Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Tue Apr 06, 2010 4:40 pm Post subject: Registration vs. Airworthiness - Chicken & The Egg... |
I've gotten some conflicting reports. Do you have your final registration cert from the FAA in hand before you can apply for your Airworthiness cert, or is the pink copy of the registration sufficient?
RV-8 #82880 N998RV
http://www.mattsrv8.com Matt's RV-8 Building Log
Final Bits - Inspection then Test Flight...
_________________ Matt Dralle
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Apr 06, 2010 5:15 pm Post subject: Re: Registration vs. Airworthiness - Chicken & The Egg.. |
The EAA Amateur Built Certification Kit that leads you through all of the paperwork is an excellent resource. Step by step instructions for a very reasonable cost of $12.99. Follow all of the steps carefully and it will all go through without a hitch. It can be ordered by phone or online at EAA.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Gary.A.Sobek
Posted: Tue Apr 06, 2010 7:55 pm Post subject: Registration vs. Airworthiness - Chicken & The Egg... |
You need the HARD CARD from Oklahoma City. The PINK copy is NOT sufficient.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,345+ Flying Hours So. CA, USA
[quote] Date: Tue, 6 Apr 2010 17:37:28 -0700
To: rv-list(at)matronics.com; rv7-list(at)matronics.com; rv8-list(at)matronics.com
Subject: Registration vs. Airworthiness - Chicken & The Egg...
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
RV-8 #82880 N998RV
Final Bits - Inspection then Test Fl========================Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. See how. [quote][b]
FisherPaulA(at)johndeere. Guest
Posted: Wed Apr 07, 2010 4:19 am Post subject: Registration vs. Airworthiness - Chicken & The Egg... |
Looks like you are still getting conflicting reports Matt! I got my AW certificate last August. My local FSDO (Des Moines Iowa) required me to have the final registration – not the pink copy. It may vary by FSDO, but the rule here is as Gary describes below.
Paul A. Fisher
RV-7A N18PF ~80 hours (and happy spring has finally arrived!)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV6 Flyer
Sent: Tuesday, April 06, 2010 22:49
To: RV List
Subject: RE: Registration vs. Airworthiness - Chicken & The Egg...
Gary A. Sobek
[quote] [b]
Posted: Wed Apr 07, 2010 1:29 pm Post subject: Registration vs. Airworthiness - Chicken & The Egg... |
At 05:37 PM 4/6/2010 Tuesday, you wrote:
| Quote: | --> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Matt Dralle |
I found the following bit of information on the FAA web site regarding registrations and the use of the Pink copy. Here's an excerpt from the link that follows:
"You can also check the Document Index to see if recently mailed registration documents have arrived at the Aircraft Registration Branch. Arrival of registration documents in the Registry enables confirmation that application for registration has been made and temporary (pink-copy) operating authority is in effect. Processing registration documents related to a change in aircraft ownership averages 16 working days after their receipt."
http://www.faa.gov/licenses_certificates/aircraft_certification/aircraft_registry/registration_status/
To me, this sounds like as soon as the FAA has received the registration and entered it into the system as indicated by an on line status search, you are allowed to use the Pink copy until the real copy arrives.
I would then assume that Airworthiness could be applied for under the same conditions...?
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Final Bits/Inspection/Test Flight
mrobert569(at)hotmail.com Guest
Posted: Wed Apr 07, 2010 2:30 pm Post subject: Registration vs. Airworthiness - Chicken & The Egg... |
Matt,
The aircraft MUST be registered and you have the registration in hand before the airworthiness inspection can take place.
Mike Robertson
Das Fed
| Quote: | Date: Tue, 6 Apr 2010 17:37:28 -0700
RV-8 #82880 N998RV
&g=====================
[quote] _=====
