHD in Aridzona
On 4/11/2010 7:42 AM, Tom & Cathy Ervin wrote:
Quote: |
Group,
I thought I would break down and buy grease and a new grease
gun to annually grease my Hartzell prop hub...instead of bothering the
now retired FBO.
The zerk fittings on the hub don't seem like they are the same
as automotive? The test fit against a new gun indicates a loose
fit....doesn't snap on like I'm used to??? Grease goes everywhere but
in the fittings!
Either my new gun is defective or....as I suspect it takes a
special gun and fittings?????
Any ideas?? Thanks, Tom in Ohio
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
KCHD |
tcervin(at)embarqmail.com Guest
Posted: Sun Apr 11, 2010 8:14 am Post subject: Hartzell Prop Grease gun & Fittings |
Kelly,
I have done everything as you have listed....maybe a fitting is plugged or the new gun is defective?
I am using Mobil 28 which is compatible with all Shell grease....6&7. Shell has been used in the past but I like the testing data on Mobil 28. I also use Exxon Elite oils and in 100 hrs I have added 1 pint between changes.
Looks like I may be buying a better quality gun if cleaning the zerk fittings doesn't work.
Thanks, Tom in Ohio
Kellym
Posted: Sun Apr 11, 2010 8:19 am Post subject: Hartzell Prop Grease gun & Fittings |
While I would try another gun, I advise strongly against using a
different brand grease unless the hub is torn down, inspected and
resealed. "compatible" is one thing in a gear leg or similar, and
entirely different in a prop hub with relatively large quantity of
grease that is going to be mixed for a long period of time. Hartzell
advises against mixing grease in any way. Your prop is not the place to
be trying a new brand.
On 4/11/2010 9:13 AM, Tom & Cathy Ervin wrote:
Kelly,
Thanks, Tom in Ohio
KCHD |
Gary.A.Sobek
Posted: Sun Apr 11, 2010 8:27 am Post subject: Hartzell Prop Grease gun & Fittings |
Not familiar with Mobil 28 grease. I do know that there is a TEMPERATURE constraint for AeroShell 7 when used with the Hartzell prop. You need to placard the panel that operation is not permitted below -40 outside air temperature. My Hartzell was shipped with AeroShell 6 but the West Coast prop shop that did the overhaul used AeroShell 7. AeroShell 7 is fine for the flying that I do on the "LEFT" Coast but would want the AeroShell 6 if I lived back in Pennsylvania were I grew up and learned to fly.
Gary A. Sobek
2,346+ Flying Hours So. CA, USA
[quote] Date: Sun, 11 Apr 2010 12:13:26 -0400
To: rv-list(at)matronics.com
Subject: Re: Hartzell Prop Grease gun & Fittings
--> RV-List message posted by: Tom & Cathy Ervin <tcervin(at)embarqmail.com>
Kelly,
I am using Mobil 28 which is compatible with all Shell grease...6&7. Shell has been used in the past but I like the testing data on Mobil 28. I also use Exxon Elite oils and in 100 hrs I have added 1 pint between changes.
Thanks, Tom in Ohio
Gary.A.Sobek
Posted: Sun Apr 11, 2010 8:33 am Post subject: Hartzell Prop Grease gun & Fittings |
My Hartzell manual says that 6 and 7 can be mixed but if you do, there is a do NOT OPERATE below -40 OAT limitation that goes with the AeroShell 7 grease. AeroShell 6 does not have that limitation.
I agree that I would not change brands of grease without a reseal. I would only use the grease that Hartzell lists in their manual.
Gary A. Sobek
[quote] Date: Sun, 11 Apr 2010 09:18:18 -0700
--> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com>
> --> RV-List message posted by: Tom& Cathy Ervin<tcervin(at)embarqmail.com>
> Kelly,
> Thanks, Tom in Ohio
mcculleyja(at)starpower.n Guest
Is your Hartzell prop new from the factory? It should not be a problem
if new---NOT a used prop wherein someone could have changed the
fittings. Mine has worked perfectly for 7 years.
Possibly someone changed the fittings, if yours is not new from
Hartzell, OR there is a problem with your grease gun not being a
standard configuration common to automotive grease guns.
Be sure you remove the opposite-side grease fitting as described in
Kelly's response below.
Jim McCulley
Aeroshell #6.
Kelly
> Group,
> now retired FBO.
> in the fittings!
denis.walsh(at)comcast.ne Guest
Posted: Sun Apr 11, 2010 9:17 am Post subject: Hartzell Prop Grease gun & Fittings |
What a great set of responses.
I can find nothing t disagree with so far. These are all great pieces of information and come from the manufacturer.
Let me add one small bit of gossip. When my prop was overhauled the shop put AS 7 in it. When I asked why, since it had come with 6. His response; "it don't leak."
So there is a trade off between 6 and 7. My assumption is that 6 is "thinner" and 7 is "thicker". I am very happy with the -40 degree restriction. I wouldn't want to try starting the Lyc or the pilot at that temp, much less fly. I do cycle the prop before take off, in the winter, to make sure it is not sluggish.
On Apr 11, 2010, at 10:29 , RV6 Flyer wrote:
[quote]My Hartzell manual says that 6 and 7 can be mixed but if you do, there is a do NOT OPERATE below -40 OAT limitation that goes with the AeroShell 7 grease. AeroShell 6 does not have that limitation.
Gary A. Sobek
From: kellym(at)aviating.com (kellym(at)aviating.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
--> RV-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
> --> RV-List message posted by: Tom& Cathy Ervin<tcervin(at)embarqmail.com (tcervin(at)embarqmail.com)>
> Kelly,
> Thanks, Tom in Ohio
Larry Bowen
Posted: Sun Apr 11, 2010 12:12 pm Post subject: Hartzell Prop Grease gun & Fittings |
The end of the grease gun is adjustable for a tighter or looser fit,
right? Maybe its too loose on the fitting.
I stuck with the aeroshell 6, as was originally used when assembled.
On 4/11/10, Denis Walsh <denis.walsh(at)comcast.net> wrote:
[quote] What a great set of responses.
> Gary A. Sobek
> place to
> > > Kelly,
> > > Thanks, Tom in Ohio
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Sun Apr 11, 2010 1:46 pm Post subject: Hartzell Prop Grease gun & Fittings |
Mobil 28 is used by the defense industry and exceeds all Hartzell recommendations.
Tom in Ohio
It was new from the factory.
Tom in Ohio.
Posted: Sun Apr 11, 2010 1:49 pm Post subject: Hartzell Prop Grease gun & Fittings |
The gun was the problem! I had to replace the fitting on the end and now it works perfectly.
I understand your concern with changing brands but my past experence with shell products have not been good.....won't use them.
Tom in Ohio
Kellym
Posted: Sun Apr 11, 2010 4:12 pm Post subject: Hartzell Prop Grease gun & Fittings |
The problem is you need to purge the Shell that is already in the hub.
There is NOT a good way to do that. Mixing is taking a big risk.
Tom in Ohio
KCHD |
