Vanremog(at)aol.com Guest
Posted: Sun Apr 04, 2010 4:01 pm Post subject: VM1000 Oil Pressure Sender |
I've troubleshot my installation and all seems good according to the Troubleshooting Guide from VM, but I am getting low readings from the oil pressure system all of a sudden. If any lister has a spare unused P/N 3010018 Oil Pressure Transducer, I would be interested in borrowing it to further confirm the problem.
A new sender fetches a princely sum of $400, so I want to be sure.
Thanks in advance.
N1GV (RV-6A Flying 936TTAE Silicon Valley, CA)
Posted: Mon Apr 05, 2010 5:45 pm Post subject: VM1000 Oil Pressure Sender |
I'll look - I still have a few parts left from my original VM1000...
chaskuss(at)yahoo.com Guest
Posted: Tue Apr 06, 2010 4:11 am Post subject: VM1000 Oil Pressure Sender |
Gary,
I could find only limited spec info for your transducer using a quick Google search. However, if it is a commonly used 10 to 180 ohm unit, you can find a VDO replacement here.
http://www.egauges.com/vdo_indS.asp?Sender=150PSI_10Bar&PN=360-430
This unit also covers 0 to 150 psi and is about 10% of the price of the 3010018.
Charlie Kuss
--- On Sun, 4/4/10, Vanremog(at)aol.com <Vanremog(at)aol.com> wrote:
Subject: Re: VM1000 Oil Pressure Sender
To: rv-list(at)matronics.com
Date: Sunday, April 4, 2010, 8:00 PM
Thanks in advance.
| Quote: | | "_blank" href="http://www.matronics.com/Navigator?RV-List">http://www.mat="nofollow" target="_blank" href="http://forums.matronics.com">http:/======================== |
