skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Mon Apr 05, 2010 8:19 am Post subject: prop still leaking after hub seals changed? |
first couple of hours it was fine, then a little weeping... now quite a bit of oil on the vanes.
any ideas?
M
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
Posted: Mon Apr 05, 2010 8:37 am Post subject: prop still leaking after hub seals changed? |
I think you have an M-14 with a two blade V-530 hub correct? If so...
Depends on exactly what you mean by hub seals. The ones on the prop
blades are there to keep the grease in. If there is OIL coming out of
THOSE prop blade flanges, it is not a bad Hub Blade seal that is the
problem. It's one of the OTHER ones.
If we are talking OIL, there are usually three areas of concern.
1. The large and small o'ring seals for the hub piston (you take the
front hub cover off to get at these)
2. The oil control tube crush washer. This is the PIPE that screws
into the front of the engine that the oil goes through to get to the hub
and control the prop. This has a crush washer on the front that leaks
and ends up coming out the prop area.
3. The shaft seal on the reduction gearbox...that is NOT easy to
change, but does not usually go bad unless you're doing serious acro.
You're going to have to determine exactly where the oil is coming from.
That has been my experience... Others better versed probably have more
accurate advice. I am by no means a prop expert.
Mark Bitterlich
Posted: Mon Apr 05, 2010 9:32 am Post subject: prop still leaking after hub seals changed? |
Remove the prop dome and piston assembly. If there is oil inside the hub, the inner seal on the piston is bad (possibly incorrectly installed too) OR the seal behind the oil tube is bad or the tube is not fully tightened. Most likely it's the inner seal on the piston if there is oil pooling inside the hub. If the piston outer seal is leaking, there will be oil on the inside of the "skull cap" dome. As Mark says, check the front seal on the nose case to see if there is evidence of oil around the prop hub/flange shaft.
Dennis
William Halverson
Posted: Mon Apr 05, 2010 10:41 am Post subject: prop still leaking after hub seals changed? |
When you day 'fully tightened' do you use a torque wrench?
Thanks!
yakplt(at)yahoo.com Guest
Posted: Mon Apr 05, 2010 2:22 pm Post subject: prop still leaking after hub seals changed? |
Thanks for saying it better than I could Dennis. I am a half-ass mech.
Mark
--- On Mon, 4/5/10, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
Subject: Re: prop still leaking after hub seals changed?
To: yak-list(at)matronics.com
Date: Monday, April 5, 2010, 1:27 PM
Dennis
Posted: Mon Apr 05, 2010 3:52 pm Post subject: prop still leaking after hub seals changed? |
I seriously doubt that Mark. -
Dennis
Posted: Mon Apr 05, 2010 5:19 pm Post subject: prop still leaking after hub seals changed? |
But one hell of a sparkvark!
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
Sent: Monday, April 05, 2010 5:19 PM
Mark
Dennis
----- Original Message -----
From: Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E
Sent: Monday, April 05, 2010 11:36 AM
Subject: RE: prop still leaking after hub seals changed?
--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
Mark Bitterlich
Posted: Tue Apr 06, 2010 3:31 pm Post subject: prop still leaking after hub seals changed? |
Only thing in life that I can hold my own in.
Mark
Posted: Wed Apr 07, 2010 3:29 am Post subject: prop still leaking after hub seals changed? |
No question about THAT!
Dennis
